Tapping into fuse blocks?
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 22
Thread: Tapping into fuse blocks?
    Car
    2011 Kia Optima SX; 2005 WRX STi
    May 2006
    Noblesville, IN
    10,964
    Question Tapping into fuse blocks?
    I want to tap into my fuse block for a few things I'm putting in my Sonata. (I've never done this before, as I've always ran power wires from the battery with inline fuses.) I want my radar detector to come on with the car, as well as whatever else I put in there.
    What's the best place to tap into? How exactly is it done? I was under the assumption you just stick one wire in each side and hold it in with a fuse, but I didn't think it would be that easy. Any insights?
    Elantra XD
    Car
    2005 Elantra GT M/T
    Feb 2005
    Gatineau, Quebec, Canada
    310
    Default Re: Tapping into fuse blocks?
    If I were you, I would still run a primary wire from the battery. However, you could tap on an accessory that comes ''on'' with the car to activate a relay that would bring power to your accessories at the same time as you turn your car on. Therefore, you run less chance of blowing your fuses due to too much current being drawn plus you can put a fuse just for that or those extra accessories you want to give power to.
    Alpine Developments, Alpine Audio, Atelier HP,Extreme PSI, Hifonics, Goodridge, Kartboy, Mobis, Perfect Power, Prosport, SFR, South Bend Clutches, TSW, TWM.
    Car
    2005 Elantra GT Sedan
    Aug 2005
    Rock Hill, SC
    5,500
    I actually just hardwired a 1 to 2- outlet cigarette plug thingy behind the dash. Just spiced straight into the wiring for the AUX power plug.
    Gives me 2 hidden outlets and 2 external outlets. I have my GPS and my XM radio plugged in behind the dash.
  5. #4
    Car
    May 2006
    Noblesville, IN
    10,964
    Quote Originally Posted by Tommy View Post
    You know, that's not a bad idea, I was thinking of doing that. I did something similar in the Elantra..I wired a 4-way to a switch.
    How did you tap into the power?
  6. #5
    Car
    Aug 2005
    Rock Hill, SC
    5,500
    Cut the hot wire, spiced it back together with the positive from the adapter, then grounded the other wire to the chassis.
  7. #6
    Car
    2008 Hyundai Elantra
    May 2008
    utica,ny
    247
    you can also use a device called "add-a-circuit". i wired up a radar detector and 2 sets of neons with switches right to my fuses. its really easy to use
  8. #7
    Aug 2004
    Beltsville, MD
    708
    Fuse taps - they plug into the fuse socket and give you a 12V wire, and they have sockets for two fuses - one for the original circuit and one for the additional thing you're adding. They're like $10 or less at auto parts stores. I think I got mine at Advance Auto or Autozone.
    I used one to connect the cig lighter circuit to the CarPC power supply logic, so it knows when the ignition is ON/OFF and boots/shuts-down accordingly.
    I've wondered if it makes a difference plugging it in the wrong way, and how to tell what the right way is. Still don't know.
  9. #8
    Car
    2010 Equator, 2003 Tiburon GT, 2004 Santa Fe, (Sold 2002 Elantra GLS A/T)
    Near Chicago, IL
    15,060
    Shouldn't make a difference if you plug it in backwards. It's all positive power, and the fuses are just like "interrupts" in the power line.
    2010 Equator Sport | 2002 Elantra GLS (sold) | 2003 Tiburon GT | 2004 Santa Fe GLS
  10. #9
    Car
    2006 Elantra GLS Manual
    May 2006
    Pittsburgh
    9,868
    ive done all three. power taps are nice, but i only did this once cause people are too lazy to go get them lol.
    did a small 35x3 amp in my dads 98 elantra wagon. just ran the wire into an open fuze spot, jammed the fuze over the wire and voila. Ideal? no.. functional. Yes.
    I also spliced my cigarette into two when i was 18 and obsessed with neon lights. i just used a wire tap to split the line, ran it to an on off switch hid in the ashtray then to one of the small wire blocks. Its a single hot input with like 10 really tiny high gauge outputs It came with a neon set. Open the ashtray, flick the switch and the neons all kicked on.
    al three are fine. wire into the fuse was the easiest, but the most ghetto. Also make sure everything is secure, dont want anything falling out :P -and on the 98 there were a good 3-4 empty fuse slots, i assume for options this car didnt have or something.. so i just used one of those.
