Water leak in trunk
Results 1 to 11 of 11
Thread: Water leak in trunk
    Newbie 22t has not yet proved knowledgeable
    Nov 2006
    Canada
    1
    Default Water leak in trunk
    I have a 2001 4 door Elantra VE, It has rained a fair bit here on Vancouver Island the last few days and when I opened the trunk I noticed the mat was soaking wet and when I removed it I noticed that there was ~ a half a litre of water in the drivers side well to the left of the spare tire holder. I could not find any obvious spots where it could of leaked in. The rubber looks fine. Any thoughts on this, has anyone else had this problem?
    Thank you
    Senior Member alienman has not yet proved knowledgeable alienman's Avatar
    Oct 2005
    saskatchewan
    565
    Default Re: Water leak in trunk
    get a hose, or go to a car wash and get someone you trust, make sure it is someone you trust to come with you. get in the trunk and shut it, then have the other person spray water all over the trunk edges and watch to see where it is coming in from... you prolly have to have a flashlight to see...
    Another thing you can check is if there are any plugs missing out of the trunk floor in case the water is coming up from underneath while you drive.
    Veni, Vidi, Velcro Munky has information that can be trustedMunky has information that can be trusted Munky's Avatar
    May 2006
    Noblesville, IN
    10,969
    Quote Originally Posted by alienman
    Yeah, that's REAL important, lol.
    Nov 2004
    Quebec, Canada
    17,346
    ...or just fold the seats down so you can escape the trunk, lol
    '02 Elantra GT
    '04 Suzuki Katana 600
    Senior Member Slapshotman7 has not yet proved knowledgeable Slapshotman7's Avatar
    Aug 2006
    Vermont
    731
    I do believe that my 05 has a trunk release handle on the inside, or atleast thats what I assume it is, I havent actually locked myself in the trunk to find out.. and I dont intend on it either..
    May 2006
    Noblesville, IN
    10,969
    Mine does
    There is a seam in the trunk that is not sealed. They are in the back corners (next to the bumper) and water comes up from there.
    EXD SupaMod Ugzz knows a lot about Elantras Ugzz's Avatar
    May 2006
    Pittsburgh
    9,870
    im not from canada hehe -seeing litres threw me off 2- heh
    but my old car had a small hole in the rubber where the taillights were located, wires went out and under the car there. i see the hyundais similarly near the lid some have rubber sections there. i would look into those. even thought i had only a small hole everything in my trunk was SOAKED when it was really rainy. and because most of it was backsplash from the road it was dirty water at that :P
    Lil SnowFlake TURBOgls has not yet proved knowledgeable TURBOgls's Avatar
    Jan 2005
    Rockville MD
    828
    ok, had the same problem, what it is, is that water runs down the weather stripping and gets into a tiny hole where the sheet metal is joind together, then runs into the trunk, had a real hard time trying to figure that out today because i had the same problem, got a little sealant and fixed it
    2001 Hyundai Elantra GLS Automatic
    My Garage
    Nov 2004
    Quebec, Canada
    17,346
    fixed it and thats what counts
    '02 Elantra GT
    Newbie GTRosie has not yet proved knowledgeable
    Jun 2011
    Morelos, Mexico
    4
    anyone have an actual fix for this? or can you give better details as to where these seams and rubber etc are exactly located? and exactly how to fix it??
