Sound deadening thread - Page 6
Page 6 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 101 to 120 of 191
Thread: Sound deadening thread
  1. #101
    Rebuilding the XD CornbreadXD knows a lot about Elantras CornbreadXD's Avatar
    dna-level-C ,OHIO
    6,253
    Default Re: Sound deadening thread
    Here are the pic updates(can this post be automerged?)
    The headliner was a PIECE OF CAKE!! FIRST TIME EVER IN MODDING! It's WAAAAAYYYY easier to remove the sunroof headliner than it is for the non sunroof and the use of velcro by Hyundai is genius
    78 Datsun 280z = Resting
  3. #102
    May 2005
    Mahanoy City, PA
    6,582
    So, how much more does your car weigh now that you've added all of this? Curious to know if you know how much you've added to the car. Not that it matters to you, as I know you don't race your car. I'm wondering also how much quieter your car will be on the inside...there should be virtually NO road noise now, except for the little bit through windows and the sunroof.
  4. #103
    Where's My Boomstick? Tommy knows a lot about Elantras Tommy's Avatar
    Aug 2005
    Rock Hill, SC
    5,486
    Deadener really isnt all that heavy.
    Even the heaviest duty stuff is about .5lb /sqft. So even with the heaviest stuff, using 200sqft, which is WAY overkill, more than enough to do every surface at least 2 layers thick, you'd only add 100lbs and it would be evenly spread across the entire car.
    Stuff i used was about .4lb/sqft, and i used maybe 40-50sq ft and it was enough to do inner and outer door skins, 2layers thick, on all of the doors.
    Kick! Punch! It痴 all in the mind
    If you wanna test me, I知 sure you値l find
    The things I値l teach ya is sure to beat ya
    But nevertheless you値l get a lesson from teacher
  6. #104
    dna-level-C ,OHIO
    6,253
    +1 Tommy, and I will be racing my car on the auto-x courses. The stuff really doesn't add too much weight because like I've said many times I weigh less than 150lbs myself so adding an extra 100lbs to the car is nothing really but i'd say i've added maybe 50lbs I've used about 80sqft of the foil stuff and 25sqft of the liquid which is only 6lbs when cured.
    I still want to spray my fenders with the liquid stuff and spray the doors to cover the foil. I also am gonna get some more foam to put under the backseat and the trunk so that'll be another 10lbs
  7. #105
    May 2005
    Mahanoy City, PA
    6,582
    That's right, I forgot how much of a light weight you are, my bad. And even if you did add 100 lbs, it's not going to affect you that much other than losing another tenth of a second, but that's in a straight line...hell, you've probably made the car much stiffer by doing this, so that'll help you out a bit.
    I bet your audio is going to sound sick!!!
  8. #106
    dna-level-C ,OHIO
    6,253
    I'll try to get a video of it tommrow because it is insane how much of a difference in the sound level in the car is compared to outside, when I open the door it's like music vomits out of the car and I haven't put the interior pieces back in so hopefully that'll keep more sound inside.
  9. #107
    Aug 2005
    Rock Hill, SC
    5,486
    I just love banging on the door and it sounding like youre hitting wood. Slam the door and its like a Benz.
    Did you cover the door panels, and other plastics with foam? If you really want sound deading, you have to do that as well. Sound deadeners work 2 ways. 1 - the mat makes the panel phyisically harder to move, so less vibrations, less noise. 2 - you need something to absorb and slow the sound waves that do occur. that's what the foam is for.
  10. #108
    dna-level-C ,OHIO
    6,253
    I'm thinking of spraying the liquid deadner on the interior panels after I scuff them with a scotchbrite pad so it sticks and then slapping the foam on, I'm still debating whether to do the floor because the foam underneath is kinda thick already and I might have an issue with putting the carpet back in. I may just cut some out of my old car and bulk the area around the shifter.
    So far I've reusued the old headliner pads from my gls, the poly stuff that was behind the dooor panles and that pad that was under the rear deck to add more OEM insulation to the car
  11. #109
    May 2005
    Mahanoy City, PA
    6,582
    Quote Originally Posted by CornbreadXD View Post
    Dude, that line is worth rep...I hope I can give you some...I've never heard it put that way before. Definitely get some vids of you driving around, and then some of you playing music loud inside the car with the doors closed (you on the outside) and then open the door so I can hear the "vomiting".
  12. #110
    Aug 2005
    Rock Hill, SC
    5,486
    The liquid deadener is just another massloader like the mat. To get the full effect, you need a massloader and an absorber.
    go to the fabric store and buy some sheets of like 1/4" inch poly foam and some spray glue. the sheets will be sold as like seat cushions or something like that.
