front rotors 2003 elantra
Results 1 to 7 of 7
Thread: front rotors 2003 elantra
    Newbie andy119 has not yet proved knowledgeable
    Apr 2007
    pittsburgh, pa.
    1
    Question front rotors 2003 elantra
    Want to change pads and rotors . rotors seem to be difficult to remove, any suggestions? I also have a couple of lug nuts that may be galded up. Is this a common problem on these cars. The lug nuts have the plastic rings that hold the hubcap on can these be purchased anywhere on line?
    Feb 2006
    Thomaston, CT
    5,781
    Default Re: front rotors 2003 elantra
    http://www.elantraxd.com/forums/showthread.php?t=221043 lb. sledge hammer. Read this thread. A lot of how to remove talk in it.
    EXD Pro Member NY2002ElantraGT has not yet proved knowledgeable NY2002ElantraGT's Avatar
    Oct 2005
    Long Island, NY
    4,550
    This thread is more helpful
    http://www.elantraxd.com/forums/showthread.php?t=22706
    i dont have steelies so i dont know about that, but i know ur gonna be cursing Hyundai when you do the front rotors!
    Rock Out With Your Cock Out!
    Garage ............ OCTOBER COTM ........... CrookedH Oct COTM ............ MYSPACE
    Feb 2006
    Thomaston, CT
    5,781
    Right^^ Sorry, that's the one I was thinking of. Either way they were the same rotors in 2 diff threads.
    Poster God Tx_boy can identify a wrench Tx_boy's Avatar
    Apr 2006
    Phoenix, AZ
    1,311
    The rear ones on the GT suck cause you have to twist the piston as it goes in so be hopeful you have a GLS.
    2011 Sonata SE
    Shimmering White
    6K HID
    Stock but Beautiful!!!
    Tannersville, PA
    12,884
    ^ actually if you pop the top on the brake fluid resivior (sp duh?) they goi right in because the pressure is relieved...its not a big deal...as long as you have the tool of coarse...
    yeah a three lbs sledge from the back side and some heat would help as well...
    the steelies you can get off just by beating on the tire with a rubber mallet (i had to do this when i took my wifes car in for some tires...the owner came up and saw that i was having trouble...he litterally grabbed the largest rubber mallet...probably about 3lbs and whaled them...they popped right off and then i put some anti sieze on the back side of them so hopefully it doesnt happen again.
    Apr 2006
    Phoenix, AZ
    1,311
    Ya after the fact that I found out you needed that damn tool. I dont know why they would put those stupid rotating pistons on the rear brakes!
    2011 Sonata SE
    Shimmering White
    6K HID
