grounding
Results 1 to 4 of 4
Thread: grounding
    Car
    2002 Elantra
    Sep 2006
    Mulberry, FL
    28
    Default grounding
    im interested in in stalling ground wires so I wanted to know how to also
    what the diference is between voltage stabilisers and ground wires or if it would be good to have bolth and what kinds of gains can i exspect
    this might be a good diy
    Elantra XD
    Car
    2003, Hyundai, Elantra GLS (Moonroof+ABS+TCS)
    Mar 2006
    Seoul, Korea
    491
    Default Re: grounding
    Voltage stabilizer: generally, your electronic devices will get more stabilized voltage, which makes your devices more reliable(or provide more lifetime. eg. headlight bulbs). audio sound quality is also improved(less noise) according to many users..
    (Bigger) ground wires: less resistance (which makes less voltage for devices. eg. brighter headlight), (maybe) less voltage difference between ground points (which may improve your audio quality) ?
    however, forget about "increased torque", "increased gas mileage". I don't think there would be any meaningful difference in those criteria.
    ground wire kits : usually provide less resistance for ground wires. (thicker cables)
    voltage stabilizers : a (big?) capacitor attacthed to the battery. "damping" or "buffering" voltage output, which supress fluctuation.
    ps. I'm not one of the users. I just ordered ground wire kit today. and.. will order pivot raizin later..
    Car
    2010 Equator, 2003 Tiburon GT, 2004 Santa Fe, (Sold 2002 Elantra GLS A/T)
    Near Chicago, IL
    15,060
    2010 Equator Sport | 2002 Elantra GLS (sold) | 2003 Tiburon GT | 2004 Santa Fe GLS
  5. #4
    Car
    2002 Elantra
    Sep 2006
    Mulberry, FL
    28
    thanx babot
