I can't get to a dealer until sometime next week but according to an Autozone Computer I got Code p0010 which has something to do with the Cam Shaft. My check engine light is on (which is why I connected the computer). What is the common problem of this and am I in danger by driving it for the week? Glad I found this forum!
if so its more then likely the back cam sensor...its right behind the oil fill on the vavecover...just below it anyway...1 10mm bolt and it pops out....although you cant clear the code...should be covered under warranty....
and your not in danger all it means is that the cvvt is suspended if you have an xd2
to tell if it has cvvt look at the front of hte motor...there will be wires coming out from underneath the cover on the right side and if you have a Mass Air Flow senor not a MAP sensor
Although a n00b HERE I am a forum junkie since '94 so I know about the searching and if you don't find search more mentality. I couldn't find if it was DANGEROUS so that is my main reason for posting.
thanks all....
Also the battery seemed to be crapping out so i am going to throw a new one in there today -
Not ALL late model 03's were CVVT..only a portion of them.
So don't sit here and pretend to know everything.
And if you pay attention to the posts I referenced, they asked what year and model he had. Nothing to do with whether or not it was a CVVT. There was a seperate post explaining on how to tell whether or not his engine was in fact a CVVT.
i was right in the fact that even though not ALL late model 03 are dvvt....you still have to ask because it could be and there for a different issue, like the oil control valve for the cvvt.
then its just the came sensor....it should be covered under warranty
