Timing Belt?? Timing Chain??
Results 1 to 17 of 17
Thread: Timing Belt?? Timing Chain??
    Crooked H to the HEART ShowOffXD has not yet proved knowledgeable ShowOffXD's Avatar
    Aug 2005
    MIAMI
    115
    Unhappy Timing Belt?? Timing Chain??
    Im very confused on the aspect of..is are engine belt or chain driven?? I have 140,000 miles and very scared of the belt breaking if in fact it is a belt. Some feedback ASAP would be great. Thanx
    Nov 2004
    Quebec, Canada
    17,346
    Default Re: Timing Belt?? Timing Chain??
    Its a belt.
    CHANGE IT ASAP
    EDIT: Forgot to add, we have interfering engines, meaning that if your belt breaks, then big chances that a piston will touch a valve and **** it up.
    '02 Elantra GT
    '04 Suzuki Katana 600
    EXD Pro Member zx2uner has not yet proved knowledgeable zx2uner's Avatar
    Jun 2005
    Fargo, North Dakota
    2,058
    There is a timing belt that is run from the crank to one of the cam shaft pulleys.
    Under the valve cover there is a chain that drives one camshaft with the other.
    Thanks for being a knowitall Alex.
    Nov 2004
    Quebec, Canada
    17,346
    Yeah but some cars do have a timing chain instead of a belt
    Which is why he asked. Those usually require no maintenance.
    '02 Elantra GT
    Jun 2005
    Fargo, North Dakota
    2,058
    I know...I was just making sure he knew that the belt needs to be changed....the chain doesn't normally.
    Nov 2004
    Quebec, Canada
    17,346
    Ah ok gotcha
    '02 Elantra GT
    Full Member 03GTE has not yet proved knowledgeable 03GTE's Avatar
    Jun 2006
    Everett, Washington
    261
    the dealer just replaced the chain on my GT it was loose or some thing? dont know all i know is that having a warrenty is a beautiful thing! lol
    03 GT- Gone.
    03 Xterra - 31 inch BFG Mud Terrain's
    Indiana
    11,228
    Actually, on the Beta's, and especially the 1.8 beta the chain and guides would wear and need replaced with age. They would chatter and rattle. But the belt was needed to be changed at 60k miles. You're past due for your second belt.
    Lil SnowFlake TURBOgls has not yet proved knowledgeable TURBOgls's Avatar
    Jan 2005
    Rockville MD
    828
    just had mine changed, the car runs like new now!!
    2001 Hyundai Elantra GLS Automatic
    My Garage
    Veni, Vidi, Velcro Munky has information that can be trustedMunky has information that can be trusted Munky's Avatar
    May 2006
    Noblesville, IN
    10,969
    I have an '02 GLS, 2.0, anyone know if I have a belt or chain?
    Jun 2005
    Fargo, North Dakota
    2,058
    both...the belt needs to be replaced at 60,000 and the chain should be checked periodically too
    Aug 2005
    MIAMI
    115
    Wow, thanx guys, I'm gonna go get that checked out ASAP.
    Slave to the Grind Hyundia_90250 has not yet proved knowledgeable Hyundia_90250's Avatar
    South Gate,Ca
    251
    Question Re: Timing Belt?? Timing Chain??
    O.k. I have a 2.0 beta (01GLS) and I just passed 74500(20,000+ in 6 months) how much is it to get it changed(both dealership and self) and is it part of the 60000 check?
    Wizards first rule: "People are stupid, they will belive anything the fear to be true or wish to be true"
    Oct 2005
    Fort Worth, Texas, USA
    3,332
    No, it's not normally part of 60,000 mile service (although how the services are packaged is up to the dealer).
    Member Extraordinaire! blupupher has not yet proved knowledgeable blupupher's Avatar
    Aug 2004
    Katy, Republic Of Texas
    532
    DIY: less than $150 USD (with waterpump)
    Dealer: $300-400 USD.
    While it is not a real complicated DIY, it does take time and must be done absolutly correct, or you can destroy your engine.
  18. #16
    The hyundai dealer i worked at was seeing 03-04 xd's with 65,000 mi on them and the belts were breaking left and right. But iam in AZ so that might be why, very dry area. Also They were charging like four hours labor and I was doing them start to finish with tensioner in about a half hour.
  19. #17
    Poster God txdproject has not yet proved knowledgeable txdproject's Avatar
    Dec 2005
    Chicago, IL- South Sub's
    1,001
    took gt in with 86k on it and need a new timing chain today. Chain had slack in it making my car sound like a truck when at idle.... so if you car sounds like that get ya butt into the dealer and get a chain
