Throwing code p0032
Results 1 to 13 of 13
Thread: Throwing code p0032
    EXD Pro Member PSUsouthpaw knows a lot about Elantras PSUsouthpaw's Avatar
    Nov 2005
    Mahanoy city, PA
    3,018
    Default Throwing code p0032
    P0032 Heated oxygen sensor (HO2S) 1, bank 1, heater control circuit high Wiring short to positive, HO2S, ECM
    I used to have p0038 due to my second o2 sensor residing in my glovebox, but I extended the wires last night. I've had this for a week and don't seem to be having any success...any idea whether this is
    1. Wiring problem
    2. o2 sensor failure
    3. gremlin
    4. User error?
    2004 Elantra: To many mods to fit in a signature. Entering modding retirement fairly soon.
    1995 Monte Carlo: 3.8 SC Weekend Warrior
    1985 Pontiac Fiero: Has migrated to my backyard. Just one or two pieces away from being inspectable!
    A.K.A. ItalianSausage SilverElantra knows about Elantras SilverElantra's Avatar
    Apr 2006
    Concord,California
    4,131
    Default Re: Throwing code p0032
    if the curcuit is high that means you might have a little bit too much solder on the wire making the voltage spike higher than it should.
    Tannersville, PA
    12,884
    ^ what are you talking about??? you could use a roll of solder and it wouldnt change the amount of voltage going to it. the wire itself is where the resistance is...
    back to the problem at hand.
    replace the front 02 sensor, or you ****ed up the wiring....its only four wires though....
    Nov 2005
    Mahanoy city, PA
    3,018
    Its been fine for the last year and than all of sudden last week it started throwing this code, thats why I'm confused.
    I wasn't the one who extended the wiring on this o2 sensor though...in fact Derek, I think you were present when that header went in last year...
    Jun 2004
    Bellevue, PA
    3,538
    Then it could be that the wiring extension is loose, or that the sensor is finally going bad. The two white wires (I think they're white -- whichever two are the same color) are the wiring for the heater in the sensor. There should be some resistance across those two plugs on the O2 sensor. If there's no continuity between the two white wires on the sensor, then the heater is burned out.
    I'd make sure you have continuity for each wire to both sides of the extension wiring, too.
    That's about the limit of my diagnosing suggestions, short of getting a new O2 sensor, installing it and seeing if the code clears.
    665 -- Neighbor of the Beast.
    Senior Member 2001VE has not yet proved knowledgeable 2001VE's Avatar
    Apr 2007
    Newmarket,ONT, Canada
    535
    The set of wires for the heating element should show battery voltage with the key on. The other set is the signal going back to the ECM and is usually very low voltage. Most I believe use 1.0 volt as the center position. That means with the car running the meter should show above and below 1.0 every couple of seconds for NO CODE. If it just shows 1.2 volts or more all the time then it is stuck high--new sensor needed.
    Apr 2006
    Concord,California
    4,131
    what about as i posted in my thread that nobody posted in po131 where sensor voltage is reading low.
    i threw codes po131 and po140
    po131 is low voltage circuit bank 1 sensor 1
    po140 is cat efficiency
    02GT Black Loopy Chipmunk has not yet proved knowledgeable Loopy Chipmunk's Avatar
    Brampton, Ontario
    62
    I had the same problem 2 weeks ago (P0032 Heated oxygen sensor). I stopped by my mechanic and he cleared and said it wasn't anything to worry about but to keep an eye on it and let him know. Well 2 days later it returned so i let him know but i couldn't make it back to the shop. A day after that, it cleared all by itself and has not come back. This happened during some really cold weather, not sure if that has anything to do with it. Just hoping it stays off.
    Jun 2005
    Eastern Shore, MD
    12,635
    could be the heating element in ur sensor is going bad.
    2002 Hyundai Elantra: Sold
    1992 Toyota MR2: Sold
    Tannersville, PA
    12,884
    oh yeah it was at my house!! hahah
    replace the 02 sensor.
    Apr 2006
    Concord,California
    4,131
    ^^^who is this directed to?
    Nov 2005
    Mahanoy city, PA
    3,018
    Right than, I'll pick up an o2 sensor tomorrow and hopefully have time on Sunday to wire it in.
    SWEET! Wasn't the O2 sensor after all, but a wire that got ripped/broken somehow. Saves me quite a few $$$. And no CEL for my headers altogether now. WOOT!
    Apr 2006
    Concord,California
    4,131
    will it be ok for me to wled the bung for my o2 sensor right before the flex pipe? ive never heard of there being any problems but im sure if one was to happen it would be to me.
Similar Threads
  1. Elantra Color code by year
    By ilanpro in forum Appearance
    Last Post: 01-29-2014, 07:59 PM
  2. Replies: 10
    Last Post: 09-11-2009, 05:17 PM
  3. New to Hyundai... engine ID code?
    By NOFX in forum Naturally Aspirated
    Last Post: 09-10-2006, 01:02 AM
  4. map sensor CEL code 105
    By skeetre in forum Forced Induction and Nitrous
    Last Post: 05-18-2006, 12:25 AM