    Last edited by Ugzz; 12-16-2008 at 02:15 PM. Reason: cause munky touches himself at night
    Internet Jesus is not pleased with the absense of the chatbox.
    And he stated, "let the people speak, and I shall grant thee speed". Microsoft Sam 11:17
  11. #10
    Car
    2003 Carbon Blue GT Sedan
    Florida
    4,434
    Quote Originally Posted by hyunelan2 View Post
    Not true.
    If you plug it in backwards then the fuse will basically not work as the 'leg' of the adaptor with the wire will always be on the power side. You want the 'leg' with the wire on the opposite side of the power, therefore the fuse will trip if it ever shorts......does that make sense?
    Member # 7: 2003 Carbon Blue GT
    "If you want to kick the tiger in his ***, you better have a plan for dealing with his teeth." - Tom Clancy
    Only a Biker Knows Why a Dog Sticks His Head Out of a Car Window.
  12. #11
    Car
    Near Chicago, IL
    15,060
    You're right^
  13. #12
    Aug 2008
    Las Vegas
    2,467
    Quote Originally Posted by rckozma View Post
    This is only true if your device isn't fused. I always run an inline fuse between my device and power tap.
    Aaron Britt
    '08 Mustang GT/CS
    '87 Nissan Hardbody - The "Mud Mobile" (454,000 miles and still counting)
    '06 Suzuki Burgman 650
  14. #13
    Car
    Florida
    4,434
    The device we are talking about is what cobase posted a pic of, it already has a fuse built into it, I was just pointing out how it needed to be installed so that the fuse on the adaptor actually works
  15. #14
    Car
    03' 4dr/GT, 2-Tone ,5spd
    dna-level-C ,OHIO
    6,243
    so how will cobase know if he has it in right?
    78 Datsun 280z = Resting
  16. #15
    Aug 2008
    Las Vegas
    2,467
    My point was just that if the device is fused, it doesn't matter if the one on the adapter works or not.
    Quote Originally Posted by CornbreadXD View Post
    When you pull the fuse out to install the adapter, use a circuit tester light to determine which leg of the socket is hot. One side will be hot, the other not. Install the adapter so that the red wire is on the cold (ground) side.
    Aaron Britt
    '08 Mustang GT/CS
  17. #16
    Car
    Near Chicago, IL
    15,060
    Through the awesome, awesome power of my pen and scratch paper at my desk, I think I have illustrated how this works.
  18. #17
    Aug 2008
    Las Vegas
    2,467
    A true arteest.
    Aaron Britt
    '08 Mustang GT/CS
  19. #18
    Car
    Florida
    4,434
    Quote Originally Posted by i8acobra View Post
    Nope, you are right I do the same thing. I was just explaining the device.
  20. #19
    Car
    09 Kia Optima LX
    Jan 2008
    Fort Edward, NY
    3,960
    go with the fuse tap, they work, and they're easy. just don't try to run your 1100 watt jl amps off em. you'll go through a lot of fuses that way. and **** starts to smell funny...
    From AIM:
    Me: I get a day off during the week next week, woot!
    Derek: ooooh during the week? lucky you. I'd kill someone in front of their own mother for a day off during the week.
  21. #20
    Car
    May 2006
    Noblesville, IN
    10,964
    Thanks for the replies and awesome artwork, guys.
    This will only be for my radar detector, and possibly GPS as well. No amps or anything this way..if I get a system put in here it will be done the right way.
Similar Threads
  1. Auxilury Fuse Box
    By smileymattj in forum Audio/Video/Security
    Last Post: 09-07-2008, 08:00 PM
  2. Replies: 9
    Last Post: 02-13-2007, 11:31 PM
  3. Door lock/sunroof fuse blowing problem!
    By DJ Hellfire in forum Help!
    Last Post: 04-14-2006, 09:38 AM
  4. ECU Fuse Keeps Blowing
    By BColeman in forum Naturally Aspirated
    Last Post: 04-02-2006, 07:30 PM
  5. Fuse Problem
    By peechez in forum Help!
    Last Post: 10-03-2005, 12:35 PM
