Squealing belt when turning steering wheel all the way left or right
Results 1 to 14 of 14
Thread: Squealing belt when turning steering wheel all the way left or right
    Car
    2001 Elantra GLS
    Philadelphia, PA
    1,275
    Default Squealing belt when turning steering wheel all the way left or right
    When I go to do a 3-point turn to get out of my little street, if I turn the wheel all the way to the right or to the left, my car makes a terrible squealy belt noise. Should I be concerned about this? I replaced all of my belts not too long ago, did they just not tighten the power steering belt? (There is such a thing as a power steering belt, right? Heh.)
    151,000 miles on my '01 Champagne GLS w/ Euro Antenna, OEM Wood Dash Kit, OEM Tiburon Gauges, KDM Card Holder, OEM Tiburon Clarion/Hyundai CD player, GT Tweeters, Mussa Strut Bar, 19mm Tiburon OEM Sway Bar. Pics & Details here, Maintentance log here
    Elantra XD
    Car
    2003 Hyundai Elantra
    Columbus, Ohio
    12,675
    Default Re: Squealing belt when turning steering wheel all the way left or right
    my bros car did it too, and no matter how much we tightened it, or loosened it, it still happened. i popped the hood one day and had him turn the wheel and when he was locked either way, the pully wouldnt spin, but the belt did, making it squeal. he totalled it a few days later, so we didnt worry about it
    mine also did it after i removed my OBX crank pulley a week before i stopped driving it...not sure why though...
    only think i can think of is to get your power steering fluid flushed and refilled, and make sure the belt is at the correct tension and see if it helps
    Car
    2000 elantra
    Jun 2006
    delware,ohio
    713
    had the same problem but i just lossen my alternator belt and where tighten that and it went away.i've had this problem lots of times on the j2
  5. #4
    Car
    2003 Hyundai Elantra GLS
    Texas
    1,809
    Mine as well. Just put a little more tension on it yesterday.
  6. #5
    Car
    2000 Elantra
    Oct 2006
    San Diego
    181
    Belts often need to be adjusted soon after installation. For sure they should be checked after a few hundred miles.
    Fishslayer
  7. #6
    Car
    Texas
    1,809
    that would be the third adjustment over 10k miles...
  8. #7
    Car
    2004 Hyundai Elantra
    Mar 2006
    New Mexico
    313
    I just dealt with this problem and after racking my brain (and buggin some xd members about it) I was able to fix it by tightening my alternator belt, and at that point I realized that I no longer have the metal piece with the two bolts through it, on of the bolts which screws into the alternator through the slot in the alternator bracket, so now I have to retighten the alternator every week or so cause it wiggles loose while driving
  9. #8
    Car
    S13 Coupe, 1999 Hyundai Tiburon 5 speed
    Jun 2005
    Eastern Shore, MD
    12,621
    make sure all the belts are secure and have enough tension on them and make sure your fluid is at the correct level.
    2002 Hyundai Elantra: Sold
    1992 Toyota MR2: Sold
  10. #9
    Car
    2000 Elantra
    Oct 2006
    San Diego
    181
    Might be worth a mention that TOO MUCH tension is as bad as too little tension. Worse, actually. Too little & ya squeal. Too much & ya get early bearing failure.
    Fishslayer
  11. #10
    Any chance someone can point me to some instuctions on how to check for proper PS belt tension?
  12. #11
    Dec 2005
    Atlanta, GA
    162
    oooh, old topic. But it still haunts.
    yeah I put all new belts on my 05 XD2 and it squeels like a pig at max lock, and only at max lock. What I don't understand is the PS belt is nice and tight BUT the PS pump is at the maximum "up" position. so I can't loosen the tension even if I wanted. which I guess is good because its squeeling, but being bottomed out surely isn't ideal I would think. I'm using all hyundai belts. so yeah. if being "too" tight can cause squeeling, then the only hope I have is that it will loosen up every so slightly with age and alleviate the noise.
    I wish these cars had a serpentine belt with a single automatic tensioner like my Benz. Talk about a quick, flawless install that's impossible to mess up. sigh. There's nothing worse than people looking crazy at you for having a screaming car.
  13. #12
    Car
    2006 Hyundai Tucson
    Oct 2006
    on your ignore list
    2,532
    All cars squeal a full lock. The belt is squealing because the pump stressed when trying to push the rack further than it can go.
  14. #13
    Car
    2002 Hyundai Elantra GT
    Jun 2006
    Italy... oh joy :(
    353
    mine doesn't make any of those noises and i've done the belt twice already.
    When you're out of fuel, your altitude is dropping and you're out of ideas...Eject! Eject! Eject!!
    Fired Up!! Feels Good!!
  15. #14
    Car
    2005 Elantra VE A/T
    Dec 2007
    Calgary, AB, Canada
    4,864
    Mine does it too. Instead of 3-pointers I e-brake turn... fun for the whole family!
    I once thought I was wrong. It turned out I was only mistaken. Hasn't happened since.
    Like what I'm saying? Use the Rep system and let me know! You can also follow my Twitter.
