Removing driver's side window switch assembly?
Results 1 to 8 of 8
Thread: Removing driver's side window switch assembly?
    Newbie redmond1501 has not yet proved knowledgeable
    Jul 2007
    Boston, MA
    2
    Default Removing driver's side window switch assembly?
    How do I remove the driver's side window switch assembly? Do I need to remove the door panel or does the assembly pop out?
    -I tried just prying the switch assembly out with the door panel in place, but the assembly feels like it's locked in place with a backplate.
    -If you do have to remove the door panel, how is that done? I tried removing all of the door trim screws and the triangular panel behind the mirror, but the door trim wouldn't budge. Do I need fully undo the door latch as well (I only removed the screw holding the trim on it ).
    Thanks for your help.
    Near Chicago, IL
    15,223
    Default Re: Removing driver's side window switch assembly?
    Yes, you need to remove the door panel.
    There are 2 screws on the side of the door, near were the door meets up with the B pillar when the door is closed.
    There are 2 screws underneath covers below the grab-handle of the door.
    There is the screw where the interior handle is as well.
    Also check that there are no screws on the bottom - it's been a while since I've had mine apart.
    After removing all these screws, you can pull the door panel off. There are a few "clips" that hold it on even after the screws are all out, so you will need to pull gently.
    Be careful you don't pull too far, because there are wires attached to that door panel that run into the door.
    EDIT:
    Use this DIY: http://www.elantraxd.com/DIY/doorpanel.php
    • Future: ????
    Jul 2007
    Boston, MA
    2
    Thanks!
    Near Chicago, IL
    15,223
    Make sure you see my edit with the DIY in the post.
    • Future: ????
    EXD SupaMod Ugzz knows a lot about Elantras Ugzz's Avatar
    May 2006
    Pittsburgh
    9,870
    ^what edit?
    Internet Jesus is not pleased with the absense of the chatbox.
    And he stated, "let the people speak, and I shall grant thee speed". Microsoft Sam 11:17
    Veni, Vidi, Velcro Munky has information that can be trustedMunky has information that can be trusted Munky's Avatar
    May 2006
    Noblesville, IN
    10,969
    Quote Originally Posted by Ugzz View Post
    ^what edit?
    He edited his post and added the link to the DIY.
    May 2006
    Pittsburgh
    9,870
    Ohhh i see. i thought he was saying he edited the diy itself and i didnt notice anything changed
    all clear
    Newbie acw8609 has not yet proved knowledgeable
    Jul 2012
    Boston, MA
    1
    Sorry to dig up a really old thread, but I'm trying to go through this process now to clean out the switch contacts (the master switch on my car no longer works for the passenger side front window) and having some trouble.
    I took off the door panel but then I had no idea what to do from there. It wasn't clear on the underside of the switch assembly how to remove it. There are 2 clips, but even pushing them in didn't allow me to push the assembly out without a great amount of force (and I was afraid of breaking it).
    Any ideas? Thanks much.
