Why won't the air bag light go out on my 2000 Elantra?
Results 1 to 13 of 13
Thread: Why won't the air bag light go out on my 2000 Elantra?
    Question Why won't the air bag light go out on my 2000 Elantra?
    I am rebuilding a wrecked Elantra. I replaced both bags and control module. I checked all fuses and they are ok. Any ideas?
    Senior Member VTElantra has not yet proved knowledgeable VTElantra's Avatar
    Mar 2005
    Plainfield, VT
    903
    Default Re: Why won't the air bag light go out on my 2000 Elantra?
    have the dealer clear the light with there computer.
    www.eztechhelp.com please register MY BLOG
    Poster God CTele02 has not yet proved knowledgeable CTele02's Avatar
    Aug 2004
    New Haven, CT
    2,233
    To clear a CEL yourself and reset the ecu for FREE. First warm up the car for 5 minutes until at normal temp. Second turn it off and disconnect battery. Wait for the Ecu reserves to drain and assist it by pushing the foot brake. Reconnect the battery and turn the car on. Drive regularly for the ECU to "relearn" its maps and the CEL should be off if you fully drained the reserves. Now if it comes back on, that means you did not repair the issue/problem since the ECU recognized it again.
    Now: 2006 Subaru Legacy
    Rota Slipstreams For Sale
    Near Chicago, IL
    15,223
    ^^^That works for a CEL reset, but I don't think it will work for an Airbag light reset? I thought that could only be cleared by computer. Worth a shot, i suppose, but don't get your hopes up.
    • Future: ????
    May 2005
    cambridge,md
    3,323
    If the car was in a wreck bad enough that you had to replace both bags,you will need to replace the srs wiring harness.Also, you probably have bad seatbelt pre-tensioners.Go get it looked at and they will tell you what codes are stored,therefore,you can get the parts to do it right.Never skimp on safety my man
    Expect the unexpected.....................
    My name is Aaron Vampyrate knows a lot about Elantras Vampyrate's Avatar
    Jun 2005
    Warrenton, VA
    7,827
    airbags dont work like that... my light was on and i got tired of it and just took out the fuse until i can take it to a dealer
    Some problem with the Internet and Jesus not getting along or something.
    There hadn't been a problem in weeks and then last night out of nowhere Jesus strikes again. Sorry kids.
    I also replaced the seatbelts. All of the parts came out of a car that hadn't been wrecked. I called a dealer and they said I would need to have the code cleared. I'll try that then.......we'll wait to see.
    Does this need to be done by a dealer or can it be done by someone else?
    May 2005
    cambridge,md
    3,323
    Quote Originally Posted by bloney24
    Does what need to be done by a dealer?
    Does the computer need to ber reset by a dealer or can someone with a scantoo do it?
    May 2005
    cambridge,md
    3,323
    Any OBDII scan tool that is capable of reading and clearing codes should do the trick.Make sure that you get the codes wrote down before they clear them,and thats if the codes clear and dont return.After retrieving the codes,go on hmaservice and find out what the codes mean or post them on here,and then you can fix it from there
    Thanks 05xd!!
    Had to replace the clockspring. low resistance on wire to airbag from clockspring.
    All fixed
    May 2005
    cambridge,md
    3,323
    Not a problem.Good to know you got it fixed.
