HELP! 2001 Hyundai Elantra Codes, How To Fix!!??
Results 1 to 9 of 9
Thread: HELP! 2001 Hyundai Elantra Codes, How To Fix!!??
    Default HELP! 2001 Hyundai Elantra Codes, How To Fix!!??
    my 2001 hyundai elantra runs fine, then decides to die out, then it wont start for a while, then runs fine a day or two then die. i bought a scanner and these 9 codes came up. (its 4 cylinder, 5 speed.)
    P0301 (cylinder 1 misfire) (generic code)
    P1440 (EVAP system vent circuit malfunction) (manufacturer code)
    P0443 (EvaPorative emission system purge control valve circuit) (generic code)
    P0303 (cylinder 3 misfire) (generic code)
    P0304 (cylinder 4 misfire) (generic code)
    P0302 (cylinder 2 misfire) (generic code)
    P0300 (random misfire) (generic code)
    P0507 (idle air control system RPM higher than expected) (shows up 2 times) (generic code)
    all codes show up in this order, i dont know where to start. what should i fix first? could one thing be the cause of the other codes? whats wrong? any help would be greatly appreciated.
    any one knows how to help?????
    Hyundai FTW. 2002 GLS has picked up a wrench 2002 GLS's Avatar
    Jun 2007
    Upstate, NY
    1,418
    Cool Re: HELP! 2001 Hyundai Elantra Codes, How To Fix!!??
    Holy cow. wish i could help you, but have no idea. maybe bump for some ideas lOl.... Welcome to the forums. I wanna say something with the spark plugs and wires?
    2005 Hyundai Xg350L, 2002 Hyundai Elantra Gls-Stolen, 1989 Mercury Cougar LS
    Both Hyundais and the cougar are long gone. Back to domestic for now...
    Looking for 96-99 V8 Explorer AWD.
    Jun 2005
    Eastern Shore, MD
    12,635
    Default Re: HELP! 2001 Hyundai Elantra Codes, How To Fix!!??
    Well, looks like you're boned.
    2002 Hyundai Elantra: Sold
    1992 Toyota MR2: Sold
    Sparta, NJ
    6,437
    bad gas.
    MySpace/Facebook
    Keyan.
    You are my ****ing hero.
    any more suggestions?
    Senior Member 2001VE has not yet proved knowledgeable 2001VE's Avatar
    Apr 2007
    Newmarket,ONT, Canada
    535
    Vapor lock from evap problem? When it dies removed the gas cap and try to restart car again. If it starts right up there is a venting issue. Bad gas ;water in gas also possible , add isopropyl alcohol , may be hard to find where you are, its gas line anti-freeze. Removes water quite well. Also try to check fuel pump pressure.
    Plug fouling can cause misfires. I'd pull the plugs to look at them and if it has been a while since they were replaced, replace them. Plug wires also can cause misfires.
    Once the misfires are corrected, look at the evap system. The purge control valve can be bad as well.
    7 psi tunned by poweraxel Matrixloader has picked up a wrench Matrixloader's Avatar
    Jul 2006
    san diego, California
    3,203
    thats way to many missfires all at once dude, i am going to say that it sounds like your coil pack took a crap on you.
    I would replace the coil pack first before doing anything else.
    When I die, I want to die like my grandfather–who died peacefully in his sleep. Not screaming like all the passengers in his car.
    DIY : Paint Bezels and turn signals Black. http://www.elantraxd.com/forums/showthread.php?t=28188
    Quote Originally Posted by Matrixloader View Post
    Might not be a coil pack. I might suspect it if 2 misfires (1, 3 or 2, 4) but not all of the cylundars. Since there are evap codes also, I first would look into fouled plugs or why the plugs fouled in the first place. Since the evap system vent system is malfunctioning, I would think that there is too much pressure in the fuel system, which can add pressure behind the injectors and possibly add too much fuel than needed (and possibly at the wrong time).
Similar Threads
  1. 2008 Hyundai Elantra Press Release - New Trim Levels
    By SuperGLS in forum Other Cars & Car News
    Last Post: 07-18-2007, 08:18 AM
  2. $5,500 - 2001 Hyundai Elantra GLS 43200mi
    By DL01elantra in forum Marketplace
    Last Post: 07-03-2007, 03:37 PM
  3. !!!!!2001 Elantra dual or tripple guage pod!!!!!
    By Elantra2nr in forum Interior
    Last Post: 09-12-2006, 09:11 AM
  4. Replies: 0
    Last Post: 06-29-2004, 12:24 AM
