Vibration when foot off throttle between 70-75 MPH only
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
Thread: Vibration when foot off throttle between 70-75 MPH only
    Junior Member doji_nj has not yet proved knowledgeable
    Mar 2008
    Central NJ
    106
    Default Vibration when foot off throttle between 70-75 MPH only
    The last 2-3 days, I have started getting this horrible vibration all over the car when I take my foot completely off the accelerator around 70-75 MPH. As soon as I gently tap the brakes when the vibrating starts or push the gas pedal to accelerate, the vibration disappears. So I have learnt to drive without taking the foot off the pedal suddenly at highway speeds, which is not easy in rush hour traffic
    Is a wheel balancing and alignment required? Or is there a chance there is some thing in the front-end suspension that is out of whack and might need to be replaced? My tires (Bridgestone Potenza 960 Pole Position) have 10K miles on them and I do primarily highway miles.
    I did have new front pads and rotors put on a week ago. Another incident was that I hit an undulation in the road (no pothole) around 10 days ago at 50 MPH and thinking something might have screwed up the right passenger side after that? The car handled fine after the bump and no vibrations but am wondering if an incident like this might take a week or two before the vibration shows up?
    I was planning to go to Firestone for an alignment and wheel balancing /rotation but wondering if that will fix the problem, or do I have a bigger problem with the car?
    Elantra04 jobzombi has not yet proved knowledgeable jobzombi's Avatar
    Jul 2007
    Carteret, NJ
    1,009
    Default Re: Vibration when foot off throttle between 70-75 MPH only
    It is not the wheels as you would feel the vibration at all speeds, not just when you let off the throttle. Is it auto or manual? Depending on that it may be your tranny trying to engage and causing the shake through the engine.
    Call me J xdforme22 can identify a wrench xdforme22's Avatar
    Apr 2006
    Pennsylvania/Michigan
    1,978
    I have had this problem too. I thought it was caused by the known vibration defect (something to do with the steering components or something).
    Quote Originally Posted by Bobzilla
    But if it ain't broke, don't fix it is my old motto. Unfortunately that got replaced with: Break it so you can fix it sooner.
    Mar 2008
    Central NJ
    106
    Quote Originally Posted by jobzombi View Post
    It's an auto...04 GT with 109K miles.
    Jun 2005
    Eastern Shore, MD
    12,635
    Check your wheel bearings.
    2002 Hyundai Elantra: Sold
    1992 Toyota MR2: Sold
    Senior Member Poopsicle can identify a wrench
    Mar 2008
    Pittsburg
    975
    ^^ What? Why?
    Mar 2008
    Central NJ
    106
    Thanks. Will give it a try.....
    Bo daddy justintodd has not yet proved knowledgeable justintodd's Avatar
    Jun 2008
    Colorado
    224
    why would bearings go out at just that speed when the gas is lat off? im curious too. but then again I have no idea at all so i guess thats better than nothing...
    Ultimate Post Whore cbogg knows a lot about Elantras cbogg's Avatar
    Jan 2008
    Fort Edward, NY
    3,960
    Sounds like maybe the torque converter is sticking as he lets off the gas, like the clutch isn't disengaging as fast as it should.
    From AIM:
    Me: I get a day off during the week next week, woot!
    Derek: ooooh during the week? lucky you. I'd kill someone in front of their own mother for a day off during the week.
    Jun 2005
    Eastern Shore, MD
    12,635
    no idea. just thought I'd throw out a part name.
    Jan 2008
    Fort Edward, NY
    3,960
    Classic. Jim you made a joke! OMG!
    From AIM:
    Jul 2007
    Carteret, NJ
    1,009
    Yeah I am thinking clutch too!! Can't be axle or wheel related as it would get worse as you go faster not just at one specific speed. It may be that when you let go of the throttle the torque converter is not engaging properly and switching the gears. You have been using the proper tranny fluid right!?
    Mar 2008
    Central NJ
    106
    Yes I am. Infact, I just did a drain and fill a month back of SPIII fluid. So looks like this entails a trip to the dealer to fix the torque converter. What financial damage am I looking at for this problem?
