cost to replace radiator?
Results 1 to 12 of 12
Thread: cost to replace radiator?
    Newbie BIGp has not yet proved knowledgeable BIGp's Avatar
    Dec 2004
    new jersey
    30
    Default cost to replace radiator?
    hello all.
    I have a 02 elantra gls ....no warranty..........
    I have a small crack on the top plastic part of the radiator.will the entire radiator have to be replaced? i think it will.
    what can i expect to pay for parts and labor for this job?
    thanks.........bigp
    May 2005
    Mahanoy City, PA
    6,582
    Default Re: cost to replace radiator?
    Are you leaking radiator fluid? Are you overheating?
    Just wondering. Yes, you'll need to replace the whole radiator. If you are mechanically inclined, you can do this yourself in about an hour. As far as rates and such, most places charge $70 to $80 an hour for labor, plus parts.
    Poster God mtlelantra knows a lot about Elantras mtlelantra's Avatar
    Oct 2004
    San Francisco Bay Area
    1,947
    I dunno about how well the hyundai radiator would hold up and how big of a crack it is, but I had two 1 inch-long cracks on the plastic top of my old 89 Civic radiator which I repaired and had it last 5 years until I sold the car.
    I drained the fluid a bit, widened the crack a bit with an Xacto knife, taped off about a 1/2" section surrounding the crack, sanded the section, degreased and cleaned it. Then I used steel epoxy (I forget which kind but not the JB weld stuff cuz glycol eats through it) to fill the widened crack and coat the sanded section. I laid a piece of fiberglass cloth that was about a 1/4" surrounding the crack in size over the crack into the still wet steel epoxy and added a bit more epoxy to saturate the cloth. I let that dry, sanded it smooth, cleaned and degreased and then put another layer of steel epoxy to cover the whole 1/2" surrounding area, laying as smooth a top layer as humanly possible.
    2004 Hyundai Elantra VE 2.slow
    One of the few 138 HP ULEV XD2s in California.
    Dec 2004
    new jersey
    30
    yes, it is leaking coolant.
    the crack is about 1/4" going top to bottom.(pretty small)
    i can see it seeping out when the coolant is warm.
    it's on the front middle section of the plactic, near the cap.
    i was also thinking aboutsome kind of bonding material.
    it seem like a pain in the butt to do it myself.
    should i get an oem radiator?
    Oct 2004
    1,947
    It's a bit of work to try to seal it up, but for $10 in supplies you should give it a try before shelling out $whatever for a new rad.
    EXD Pro Member zx2uner has not yet proved knowledgeable zx2uner's Avatar
    Jun 2005
    Fargo, North Dakota
    2,058
    Quote Originally Posted by mtlelantra View Post
    I would make sure to clean it up...then scratch the surface a little with sandpaper, and JB Weld it. Worth a try then buying a new one.
    Thanks for being a knowitall Alex.
    Oct 2004
    1,947
    Quote Originally Posted by zx2uner View Post
    You didn't read my 1st post. Don't use JB weld cuz antifreeze eats it. There's another brand of steel epoxy... I just forget the name... if I remember it, I'll post it up.
    You also have to reinforce it with something like fiberglass.
    Jun 2005
    Fargo, North Dakota
    2,058
    I read it... I don't know how fast it eats it....my ZX2 still doesn't leak after 2 years. Anyway, I know Quiksteel works for it too.
    Senior Member 2001VE has not yet proved knowledgeable 2001VE's Avatar
    Apr 2007
    Newmarket,ONT, Canada
    535
    If you are going to keep the car for a while ; switch to a copper tank rad if possible. A bit more money but they seem to last a bit longer in my opinion.
    Dec 2004
    new jersey
    30
    thanks everyone!
    I will take a look in autozone and see what they got.
    worth a try!
    big p.........................
    Jun 2005
    Fargo, North Dakota
    2,058
    ebay? aftermarket for $100....
    Dec 2004
    new jersey
    30
    Well, after a closer exam, what i thought was a seam, turned out to be a 9"
    horizontal crack on the front part of the black plastic piece.
    $480.00 plus tax to replace radiator.........oh well........
Similar Threads
  1. Cost to replace struts
    By jetskiscott2 in forum Suspension/Brakes/Drivetrain
    Last Post: 11-03-2007, 07:24 AM
  2. Replies: 5
    Last Post: 05-24-2007, 04:07 PM
  3. ****ty Plastic Hyundai Radiator
    By Josh K in forum Help!
    Last Post: 02-08-2007, 10:52 PM
  4. Around how much would it cost to get brake pads changed?
    By ArunSenior04 in forum New Member Checkpoint
    Last Post: 07-15-2005, 02:26 AM
  5. Replies: 17
    Last Post: 03-18-2005, 08:39 AM
