where is the PCV valve?
Results 1 to 9 of 9
Thread: where is the PCV valve?
    Newbie cynick has not yet proved knowledgeable
    Feb 2008
    Toronto, Ontario
    36
    Default where is the PCV valve?
    I can't find the PCV valve for my Elantra '05
    Is it just a hose? And if so, do I need to replace it?
    I've read somewhere people are installing filters/catchers on that hose. Has anybody done this?
    For example:
    http://elantragtclub.tripod.com/site...tures/pvc8.jpg
    http://elantragtclub.tripod.com/elantra/id405.html
    i'm focused man. theWorst has not yet proved knowledgeable theWorst's Avatar
    Jun 2006
    Hoodbridge, VA
    887
    Default Re: where is the PCV valve?
    it runs from your IM to your engine cover ( you have to remove the plastic cover to see it )..
    the valve is a brass valve...
    i replaced mine for $3 at autozone.. but everyone says you can just soak it in brake cleaner and it'll be good as new.
    yep.. alot of people have put catch can's on the pcv line... and on the breather line also.
    twigs? no... delicious? yes.
    Feb 2008
    Toronto, Ontario
    36
    I see.. it is on the pcv line, attached to to the valve cover, and covered in a black hose.
    nice
    So how do I remove it? Remove the hose attached hose and then the hose that covers it and then? How much force do I apply or do I twist it somehow?
    Hyundai FTW. 2002 GLS has picked up a wrench 2002 GLS's Avatar
    Jun 2007
    Upstate, NY
    1,418
    Cool Re: where is the PCV valve?
    Wow... that is clean!
    2005 Hyundai Xg350L, 2002 Hyundai Elantra Gls-Stolen, 1989 Mercury Cougar LS
    Both Hyundais and the cougar are long gone. Back to domestic for now...
    Looking for 96-99 V8 Explorer AWD.
    Jun 2006
    Hoodbridge, VA
    887
    you just unscrew it with a wrench... it should break loose easily..
    i turned mine the wrong way about half a turn... then when i realized i was going the wrong way (because you should turn it counterclockwise, as if you were standing from the other side.. lol)
    it broke free with about 40lbs of force.. not much.
    Feb 2008
    Toronto, Ontario
    36
    Thanks! I'll try that
    Actually this is a picture I got from the links above, not my actual car unfortunately
    Poster God mlumz has not yet proved knowledgeable mlumz's Avatar
    Mar 2005
    NJ
    1,579
    what is the interval change for the pcv valve?
    A.K.A. ItalianSausage SilverElantra knows about Elantras SilverElantra's Avatar
    Apr 2006
    Concord,California
    4,131
    30k miles.
    Newbie SeanK137 has not yet proved knowledgeable
    Mar 2005
    Chantilly
    2
    Bringing up an old thread....
    I'm trying to replace the PCV valve on a 98 elantra. I've read through the forum post, and looked at the pictures but still am not sure where it is. Is it actually in a hose? I've looked at HMAservice.com, and scoured the internets but still no luck. Any help would be greatly appreciated.
    Thanks,
    Sean
Similar Threads
  1. Official Check Engine Light (CEL) thread
    By Haiduc in forum Help!
    Last Post: 07-20-2014, 02:10 PM
  2. Replacing PCV valve: Is it necessary?
    By tomahawk in forum Do It Yourself Section
    Last Post: 03-25-2008, 03:20 AM
  3. Where do I find the PCV valve
    By medicm in forum Help!
    Last Post: 02-19-2007, 11:49 AM
  4. Air Ram Intake Manifold, How You Guys Rigged Idle Air Control Valve...?
    By Mahonroy in forum Forced Induction and Nitrous
    Last Post: 10-19-2006, 09:32 PM
  5. Question About Forge Diverter/Dump Valve...
    Last Post: 05-12-2004, 08:59 PM
