Right front tire makes clicking noise
Results 1 to 10 of 10
Thread: Right front tire makes clicking noise
    Senior Member Caudill2748 has picked up a wrench Caudill2748's Avatar
    Oct 2008
    Maryland
    785
    Default Right front tire makes clicking noise
    Randomly does it, but recently hasnt stopped...Can mainly hear it when above 30-40Mph...Anyone know what it would be? sounded like something was sticking out of wheel or something but its not that.
    EXD Pro Member vsolo has picked up a wrench vsolo's Avatar
    So. Central Pennsylvania
    1,116
    Wink Re: Right front tire makes clicking noise
    How many miles ? How old are the tires, Miles on them, RIMS ? Etc
    2002 GT Black,Tib 19 mm swaybar,KORE strut bar,
    CF Hood,Carbonman Grill & Eye Liners, KDM foglights,
    OEM SS brake lines, H & R Springs, KYB GR2 struts,
    Astrel side skirts,TC Front Spoiler,OEM Rear Spoiler .
    Rebuilding the XD CornbreadXD knows a lot about Elantras CornbreadXD's Avatar
    dna-level-C ,OHIO
    6,253
    Default Re: Right front tire makes clicking noise
    do you see any grease coming out of the cv boot? You might need to take the tire off to get a better look at the area
    78 Datsun 280z = Resting
    Senior Member soccerfanatics3 can be stupid at times
    Sep 2007
    LONG BEACH,CA-Denver,CO
    652
    wheel bearing most likely had the same problem
    dna-level-C ,OHIO
    6,253
    can't you check the bearing by jacking the car up and shaking the wheel to see if there is play or spinning it to hear a moving marble sound
    Jul 2006
    3,782
    Clicking / popping is usually going to be the CV. Bearing would make grinding or vibration.
    Shaking the wheel off the ground should indicate a bad bearing if there is too much play, best to take the brakes off because they will help hold the hub straight. Then you can really see what the bearing is doing.
    Could be something rattling inside the tire hitting the rim every now and then?
    smileymattj's Garage
    Oct 2008
    Maryland
    785
    Tires and Rims havent been on the car for over 5k miles...and the car has about 54k on it...And the bearing on the side that clicks was replaced about a year and a half ago during xmas when my car slid into a curb at about 30mph >=(
    But yeah i gotta change the brakes/rotors soon, but didnt think it was those making the noise, so ill take off the wheel and everything sometime soon to see if its that...Or just take it to my uncles shop and bug him more >.< lol.
    Thanks for the help, ill keep ya updated.
    Newbie Cranker has not yet proved knowledgeable
    Jul 2009
    Northeast USA
    4
    Any clicking I've had was a nail/screw/rock stuck in tread.
    I had large screw removed from tire, but clicking persisted. It turns out my other tire had nail in it also at same time! Tires are silent now.
    No frills zander has not yet proved knowledgeable zander's Avatar
    Aug 2009
    SW Ontario
    34
    I have to side with Cranker here. A "clicking" sound which "Can mainly hear it when above 30-40Mph" would lead me to checking the thread on *all* tires, not just the one I thought the clicking was coming from. Cars are great ventriloquists. A sound which you think is coming from the front left tire, may end up originating from the rear right, by the time you've found the source.
    To me, "clicking" is thread-lodged debris; bearings would be a hum which would increase in volume with speed; and a CV boot would typically click on turns (which would be ruled out here with the 30-40mph).
    Just some thoughts.
    Junior Member HyundaiKitCoupe knows about Elantras HyundaiKitCoupe's Avatar
    Aug 2006
    Washington D.C.
    148
    have a problem like that now. it's my ball joint. otherwise it's the bearing, or CV rubber Boot has a crack in it and you can tell if there's a bunch of grease splashed all over the inside of your rim.
