Hooking up 3 subs to one amp
Results 1 to 17 of 17
Thread: Hooking up 3 subs to one amp
    Junior Member nadcraker has not yet proved knowledgeable nadcraker's Avatar
    Aug 2005
    Central Valley, CA
    59
    Default Hooking up 3 subs to one amp
    I have a 2 channel amp that can go 100x2 @4 ohms, 200x2 @2 ohms, & 400x1 @4 ohms bridged. I'm thinking of hooking up 3 low wattage subs to it, how would I do that wiring wise? And how would the power be split? Can you run two or more subs off of one bridged channel? I think I need clarification on channels of music and number or speakers, because a car audio guy told me I could run 4 coax speakers off a two channel amp, but I would lose the ability to fade from front to back, but I could still use balance from left to right.
    Nov 2004
    Quebec, Canada
    17,346
    Default Re: Hooking up 3 subs to one amp
    you could, you will have to wire them in parallel.
    its gonna give you something funky though OHM-wise. but it will work.
    check to see if your amp is 2 ohms stable.
    '02 Elantra GT
    '04 Suzuki Katana 600
    Oct 2004
    detroit
    3,820
    Quote Originally Posted by KeWLKaT
    exactly
    contact the sub manufacturer and the amp manufacturer. talk to them and see if the ohm load will be off. if it is, DO NOT wire it up and power it. it will fry the amp and subs.
    click here for K-sport coilover deal
    http://www.elantraxd.com/forums/showthread.php?t=14992
    Boston
    1,713
    if your subs are 4-ohm each, you could wire two in parallel, and hook those up in series to the third, which would give you a 6-ohm load on your amp bridged to one channel. but i'm not sure how that would sound... it could color the sound, but at least it won't cause any damage to the amp.
    if the subs are 2-ohm each, i would wire all three in series for a 6-ohm final load. they will sound fine, and again there will be no strain on the amp.
    2006 Mazda3 S Touring 5-dr
    Aug 2005
    Central Valley, CA
    59
    Thanks for the info guys, but I'm still curious how the power would be split among the subs, depending on if leave it in 2 channel or bridge to one channel.
    Newbie, such a harsh word ryan s-b has not yet proved knowledgeable ryan s-b's Avatar
    Aug 2005
    Brew City
    97
    or you could wire them all in parallel and have it sound super good for 30 min until you fry your amp
    2k5 elantra gls hatch
    audio:
    HU - alpine cda-9813
    comps - cdt cl-61's
    amps - zapco ag750, zapco ag350
    sub - 12" RE SX in a ported box tuned @ 32 Hz
    video:
    ps2 slimline in glovebox w/ 7" flipout in dash lcd screen
    I NEED A UNIVERSAL REMOTE FOR MY RIDE!!
    Boston
    1,713
    i don't see how you have a choice but to have it bridged to one channel. you don't want two subs on one channel and one sub on another.
    here's another idea: run the amp in 4-channel mode, and have one sub per channel and leave one channel unused. but then you have to split your input signal among three channels... that will reduce your signal to noise ratio.
    Junior Member chaos GT has not yet proved knowledgeable
    Aug 2004
    PA
    141
    Quote Originally Posted by southpawboston
    the first method would work fine as far as the amp is concerned, but it would provide unequal power to the subs. that's just asking for cancellation issues and you'd probably be better off just running 2 of the speakers.
    the second option, although not delivering full power from the amp would work just fine.
    it'd be really helpful to know the make/model of the subs and amp though so we know what options are even possible.
    Aug 2005
    Central Valley, CA
    59
    Well I was just asking for the knowledge, because I was thinking about getting 3 8" subs. But today I got 2 JL 10W1v2 8 ohm subs. So I have those two subs, plus the Arc Audio KAR 400.2 amp ( 100x2 @4 ohms, 200x2 @2 ohms, & 400x1 @4 ohms bridged ). Those subs are rated for 150W (assuming thats RMS), so what would be the best way to wire them? If I bridge it, how many watts would each sub get? I think it would be too much.
    DON'T PANIC! Atomic has not yet proved knowledgeable Atomic's Avatar
    Nov 2004
    North Glendale, Arizona
    486
    Bridging the amp and the subs wired in parallel, you'd be pushing a max of 400watts @ a 4ohm load, so 200 per speaker. But that's at max volume, so really about 50-100 watts RMS, which should sound fine.
    2006 Santa Fe
    Aug 2004
    PA
    141
    that looks like a good match up you have there. do as atomic said and run the subs parallel and bridge the amp. the jls should take 200 watts no problem.
    Boston
    1,713
    ^^^ what they said. good setup. and the JLs will handle it fine.
    Aug 2005
    Central Valley, CA
    59
    Thanks a lot for all the help guys, Im gonna get to work on designing/building a box now. I'll post pics when I'm done, IF it turns out post-pic worthy
    Columbus, Ohio
    12,676
    oh, the box building stage. me and nick tried this the other night. im sure if we had GOOD wood (shut up, i know what youre thinking) instead of some been rained on 1/2" MDF and instead had some solid, non-warped 3/4" or even 1" MDF, it could be a lot nicer. once he gets a little $ together, the box will be a lot nicer. ive been thinking of building myself one once i find the carpet so it doesnt look like a wood box
    Nov 2004
    Quebec, Canada
    17,346
    LOL all of this to come to the conclusion that my first post was the right one?
    '02 Elantra GT
  18. #16
    Aug 2005
    Central Valley, CA
    59
    Well I got my box built. A basic, sealed enclosure that fits right up close to the seats and still gives me tons of trunk space. But now when it comes to adjusting my amp, I've got some questions. How do I know where to set the crossover? I want Low Pass mode, but at what frequency? I've searched JL's site and can't find a reccomendation, or something that says the subs safe frequency range or anything.
    http://mobile.jlaudio.com/products_s...p?series_id=15
    ^^^ Thats my subs right there, but the only thing I see on their table that has to do with frequency is Free Air Resonance (Fs), which I have no idea what that is. Any help?
  19. #17
    Oct 2004
    detroit
    3,820
    thuroughly read thru this site. everything you need to know.
    http://ccs.exl.info/frame_main.html