    I am able to create this vibration at will. As in only between 70-75 MPH when I let my foot off the gas completely does the vibration appear and pretty much through the entire car for 2 to 5 seconds, and goes away if I step on the gas right away. As of now, I drive like I have an egg between my foot and pedal so that the shudder does not appear when decelerating.
    I plan to take the car for a tire rotation and alignment anyway since I'm due for it. If the vibration remains after this, I have no choice but to take it to the dealer and have them figure it out.
    Poster God Tx_boy can identify a wrench Tx_boy's Avatar
    Apr 2006
    Phoenix, AZ
    1,311
    I have that problem too but I know mine is because I need new half shafts cause my boots broke. When I just changed my brakes I was able to chake the rotor and not have the steering wheel move.
    2011 Sonata SE
    Shimmering White
    6K HID
    Stock but Beautiful!!!
    Senior Member Stocker can identify a wrench Stocker's Avatar
    Jun 2008
    Austin
    667
    if you are having your wheels/tires balanced for car-shaking problems, get them ROAD FORCE balanced. Not just static balance. Road Force. If the tire guy looks @ you like you are dumb or tries to hem & haw just find another shop.
    Note: if it only happens >70, how about trying <69 until you get it fixed?
    I am no longer active on this message board. Please find me at http://www.hyundaiaftermarket.org if you just have to get in touch with me.
    ______
    Check out my blog!
  18. #16
    Jun 2005
    Eastern Shore, MD
    12,635
    a static balance is just with the weights on the inside of the wheel. A dynamic balance has weights on both the inside and outside and can be done on a normal non-road force balancer. A road force balancer is different because it simulates the effects of driving and gives you a number corresponding to how well it does.
    A tire can be perfectly balanced but still fail a road forcer.
  19. #17
    Apr 2006
    1,978
    Quote Originally Posted by Stocker View Post
    Locate a shop here:
    http://www.gsp9700.com/pub/search/findgsp9700.cfm
  20. #18
    Mar 2008
    Central NJ
    106
    I had Firestone do a wheel alignment today. The vibration has reduced slightly, but they did a road test and confirmed that there is something either with the transmission or axle that is causing this vibration that they prefer not to get into, and referred me to a local transmission shop.
    The vibration is now very pronounced when I am going slightly uphill between 70-75 MPH on a gradual left to right turn and I need to slow down to reduce the vibration. So the vibration has progressed beyond appearing only when suddenly off the pedal when at highway speeds.
    Looks like a trip to a Hyundai dealer in central NJ is in store soon to figure out this issue. Also, is there a chance that 'if' I migh have overfilled the tranny fluid by perhaps quarter a quart of SPIII that this issue might have arisen? Is the TCM very sensitive to fluid level?
  21. #19
    Jun 2008
    Austin
    667
    If there is none, it won't run. If there is way too much it wouldn't be good but an extra dribble won't kill anything but your paint.
    Did they road force balance the tires?
    Before you go spending a zillion dollars at the dealership, try this: Rotate the tires front to back, and see if it changes. If it changes, or goes away it's the tires or wheels.
    ______
    Check out my blog!
  22. #20
    Senior Member cobase has not yet proved knowledgeable
    Aug 2004
    Beltsville, MD
    708
    When you're accelerating, more of the weight is on the back tires, and when you decelerate/brake it shift to the front tires again. Not a huge difference, but it might matter. Rotating the tires is one way to experiment with just changing one thing. What about using "3" instead of "D"? Does it still happen? Does the vibration stop if you shift into Neutral? (not a trivial thing to try at 75mph)
Similar Threads
  1. throttle sticks
    By shadow5606 in forum Help!
    Last Post: 11-05-2008, 10:04 PM
  2. Throttle Body off a different car thats compatable?
    By Mahonroy in forum Forced Induction and Nitrous
    Last Post: 04-17-2007, 05:50 PM
  3. unique vibration
    By CodyTheBowler in forum Help!
    Last Post: 11-23-2006, 04:05 AM
  4. Throttle Body Sticking...
    By Mahonroy in forum Help!
    Last Post: 11-18-2006, 01:13 PM
  5. Vibration at 65 to 70 mph?
    By Lil Stinky in forum Help!
    Last Post: 09-01-2005, 09:18 PM
