Clutch Torque Specs! asap!
Results 1 to 11 of 11
Thread: Clutch Torque Specs! asap!
    Sparta, NJ
    6,437
    Default Clutch Torque Specs! asap!
    Does anyone who has done a clutch install know the torque specs for the:
    flywheel/crankshaft bolts
    pressure plate/flywheel bolts
    bell houseing bolts
    and any other numbers i need?
    MySpace/Facebook
    Keyan.
    You are my ****ing hero.
    Columbus, Ohio
    12,676
    Default Re: Clutch Torque Specs! asap!
    crank-flywheel is 90-110 ft/lb. pressure plate/flywheel is probably about 35, and id go about the same on the bell housing. the last 2 im not positive, but the flywheel/crank is correct
    i thought you had access to webtech?
    Sparta, NJ
    6,437
    Quote Originally Posted by evan938
    I do, but I spent an hour looking for the numbers but all i could find were the starter/bellhousing specs. I guess I was looking in the wrong place.
    All I really need now is a torque wrench. autozone doesn't rent them LOL....
    MySpace/Facebook
    Keyan.
    Columbus, Ohio
    12,676
    hold on...
    youre doing a auto -----> manual swap and you dont even have a basic tool like a torque wrench?
    Sparta, NJ
    6,437
    hold on...
    lol it's not a "basic tool". If it costs over $50 it isnt a "basic tool"
    lol.
    MySpace/Facebook
    Keyan.
    Columbus, Ohio
    12,676
    um, i got mine for under 30$ and a torque wrench should be the 1st thing you buy after a socket set
    Full Member chillbro1 has not yet proved knowledgeable chillbro1's Avatar
    Apr 2006
    Michigan
    316
    hmaservice.com in the shop manual states that the clutch cover bolts should be tightened to 11-16 ft/lbs. in a star pattern.
    Hope this helps...
    Peace,
    GT_Lightweight LateAPXR has not yet proved knowledgeable LateAPXR's Avatar
    Aug 2005
    Indianapolis, IN ('05 XD2 TW Blue 5dr,5spd)
    243
    I bought my torque wrench for $13 at Harbor Freight (I'm a lucky SOB that has a brick&mortar storefront in town).
    And YES it is QUITE necessary when doing practically ANYthing on a car.
    September 2006 COTM
    Check out my website!
    http://www.timnovinger.com/
    11-16 is right for the pressure plate to flywheel bolts.. 35 will strip the flywheel. Ask ryanolson, betaswap guy. He tore up a flywheel doing that.
    book says 90-96 on the flywheel
    I have yet to find the right torque spec in the book for the bell housing but I went with 35 and mine turned out ok.
    You really need a torque wrench when dealing with stuff like this. Not setting things to there proper torque will cause problems later. Its to easy to get it right the first time.
    Super Hero XDGT03 has not yet proved knowledgeable XDGT03's Avatar
    Michigan
    579
    http://www.harborfreight.com/cpi/cta...Itemnumber=239
    $12.99
    Do you ever take your wheels and tires off? Don't you use a torque wrench to put them back on? Maybe that is what happened with your girlfriends car when the wheel came loose and the studs broke.
    Sparta, NJ
    6,437
    ok, ok I get it. I'll buy a torque wrench.
    MySpace/Facebook
    Keyan.
