Loud Popping sound!!!
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 28
Thread: Loud Popping sound!!!
    Junior Member wolfemanXD has not yet proved knowledgeable wolfemanXD's Avatar
    May 2005
    Ashland,Ky
    162
    Default Loud Popping sound!!!
    It started making a poping noise when I turn my car left only. It only did it a few times but now every time I only turn left It make a "pop" noise. It kind of sounds like a motor mount or bearing not for sure. What steps should I go thought to eliminate whats making the noise, o and by the way I'm going on a 500mile drive in 2 days. Think it can make it?
    SILVER BULLET
    Default Re: Loud Poping sound!!!
    did ya check the CV axle? check the rubber boots, one could be ripped and letting road **** get in and causing the axle to prematurely fail.
    http://www.elantraxd.com/cotm/april07.php
    "President Obama to increase the tax on aspirin by 40%... due to the fact it is white, and it works."
    Oct 2004
    Redondo Beach, Ca
    4,862
    Is it a continuous popping noise? Or a single pop? I'm thinking ball joint.
    May 2005
    Mahanoy City, PA
    6,582
    ^ Agreed.
    To check the ball joint, lift the car on jack stand(s). Then use a pole or pry bar, placing it under the tire. Lift the bar upwards and watch the ball joint. If there is more than a 1/4" of play (which is actually way too much anyway), you've got a problem there. If it is tight, no play, then it could be other things.
    Inner/Outer tie rod, CV Axle, etc. CV axles tend to make clicking noises though, not popping. So like ricer said, it's probably your ball joint.
    Jun 2005
    Eastern Shore, MD
    12,635
    Ball joint was also my first thought when I saw the title.
    2002 Hyundai Elantra: Sold
    1992 Toyota MR2: Sold
    Oct 2004
    Redondo Beach, Ca
    4,862
    Actually, when I first saw the title, I thought he was getting yelled at in the Vatican...
    mine makes a "popping" noise when i go in reverse and turn. either direction, no matter how slow or fast... obviously faster makes it worse, but it happens regardless.
    Default Re: Loud Popping sound!!!
    Is it when turning the steering wheel left or while actually driving on a left turn. If it's just while turning the wheel, I'd say dry BJ or outer tie-rod. If it's while driving on a left turn, definitely CV!
    Check out my 02 GLS:
    mine pops whenever i drive in reverse and turn the wheel. if im driving straight in reverse, nothing happens, but as soon as i start turning teh wheel, it satrts popping, n gets worse the further i turn it, in both directions.
    Quote Originally Posted by Pete03GLS View Post
    CV axle/s!
    well, im goin to my dealer this saturday, so they better fix it.
    Quote Originally Posted by ricerrx7 View Post
    Hahahaha!
    Oct 2004
    Redondo Beach, Ca
    4,862
    Quote Originally Posted by DJ Hellfire View Post
    I'd say dry BJ
    There's nothing worse than a dry BJ...
    May 2005
    Ashland,Ky
    162
    It does it only when im driving and turn left. How much would it cost to have it fixed if it is the ball bearing?
    SILVER BULLET
    Veni, Vidi, Velcro Munky has information that can be trustedMunky has information that can be trusted Munky's Avatar
    May 2006
    Noblesville, IN
    10,969
    It sounds like the CV axle to me. But it very well could be a ball joint too.
  18. #16
    EXD SupaMod Ugzz knows a lot about Elantras Ugzz's Avatar
    May 2006
    Pittsburgh
    9,870
    I had what started as a popping sound when making a left, then after not getting it fixed it turned into a constant popping when turning. i ended up needing both the cv and ball joint. once they were fixed in the long run (months later) iended up needing a new axle as well..
    that was in my sable, which i had wrecked not long before. after that endever it started spitting axles every month or so, so i traded it in for 1000$ and got the elantra
    Internet Jesus is not pleased with the absense of the chatbox.
    And he stated, "let the people speak, and I shall grant thee speed". Microsoft Sam 11:17
  19. #17
    Super Moderator Qyn has information that can be trustedQyn has information that can be trusted Qyn's Avatar
    Dec 2007
    Calgary, AB, Canada
    4,858
    I once thought I was wrong. It turned out I was only mistaken. Hasn't happened since.
    Like what I'm saying? Use the Rep system and let me know! You can also follow my Twitter.
  20. #18
    May 2005
    Ashland,Ky
    162
    Scary story.
    SILVER BULLET
  21. #19
    Ultimate Post Whore cbogg knows a lot about Elantras cbogg's Avatar
    Jan 2008
    Fort Edward, NY
    3,960
    dude, beat me to it. +1 for you
    From AIM:
    Me: I get a day off during the week next week, woot!
    Derek: ooooh during the week? lucky you. I'd kill someone in front of their own mother for a day off during the week.
  22. #20
    May 2005
    Mahanoy City, PA
    6,582
    When dealing with steering components on a FWD car, basically, one system affects another, and affects another. Letting whatever the problem may be go for too long, and you run into other parts, that by picking up the "slack", led to premature failure as well.
    But depending on mileage, it's always good to get new fresh stuff installed anyway, like struts every 60k miles, etc. Whatever the issue is with your car, I would suggest replacing everything, kind of. If it's the CV axle, replace the axle, and the BJ, and have everything else checked out as well. This way everything is brand new and will wear "evenly".
Similar Threads
  1. HELP - Humming sound after installing CAI
    By eclaixp in forum Naturally Aspirated
    Last Post: 05-26-2014, 11:58 AM
  2. wireless surround sound...
    By evan938 in forum Off-Topic
    Last Post: 03-01-2007, 08:29 PM
  3. Loud Air sucking sound with SRI
    By Raydee in forum Naturally Aspirated
    Last Post: 05-05-2006, 05:56 PM
  4. A hard to describe sound
    By lanzemurdok in forum Suspension/Brakes/Drivetrain
    Last Post: 04-12-2006, 06:03 PM
  5. Annoying sound with CAI cured
    By SWortham in forum Naturally Aspirated
    Last Post: 07-30-2004, 12:21 PM
