Rear wheel bearings
Results 1 to 20 of 20
Thread: Rear wheel bearings
    Full Member krellmk has not yet proved knowledgeable
    Aug 2006
    brooklyn ny
    441
    Default Rear wheel bearings
    Does the 02 Elantra uses rear wheel bearings ?
    Oct 2004
    Redondo Beach, Ca
    4,862
    Default Re: Rear wheel bearings
    Sealed bearing assembly.
    EXD Pro Member 04 elantra cvvt has not yet proved knowledgeable 04 elantra cvvt's Avatar
    Georgetown, Texas
    3,501
    ^^^ What he said. There is a bearing with a nut in the rear. Not too hard to remove. What is the problem?
    Aug 2006
    brooklyn ny
    441
    So a post somewhere here on rear wheel bearings
    Oct 2004
    Redondo Beach, Ca
    4,862
    ^Was that a question? Statement? I couldn't really understand what you were going for...
    With Odin on our side... bfgoedeke has not yet proved knowledgeable bfgoedeke's Avatar
    Dec 2005
    Keansburg, New Jersey
    267
    The bearing and hub (rear) are one unit. Remove the hub to replace the bearing. Pretty easy. Use a 1-1/4" socket to remove, with a breaker bar....Replace the nut if possible. Torque to spec ( very critical ) and stake the nut into the groove on the spindle. No cotter pins required....ANy ques. just PM me...I have the Factory manual..
    17" x 7" ADR Phantom rims with Falken Ziex 512's
    Mussa front and rear strut bars
    PSC rear 20mm sway bar
    Rear disk conversion
    Fujita CAI
    Evo Fusion catback
    Indiana
    11,228
    Kinda have to have a wheel bearing. Without one it makes it darn near impossible to move. . . . . now what TYPE of bearing is a different question.
    Full Member xxxmonoxidechil has not yet proved knowledgeable xxxmonoxidechil's Avatar
    Aug 2006
    rockford, IL
    466
    i was thinking the same thing after reading the 1st post
    Oct 2004
    Redondo Beach, Ca
    4,862
    Quote Originally Posted by bfgoedeke
    I think you're talking about the front where you have to remove the axle nut. The rear has no axle, therefore no axle nut.
    Aug 2006
    rockford, IL
    466
    but there is a 1 1/4 nut that needs to be removed on the rear. i think he just didnt know how to work it properly. once you remove that nut, the bearing slides right out.
    rear wheel bearings are insanely easy. its only 1 step harder then doing the brakes.
    Oct 2004
    Redondo Beach, Ca
    4,862
    Hmm. I guess I have to go look at my car to see. I guess I'm just used to GM's where there's three bolts that go through the knuckle to hold the hub/bearing assembly on...
    Senior Member HYTECH has not yet proved knowledgeable
    Jul 2006
    florida
    569
    The rear has a spindle that the hub and bearing slide onto.
    If you have drum brakes you take the wheel, drum, then the 1 1/4" nut off it takes 5 minutes
    If it has disc brakes you take the wheel, caliper and bracket, rotor then the 1 1/4" nut off it takes about 10 minutes.
    Platinum Hyundai Tech, ASE Certified Master Tech, L1 Advanced Engine Performance Specialist, ASE Certified Master Engine Machinist. Over all Gold medalist of the 2011 Hyundai Motors World Skill Olympics #1 Hyundai tech in the world!
    Newbie ultramag has not yet proved knowledgeable
    Oct 2004
    manitoba, canada
    25
    Question Re: Rear wheel bearings
    does anyone know the torque specs. for the hub nut on my 02 gt??
    Indiana
    11,228
    32mm. Same as the Accent nuts. I know.
    Oct 2004
    Redondo Beach, Ca
    4,862
    That's the strangest torque spec I've ever seen bob!
  18. #16
    Indiana
    11,228
    Nut size numbnuts!
  19. #17
    Newbie Forever silet can identify a wrench
    Poughkeepsie, NY
    887
    148 to 192 ft-lbs
    05 Tidal Wave GLS ---Lemon 02 Black GT --- RIP 03 Rally Red GT
  20. #18
    Indiana
    11,228
    Quote Originally Posted by silet View Post
    148 to 192 ft-lbs
    That means "Big Impact" tight.
  21. #19
    Quite.
    That reminds me; I need to get a new impact gun. Mine went tits up.
  22. #20
    EXD Pro Member NY2002ElantraGT has not yet proved knowledgeable NY2002ElantraGT's Avatar
    Oct 2005
    Long Island, NY
    4,550
    i posted a step by step thread with pics wheni changed my rear hub assembly
    Rock Out With Your Cock Out!
    Garage ............ OCTOBER COTM ........... CrookedH Oct COTM ............ MYSPACE
