Universal Wideband O2 Kits
Results 1 to 4 of 4
Thread: Universal Wideband O2 Kits
    Car
    I need an XD, hook me up!
    May 2005
    Mahanoy City, PA
    6,583
    Default Universal Wideband O2 Kits
    This is a thread in regards to the available wideband O2 sensor kits available on the market. These come in handy when tuning your ride, optimizing the air/fuel ratio for better performance, and even fuel economy.
    Basic Information:
    14.7 is considered stoichimetric (perfect)
    The higher the number, the Leaner the Air/Fuel is.
    The lower the number, the Richer the Air/Fuel is.
    AEM Gauge-Type Wideband UEGO Controller
    Webpage
    A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
    Features:
    Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
    Does not oscillate AFR reading like narrow band sensors
    No laptop required for monitoring!
    Bosch sensor included
    Accurate to 0.1 AFR
    Reads in AFR or Lambda via a switch in back of gauge housing
    24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
    Integrated three-digit display reveals AFR or Lambda in real time
    User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
    Serial data stream included for output of AFR (RS 232)
    NGK Powerdex AFX
    Webpage
    NGK Spark Plugs (USA), Inc. is introducing its new Powerdex AFX Wideband Air-Fuel Ratio Monitor for the performance aftermarket. This product meets the increasing demand in the market for precision air-fuel ratio monitoring tools.
    Traditionally these types of tools commanded price tags that could only be justified by professional race teams and engine specialists. As technology advanced, many low-cost air-fuel ratio products emerged. Some used actual wideband sensors while others simply read OE style narrowband oxygen sensor signals and attempted to convert them to linear readouts….often with marginal success.
    The AFX Air-Fuel Ratio Monitor offers the most affordable wideband system to date. A flexible and rugged system complete with everything needed to get you tuning. The kit comes with a digital display control module, 13’ wiring harness, wideband air-fuel ratio sensor, exhaust boss and plug, and a comprehensive tuning manual. The tuning manual includes installation instructions and contains a detailed guide to performance air-fuel ratio tuning.
    The AFX measures and displays air-fuel ratio (AFR) from 9.00 to 16.00. It demonstrates superb response and accuracy within 0.1 AFR. The air-fuel ratio information can then be utilized by the user to make fuel delivery adjustments to the vehicle’s carburetor, mechanical fuel injection, or programmable electronic fuel injection system. The desired air-fuel ratio can be achieved depending on the performance requirements of the engine or race application. This is an exceptionally useful tool for carbureted engines, where there is a lot of freedom in tuning as well as a great need for proper adjustment.
    Innovative Motorsports LC-1 Wideband Controller
    Webpage
    The LC-1 Lambda cable is a complete wideband controller built in to a sealed cable. It features the same award-winning patented digital measurement principal found in the LM-1, and includes digital input, output, and 2 user programmable analog outputs.
    The LC-1 is more accurate than conventional designs costing many times as much, and its self-calibrating circuitry can compensate for changes in temperature, altitude and sensor condition. The LC-1 is ideal for applications such as Dynos, Data Acquisition, Standalone ECUs, piggyback fuel controllers, OBD-II software or chip programmers, and gauges. With the LC-1, you can add additional wideband channels to your LM-1, convert an existing narrow-band gauge, or add wideband capabilities to your dyno. You can even tune individual cylinders by using multiple LC-1 kits.
    Features:
    Only fully digital wideband controller.
    Auto calibration capability to compensate for changes in temperature,
    altitude, and sensor condition.
    Two user programmable analog outputs.
    Permanent install applications
    Cost effective individual cylinder tuning.
    Easy to upgrade.
    Includes LogWorks software
    Follow me at Twitter - @BallisticTorch
    Elantra XD
    Car
    S13 Coupe, 1999 Hyundai Tiburon 5 speed
    Jun 2005
    Eastern Shore, MD
    12,621
    Default Re: Universal Wideband O2 Kits
    Very Good job.
    2002 Hyundai Elantra: Sold
    1992 Toyota MR2: Sold
    Car
    May 2005
    Mahanoy City, PA
    6,583
    PLX Devices, Inc. M-300 Wideband Controller
    Webpage
    Bosch controller with display. Wideband Air/Fuel Controller (UEGO) with 4 digit digital display readout.
    Features:
    Simple wideband air/fuel ratio gauge setup
    Stand alone engine management system interface
    Piggyback fuel system interface
    Interface with data loggers
    Stock narrowband sensor replacement
    Zeitronix Wideband Air/Fuel Meter
    Webpage
    No matter if you have a stand alone engine management system or a piggy back fuel control, the Wideband Air Fuel Ratio Meter is a must for a serious tuner! Finally you can tune for more power, closer to the edge, precisely monitoring Air/Fuel ratio Boost, EGT, RPM and throttle position datalogging up to 9 hours of data with a blazing rate of 74 samples per seconds per graph.
    Fully digital, smallest Wideband O2 controller in the world!
    Zt-2 is about the size of 1" thick business card.
    Extremely compact design for installation where space is a premium.
    Zt-2 Specs
    0.1 AFR accuracy
    Operating voltage 10V to 18V
    Switching power supply for oxygen sensor heater
    Precise sensor temperature control
    Reverse polarity protection
    Integrated fuse
    Flexible Plug and Play Sensor Harness with a small, easy to route through the fire wall, connector
    Wideband Oxygen Sensor included
    Easy to install plug and play kit
    Adjustable Narrowband Switching Point
    Warning Alarms and Triggers
    Inputs/Outputs:
    Bosch Wideband O2 sensor
    Linear Wideband Output AFR=Vx2+9.6
    Nonlinear Wideband Output
    Serial data output to the Zeitronix Wideband LCD Display
    Serial data output for real time datalogging (PC laptop required)
    RPM Input ( tachometer or primary side ignition coil input).
    The RPM input works in any car and any ignition system. No additional adapters needed!
    Simulated Narrowband Output to feed a stock ECU
    Throttle Position Input
    Boost Sensor Input
    EGT Probe Input
    User Input/Warning Output
  5. #4
    Car
    2002 Elantra GT 5 door
    Oct 2005
    Long Island, NY
    4,540
    i love the AEM UEGO! possibly doing that in the next week or so!
    Rock Out With Your Cock Out!
    Garage ............ OCTOBER COTM ........... CrookedH Oct COTM ............ MYSPACE
