Alternator replacement
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 37
Thread: Alternator replacement
    Ultimate Post Whore slow 2K2GT knows about Elantras slow 2K2GT's Avatar
    Ontario
    4,605
    Default Alternator replacement
    Tools for job:
    10, 12, 14mm sockets/wrenches
    Difficulty level: 2
    Time for project: 1 hour
    Removal:
    1) Open hood
    2) Gaze a engine with disgust
    3) Disconnect battery!
    4) Remove coolant overflow line (ensure the engine is cold when doing this)
    5) Remove PS pump adjustment bolts
    6) Move PS pump to the side.
    7) Remove PS pump bracket (6 bolts total: 3 in triangle, 1 down and to the right and 2 on left side of bracket)
    8) Now there is another bracket to loosen, you cant remove it unless you you remove the waterpump pulley and thats just a pain, so loosen the two bolts off as much as you can until that bracket swings to the left.
    9) Go underneath car
    10) Remove power wires from alternator (clip and bolt)
    11) Remove nut from alternator, then push long swivel bolt out.
    12) Now push on alternator until it comes off bracket.
    13) Go back up top and try to wrangle alternator out.
    Install is just opposite of removal though when installing alternator make sure its totally bolted down with belt tension set before going on to PS pump.
    Install points to consider:
    A) Put swivel bolt through new alternator with the nut on the end.
    B) Seat alternator back on to lower swing bracket and push in as far as possible, it will be very tight so dont give up.
    C) Once its in as far as you can manage swivel alternator up and place the tension adjustment bolts in so that the alternator swings for up and down adjustment. If you push the alternator all the way down at this point the lower bracket will seat itself all the way in.
    D) Now carry on with PS bracket and pump installation and adjustment.
    I'm Frank fgummett has not yet proved knowledgeable fgummett's Avatar
    Sep 2005
    Nova Scotia, Canada
    642
    Default Re: Alternator replacement
    Many Thanks... nice to have the voice of experience on this kind of thing
    And of course, it goes without saying that the battery is disconnected for this procedure.
    05GT 5SPD, CAI+K&N, P&P TB-coolant, P&P IM+Phenolic, PCV filter, TWM+M1, EVO Bushings, SS Clutch line, Slave, Tib Sway, F/R strut bars, PC680, Ground, Altron 4, Flamms, Iridiums, Xenons, 5 brake-light, X-Plod speakers/grills, De-badged, Custom grill, Painted calipers. SS brake lines SOON!
    Search is your friend. j0hnh0lmes has not yet proved knowledgeable j0hnh0lmes's Avatar
    Feb 2006
    Dunedin, Florida
    1,610
    Quote Originally Posted by slow 2K2GT
    I WILL TAKE PICS TODAY AND LABEL THEM TO BEST OF MY ABILITY FOR EASE OF UNDERSTANDING!
    Tools for job:
    Difficulty level: 2
    Removal:
    -Open hood
    OMG......OBVIOUS...SORRY. I'm a n00b and I could have figured that one out.
    Sep 2005
    Nova Scotia, Canada
    642
    Quote Originally Posted by j0hnh0lmes
    I'm sure it was obvious to you.. BUT you might be surprised what some folks do.. I try not to be anymore
    Ontario
    4,605
    hope this works for everyone, if I didnt cover something feel free to let me know and I will add it, though I think this is about it.
    Great DIY....
    Oct 2004
    detroit
    3,820
    sweet man. many thanks
    click here for K-sport coilover deal
    http://www.elantraxd.com/forums/showthread.php?t=14992
    Apr 2004
    Southeast DC
    25,975
    Good stuff. Would it be too much to ask for you to host the pics in your EXD gallery and place them in the list where they fit in? That way I can do a DIY page for it and not screw it up, haha. THANKS!
    HID Master playboyz28 has not yet proved knowledgeable playboyz28's Avatar
    Regina, Saskatchewan, Canada
    606
    actually, you could get it from the bottom...a bit of a tight squeeze..but it works....
    I guess if you dont have acces sto a hoist, removing from thr top woul dbe the only and easiest way to do it.
    Jason
    Ontario
    4,605
    Ok James hope that helped...Im sure if you had a stock manifold it could come out the bottom, but with the header in the way, actually there was still all kinds of room I just couldnt get the alternator out. So I figured this is the easiest way seeing as most can access everything under the hood easily enough.
    Ontario
    4,605
    Ok now I wont need another alternator for the same reason...I bought a new plastic guard for under the car...it was $7!
    Nov 2004
    Quebec, Canada
    17,346
    thats the protector for the oil filter, right?
    i need to buy me one of those, bought the car without it
    '02 Elantra GT
    '04 Suzuki Katana 600
    Ontario
    4,605
    yeah, well it does double to keep water and stuff out of the alternator also, yes buy it before you end up like I did!
    Nov 2004
    Quebec, Canada
    17,346
    Yeah I think I will do that next time I'm at the dealership (wait, i never go there!), i mean, if i ever come near I'll pick one up
    '02 Elantra GT
    Poster God CTele02 has not yet proved knowledgeable CTele02's Avatar
    Aug 2004
    New Haven, CT
    2,233
    Lol theres a difficulty level for DIY???
    Now: 2006 Subaru Legacy
    Rota Slipstreams For Sale
  18. #16
    Ontario
    4,605
    Quote Originally Posted by CTele02
    Sure why not!
  19. #17
    Apr 2004
    Southeast DC
    25,975
    You knows why I waited so long on this one.
    Do It Yourself.
    Thanks again.
  20. #18
    Call me J xdforme22 can identify a wrench xdforme22's Avatar
    Apr 2006
    Pennsylvania/Michigan
    1,978
    I did mine from the bottom, just looten the belt off of the alternator, remove two screws holding the plastic "wall" between the alternator and the wheel well. Unplug and unbolt the alternator and remove through the wheel well.
    Looks good though.
    Quote Originally Posted by Bobzilla
    But if it ain't broke, don't fix it is my old motto. Unfortunately that got replaced with: Break it so you can fix it sooner.
  21. #19
    Newbie juggalo483 has not yet proved knowledgeable juggalo483's Avatar
    Mar 2007
    palm springs
    1
    anyone know where to get a Higher output altanator for an 06 gls
  22. #20
    Human Radar Detector FirePenguinz has not yet proved knowledgeable FirePenguinz's Avatar
    Apr 2007
    Cleveland, Ohio
    147
    may i also suggest that you remove the right side fan when doing this. gives you plenty of extra space to work with and all it takes is to remove two screws and unclip the harness