  13. #111
    dna-level-C ,OHIO
    6,253
    yeah, I bought foam last year and still have some left over, i've read about people dunking the foam in the liquid to get some results, but the other stuff im gonna buy is 3/8" thick
  14. #112
    Aug 2005
    Rock Hill, SC
    5,486
    3/8ths is pretty thick. Might be hard to get panels to fit right afterwords.
  15. #113
    dna-level-C ,OHIO
    6,253
    oops, I meant the 3/8" stuff is what is going under my backseats and trunk, the 1/4" foam I am gonna glue to the plastic. I bought it off of a lab teacher on ebay 35sqft for like $14 crappy pic in post #70
  16. #114
    Aug 2005
    Rock Hill, SC
    5,486
    ah, gotcha.
    Yea, it makes a good difference. helps a lot with muffling any of the higher pitched rattles, lowers their frequency to something less noticeable, and then the low frequency road noise is almost stopped completely.
  17. #115
    Part-time Newbie blearyeyedme has not yet proved knowledgeable blearyeyedme's Avatar
    Nov 2008
    Palm Beach Gardens, FL
    124
    Most of you seem to be deadening the sound to help with the systems you have in your cars. But what about someone who just wants to get rid of some of the road noise and vibrations? Would you still recommend adding dynamat/second skin/etc everywhere, or are there certain places that would give me that extra bit of quiet I'm looking for? I don't figure I'll need to do the trunk, but probably the front floorboards, maybe the front doors. The firewall? Thoughts?
  18. #116
    Aug 2005
    Rock Hill, SC
    5,486
    Floor boards, firewall, doors and roof.
    same concept as deadening for speakers.
  19. #117
    Nov 2008
    124
    Any specific brand or type you'd recommend?
  20. #118
    Aug 2005
    Rock Hill, SC
    5,486
    Anything thats Butyl based. Dont buy an asphault based deadner. They're not as effiecent, smell bad, and will melt into a puddle of nasty in your hot climate.
    I like edead45 - http://www.edesignaudio.com/index.php?cPath=1_24 - but its back ordered at the moment. They do have the heavier stuff in stock though, which is better, but more expensive and a bit tougher to work with.
    Second skin is about the best you can get - http://www.secondskinaudio.com/ - but itll cost you.
    Figure 100ft of mass loader (butyl dampener), probably 30-40 for absorption mat, and if you really want to go all out, get a bucket of paint on to do the floors with and the undersides of your fenders.
  21. #119
    dna-level-C ,OHIO
    6,253
    IMO F everything else and just use second skin, you get what you pay for. I'm practically done w/ my car and w/ the windows rolled up it's borderline Mercedes style quite on the highway and street. w/o music playing and the windows up I can't hear other cars at all, even sirens are completely faint, i like it that way myself but I didn't kill the floor because I wanted to only have noise from the undercarriage so I could hear if there is a rattle or something.
    I also did the firewall and it cut out a good amount of engine noise but not enough so that you can't diagnose stuff. I was gonna do the hood liner but i'll wait to do that on the CF hood whenever it comes.
    I do still need to put some closed cell foam on the trunk floor under my false floor when I remake it and a little more under the back seats. I'll do the wheel wells soon with the rest of the liquid deadener I have.
  22. #120
    Senior Member noisewatter has picked up a wrench noisewatter's Avatar
    May 2008
    Columbia, MO
    606
    Hey I just finished deadening my trunk, and wiring 2 of my Big 3. On the wiring, I think it looks ugly too, but it works, and I may change it later. And now the trunk lid weighs about 25 pounds heavier, and will nolonger stay open by itself. Here are some pics:
    Often wrong, never in doubt.
    Noisewatter.
    "Trust me, I'm a professional"
Similar Threads
  1. HELP - Humming sound after installing CAI
    By eclaixp in forum Naturally Aspirated
    Last Post: 05-26-2014, 11:58 AM
  2. New Remus sound clip video. No resonator! (kinda long)
    By DJ Hellfire in forum Naturally Aspirated
    Last Post: 09-10-2006, 08:26 PM
  3. About my thread that was locked
    By 03SilverBullet in forum Off-Topic
    Last Post: 03-04-2006, 08:54 AM
  4. Help!! No Sound
    By mlumz in forum Audio/Video/Security
    Last Post: 03-02-2006, 05:55 AM
  5. Exhaust sound clip thread
    By 03SilverBullet in forum Naturally Aspirated
    Last Post: 03-01-2006, 12:42 PM
