Strut mounts/clunking
Results 1 to 10 of 10
Thread: Strut mounts/clunking
    Default Strut mounts/clunking
    Hey - new here... I have a question regarding 2002 Elantra GLS strut mounts. I did a search, and didn't find much.
    The car in question has ~80k miles and has developed a clunk over bumps (from pulling into the driveway to expansion joints on the road). I took a look at the mounts, and the rubber is pretty deteriorated, especially the driver's side.
    My past experience leads me to believe that these may be the cause, or part of the cause, of the clunk. Is this correct, or does the Elantra have some other common cause for clunking? If it's just the mounts, I'm guessing a Haynes manual will cover everything needed to replace... unless there is a DIY somewhere.
    Thanks!
    Eric
    2001 Boxster | 2001 IS300
    Senior Member 2001VE has not yet proved knowledgeable 2001VE's Avatar
    Apr 2007
    Newmarket,ONT, Canada
    535
    Default Re: Strut mounts/clunking
    Lots of things can make a clunk.
    Make sure its not outer tie rods, can also be safety issue.
    If its upper strut mounts --stiff steering also a likely side effect.
    Nothing wrong with getting opinions (free) from a shop.
    If two places come to the same conclusion , your on the right track.
    Senior Member Poopsicle can identify a wrench
    Mar 2008
    Pittsburg
    975
    DId you look at the tie-rod too? lift your car and wiggle the tire side by side, if there is play, you need new tie rods end.
    Proud daddy.... mnstrmech has not yet proved knowledgeable mnstrmech's Avatar
    Nov 2005
    south bend, in
    328
    the sway bar mount bushings can cause a clunk niose when worn out also.... its VERY common on caravans/t &c's and voyager mini vans... and for some reason.. my energy suspension bushings too if i let them go to long between greasings..... it is harder to spot worn out bushings cause even just 1 millimeter of wear is hard to actually see but can cause a nasty noise...
    '03 midnight blue gls sedan
    catch can, fidenza short shifter, KYB gr-2 struts, Eibach prokit springs, 19mm tibby bar, greasable poly sway bar bushings, kenwood dpx-301, boston acoustic componets and re audio subs
    myspace
    http://www.myspace.com/mnstrmech
    Poster God CRAZIECRACKER has not yet proved knowledgeable CRAZIECRACKER's Avatar
    Jan 2008
    ALBANY, NY
    1,956
    i also have a "clunk" noise which started after my car was lowered. i checked the struts and tightened the mounts and anything in the rear just to check it out. i think its just the coils on the springs hitting eachother tho, i havent wrapped them yet like most members do on the board. i doubt its my sway bushings, theres only 27,000 on the car and they looked good when i lowered it.
    You said feen. Hah, you really are a crazie cracker.
    Quote Originally Posted by slyderdai View Post
    well damn Jesse look at that expert advice. Well Said!
    So apparently my wife is a better tech than Derek and Evan.
    MECP basic and advanced certified!
    Junior Member ken2400 has not yet proved knowledgeable
    Oct 2008
    NY
    92
    If you are going to keep this car until it dies do your self a favor
    Replace Spring, strut and month all at the same time.
    Do all four and you will have a new ride!!
    Give yourself about 30 days to get use to it.
    I replace all 4 struts my 2001 GLS with 131 K miles last fall and this spring I WILL pull it all apart again and replace all four springs. The car is too big and weights too much to keep the old springs. So much for saving the $$ on this idea. I knew better
    Good luck and keep us posted.
    Thanks for all of the feedback.
    I finally pulled it into the garage to check it out more thoroughly. I did a basic bounce test on the front suspension, and the drivers side is hard as a rock and takes a good 5 seconds to slowly rebound to normal height. So now I suppose I'll be replacing the front struts. We'll see what else is worn out while I'm in there.
    Eric
    I just ordered some KYP GR2 struts and new mounts and a Haynes manual. We're not planning on keeping this car forever... probably 30-40k more miles.
    Thanks for the help!
    Eric
    Here to irritate Munky 03GT knows a lot about Elantras 03GT's Avatar
    Sep 2007
    WA
    2,584
    I too developed the clunk about a month ago and finally isolated where it was coming from. The nut that bolts the shock absorber rod to the upper strut mount was loose. Don't ask me how, I dunno. Tightened it back up and the noise wen't away.
    The clunk seemed only to appear going over bumps. Steering/ride was no different, clunk happened when turning over bumps, straight over bumps (specially speed bumps), etc.
    100% Vaginatarian
    My Garage
    Washington DC: You will never find a more wretched hive of scum and villainy.
    May 2005
    Mahanoy City, PA
    6,582
    1) Shocks/struts should be replaced every 60k miles. That's a recommendation, so if they aren't leaking, you don't necessarily have to replace them.
    2) Strut mounts tend to wear out over time, especially the fronts, where they pull double duty as pivots for the strut for turning, and as a mount for the suspension.
    If you are hearing clunking, it is typically associated with the strut and strut mounts. Tie rods don't make any noise if they are bad, they just result in poor alignments that don't last long and poor tire wear. Endlinks, if they break, can cause clunking emanating from the sway bar area. If you've got the plastic ones, they are worth a look-see.
    Additionally, check for a broken spring. It is more evident outside the car, if the car is leaning a specific way. The spring supports the car, and if one is broken, you'll hear clunking, and see your car leaning a weird way.
Similar Threads
  1. Installing struts/springs (many pics)
    By shadow5606 in forum Do It Yourself Section
    Last Post: 04-19-2014, 10:33 AM
  2. Replies: 21
    Last Post: 03-30-2006, 07:01 PM
  3. Diameter of the 04 XD Strut?
    By Jfoghino in forum Suspension/Brakes/Drivetrain
    Last Post: 10-13-2005, 04:53 PM
  4. CF Strut Bar vs. MUSSA Strut Bar
    By Cyberz XD in forum Suspension/Brakes/Drivetrain
    Last Post: 08-26-2004, 08:21 PM
  5. MUSSA STRUT BAR on SALE ! 2 weeks.
    By MUSSA SPIRIT in forum Best Deals and Group Buys
    Last Post: 08-19-2004, 09:37 PM
