12v Cigarette Lighter Stopped Working...
Results 1 to 13 of 13
Thread: 12v Cigarette Lighter Stopped Working...
    Default 12v Cigarette Lighter Stopped Working...
    Hello, the 12v cigarette lighter and the 12v accessory plug all of the sudden stopped working. I tried swapping out the fuse that is under the steering wheel, that said cigL but the fuse didn't look burned up, and after I swapped it it still did not work. Are there any other fuses that I could try? Or what else could be wrong? Thanks!
    -New Turbo Kits For Hyundai And Kia Now Available! www.jattus.com
    Senior Member Stocker can identify a wrench Stocker's Avatar
    Jun 2008
    Austin
    667
    Default Re: 12v Cigarette Lighter Stopped Working...
    A wire may be disconnected. This is something you will end up upside-down under your dashboard trying to fix.
    I am no longer active on this message board. Please find me at http://www.hyundaiaftermarket.org if you just have to get in touch with me.
    ______
    Check out my blog!
    Kinky Kelly 2003GT has not yet proved knowledgeable 2003GT's Avatar
    Apr 2008
    MASS
    3,191
    Behind the Fascia the piece you remove to put in a New radio, there is a connector that supplies power to the Cig and the lights. Check that connection.
    FaceBook Me!!! IM: MrDeere1982 Subs, CAI, Pioneer HU, Blue interior lights, Xeon High Beams, HID 6000K Lows, 3000K Fogs, Clear Door Lenses with Multi Color LED's, Muffler Delete and Tinted Windows. BOB
    Quote Originally Posted by smileymattj View Post
    Bob is right.
    wow did i just really say that?
    Ok I pulled that off and there is a harness that plugs into the 12v power accessory. Its plugged in. I also put a voltmeter to that connection and it reads no power. I tried to follow the wireing harness back but it just gets paired up with others and goes further back. Do you think it could be a different fuse? Like maybe I tried changing the wrong one or something?
    Near Chicago, IL
    15,223
    Stupid, stupid question: Do you have the car turned on? The cig lighter gets no power without the key on.
    • Future: ????
    Yeah its turned on. I've used this plenty of times to power my laptop for when I tune my car, its deffinetly not working right.
    Oct 2004
    Redondo Beach, Ca
    4,862
    Do you have power on both sides of the fuse? Do you have continuity between the fuse and the outlet?
    Ok I figured it out thanks again for the help. My fuse diagram was labeled off. I looked up the fuses on HMA service and it told me to swap a different fuse, sure enough the fuse was cooked and when I swapped it it works now!
    Elantra04 jobzombi has not yet proved knowledgeable jobzombi's Avatar
    Jul 2007
    Carteret, NJ
    1,009
    If your going to drain a lot of juice, or use both at the same time, upgrade to a larger fuse. I added another lighter on top of the dash so I can plug in a shortened, custom made, plug for my popo radar, I hated having the wire come in front of the radio and all the other buttons, and I had to upgrade to a larger fuse.
    Jun 2008
    Austin
    667
    ^ for bad advice, see above.
    A larger fuse is a good way to either have to keep replacing fuses or start a fire, depending on how lucky you are.
    ______
    Check out my blog!
    im agreenin with stocker. never, ever replace a fuse with a larger one.
    Oct 2004
    Redondo Beach, Ca
    4,862
    Quote Originally Posted by jobzombi View Post
    Please don't post again. That same thinking lead me to have to rewire a customers car. Fuses are a certain amperage rating for a reason. Go back to posting pics of your dick online. You seem to be better at that than giving advice about cars.
    Bo daddy justintodd has not yet proved knowledgeable justintodd's Avatar
    Jun 2008
    Colorado
    224
    ^......lock
Similar Threads
  1. Cigarette Lighter
    By alexbee in forum Help!
    Last Post: 08-31-2009, 06:01 PM
  2. Replies: 2
    Last Post: 12-11-2006, 06:05 PM
  3. Replies: 1
    Last Post: 07-10-2006, 07:02 PM
  4. Dumb cigarette lighter question
    By yg17 in forum Audio/Video/Security
    Last Post: 05-25-2006, 08:27 AM
  5. cigarette lighter problem
    By TheKoreanSaab in forum Interior
    Last Post: 01-07-2006, 11:13 PM
