P0455 Code
Results 1 to 10 of 10
Thread: P0455 Code
    KWP Services kwpservices has not yet proved knowledgeable
    Dec 2007
    Oakville
    37
    Question P0455 Code
    I keep getting a P0455code - "Evaporative emission (EVAP) system large leak detected Hose connection(s), intake leak, EVAP canister, EVAP canister purge valve" - am wondering if buying a new gas tank cap might be the answer. Have a sneaking suspicion it may have a hairline crack or be damaged.
    Would appreciate any thoughts-feedback.
    Cheers
    Kate
    Jun 2005
    Eastern Shore, MD
    12,635
    Default Re: P0455 Code
    I'd say its either the evap canister or the purge valve on the back side of the intake manifold.
    2002 Hyundai Elantra: Sold
    1992 Toyota MR2: Sold
    Oct 2004
    Redondo Beach, Ca
    4,862
    You can guess all you want, but without a smoke test, it would be hard to tell.
    Jun 2005
    Eastern Shore, MD
    12,635
    I know that, but they asked for thoughts
    Oct 2004
    Redondo Beach, Ca
    4,862
    I know. I was giving the OP my thoughts.
    Oct 2005
    Fort Worth, Texas, USA
    3,332
    Inspect around the canister (left rear of car, behind the rear wheel). See if there is an obvious cracked or loose hose.
    Tannersville, PA
    12,884
    sounds stupid...but i see it all the time...did you fill the car up while it was running? or not tighten the gas cap down?
    if i were you i would clear the code and if it comes back then perform a leak test of hte evap system.
    start there....
    Dec 2007
    Oakville
    37
    start there....
    Thanks so much for the tip. HTE =??? -I'm still building my knowledge glossary Thanks again - I'm envious - Florida huh? it's -14 here with a windchill of -24 yuch! Cheers, Kate
    Tannersville, PA
    12,884
    it not much better here in the shop its 50 with a windchill of about 40...being as it was about 80 two days ago...its chilly!!
    hte....is just me mispelling ****....you'll get used to it...hahaha
    LeSabres not sharp. sciphi has not yet proved knowledgeable sciphi's Avatar
    Feb 2007
    West Columbia, SC
    484
    If it's not anything they listed above, get out your wallet. It starts with the smoke test and goes up from there.
    Everything is good in moderation. Including moderation.
    RIP Elantra 12/2007
    Replacement: 1999 Buick LeSabre, one quick couch
Similar Threads
  1. Elantra Color code by year
    By ilanpro in forum Appearance
    Last Post: 01-29-2014, 07:59 PM
  2. Replies: 10
    Last Post: 09-11-2009, 05:17 PM
  3. New to Hyundai... engine ID code?
    By NOFX in forum Naturally Aspirated
    Last Post: 09-10-2006, 01:02 AM
  4. Getting nowhere with a P0302 code...
    By TheBlatt in forum Help!
    Last Post: 08-05-2006, 10:31 PM
  5. map sensor CEL code 105
    By skeetre in forum Forced Induction and Nitrous
    Last Post: 05-18-2006, 12:25 AM
