Headlights not working?!?!
Results 1 to 14 of 14
Thread: Headlights not working?!?!
    no longer a newbie :) 04Elantra has not yet proved knowledgeable 04Elantra's Avatar
    Long Island, NY
    600
    Default Headlights not working?!?!
    Maybe someone out there has had the same problem.
    Last night I go out and start my car and the low-beams will not go on. My interior lights, turn signals, side marker lights, and taillights all work properly. Even my high-beams work. At first I thought it might be a fuse, but then wouldn't the high-beams not work either? Please help me.
    Sparta, NJ
    6,437
    Default Re: Headlights not working?!?!
    Check the fuse....if it is the fuse, figure out why. they don't pop on their own.
    Then check the bulb. Although very uncommon, both bulbs can pop at the same time.
    Then I'd check connections, grounds and anything that might be interupting the powerflow of the circut. And if it isn't the bulbs to maybe bring it in for warrenty.
    MySpace/Facebook
    Keyan.
    You are my ****ing hero.
    Long Island, NY
    600
    well, checked the fuse and then used a test light to test the harness that plugs into the headlight bulb...and there is power. Guess both bulbs burnt out at the same time (or i got a short). To the mechanic tomorrow.
    My name is Aaron Vampyrate knows a lot about Elantras Vampyrate's Avatar
    Jun 2005
    Warrenton, VA
    7,827
    i say get some el cheapo headlights and try those, and if they dont light, then there is a short. i personally think that both just died at the same time
    Some problem with the Internet and Jesus not getting along or something.
    There hadn't been a problem in weeks and then last night out of nowhere Jesus strikes again. Sorry kids.
    Cheap & Frugal Member quickfingerz has not yet proved knowledgeable
    Mar 2005
    Sacramento, CA
    716
    My Silverstars died at the same time (lasted 3 months, paid $30). Now I just run 4500K ebay bulbs @ $9 ea.
    Front Damping (0.3m/s, exp/comp): (Tib KYB GR2-235/50) (Tib Ultrasports-209/57) (Elantra KYB GR2-130/40) (Elantra stock: 105/26)
    Rear Damping: (Tib KYB GR2-118/42) (Elantra KYB GR2-75/30)
    Junior Member elantraNJ has not yet proved knowledgeable
    Apr 2005
    New Jersey
    73
    it is probally a relay in the fuse box under the hood check there had the same problem with my car
    Long Island, NY
    600
    well...both headlights went at the same time...everything is cool for now...maybe I will hunt down some ultrabrights or leds for em.
    Justin is my slave name! menallychllngd has not yet proved knowledgeable menallychllngd's Avatar
    Dec 2004
    Mays Landing, New Jersey
    658
    yeah its not uncommon it seems for both lights to go at the same time in our cars. its also not uncommon for one to die one day and the other die the next. this happens to me all too often.
    May 2005
    cambridge,md
    3,323
    Thats just Hyundais way of getting you back in the shop
    Expect the unexpected.....................
    Junior Member Gustavs01 has not yet proved knowledgeable Gustavs01's Avatar
    Mar 2005
    Mankato,Minnesota
    75
    My Lights went out the other night too Coming home from Work and the High beams worked but Lows did not smae as your problem ended up being My Sylvania Silverstars that I just put in before winter I called the company and chewed them out real good they are refunding me my 30$ Never Again will I buy Lights like that Now to find some decent ones that wont burn out within 3 months
    xd tunner mayollo072R has picked up a wrench mayollo072R's Avatar
    Dec 2005
    Carolina, Puerto Rico
    1,488
    Check your headlight relays. If the relays are okay. Then your bulbs are unusually burned at the same time.
    Resident Hacker wazntme has not yet proved knowledgeable wazntme's Avatar
    May 2005
    United Stated
    144
    i also had Sylvania Silverstars until they burnt out 26 days after install? WTF
    Volunteer Firefighter Station 49-1 Spring Lake Heights, NJ
    2002 Hyundai Elantra GT 2.0L 5 Speed
    DONE-
    -Stage 3 Clutch + lightweight Flyweel
    -Slave Cylinder Mod
    IN Progress-
    -Something cool that no one else has
    Boston
    1,713
    or just go to the dealer and they will give you two new bulbs for free. it is a warranty item after all.
    2006 Mazda3 S Touring 5-dr
    Newbie Lord_GalAthon has not yet proved knowledgeable
    Feb 2006
    Montreal, Banana Republic of Canadia.
    28
    Quote Originally Posted by southpawboston
    Yeah then you can change them yourself, easy excuse to snoop under that hood. I love underhoods...but not as much as underwear. (girlie underwear...)
