Replacing kia optima 2.4 timing belt and head
Results 1 to 14 of 14
Thread: Replacing kia optima 2.4 timing belt and head
    The Underdog seguin22 has not yet proved knowledgeable seguin22's Avatar
    Nov 2005
    Duluth, MN
    514
    Default Replacing kia optima 2.4 timing belt and head
    Long story short I need to know how hard it is to replace the timing belt and head on a dohc 2.4 litre kia optima. Have any of you guys had any expierence with it, or have any pointers to share with me? I see it has two belts one timing and one for the balance shaft and the kit comes with three tensioners so I will need to replace those I suppose.
    Thanks in advance, AJ
    Tool~ The Pot (listen to it now)
    Apr 2004
    Southeast DC
    25,975
    Default Re: Replacing kia optima 2.4 timing belt and head
    What year Optima? Which 2.4l engine? The current Theta or the old Sirius engine?
    I mean, I don't know the answer, but this info might help someone that actually knows.
    Nov 2005
    Duluth, MN
    514
    Umm its whatever one came in the 2001 optima.
    Indiana
    11,228
    2.4L sirius. It's basically a Mitsu 2.4L. Not that hard to work on. Log on to www.hmaservice.com and look up a 2001 Sonata and it will give you all the info you need.
    Nov 2005
    Duluth, MN
    514
    Awesome!! thanks for the link.
    Indiana
    11,228
    And they say I never help anyone!
    Apr 2004
    Southeast DC
    25,975
    Didn't it feel good being nice and helpful?
    Tannersville, PA
    12,884
    JUST DO NOT LET THE CAMS SLIP!!!! if they slip and twirl...you might bend a valve. i've seen it done. there are special tools to hold the cams together...i personally use 2 17mm wrenchs on the bolts and them clamp them together with a set of vice grips.
    you also have to make sure the oil pump shaft if in time as well....its a pita if you have not done one before...and also watch out for the crank position senso...if you put the plate on backwards or mess with the sensor at all...you will be taking it all apart again!
    not one of my favorites...but better then the XG
    Jun 2005
    Eastern Shore, MD
    12,635
    If its just like the mitsubishi, it's quite easy. I just did a 97 galant timing belt/balance shaft belt this past week. Everything went quite easy with the exception of the auto tensioner. If it has an automatic tensioner, GET A NEW ONE.
    Also, if its like a mitsubishi then do yourself a favor and pull out the bolt next to the oil pump sprocket and insert a long philips screwdrive into it. It'll keep the oil pump drive from turning when you go to put the timing belt on, since it spins freely. Other than that, it's a fairly straight forward and easy job.
    2002 Hyundai Elantra: Sold
    1992 Toyota MR2: Sold
    Tannersville, PA
    12,884
    or the other trick is to turn it manually and if it rolls back to towards the timing mark its in phase.
    and yes its EXACTLY a MITSU motor....hell an evo head fits on there and vise versa. its a 4g block
    Junior Member shoreman has picked up a wrench shoreman's Avatar
    Jul 2008
    Maryland's Eastern Shore
    185
    Eric drove down to Salisbury with the overdrive off. I got in the car to drive everyone to lunch and noticed it was off. He said it was off so he left it off. I wonder what RPMs he was running at 70 MPH in 3rd?
    I guess it's a testament to the engine's durability and your work. Take a little something from petty cash today.
    The whole aim of practical politics is to keep the populace alarmed and hence clamorous to be led to safety by menacing it with an endless series of hobgoblins, all of them imaginary.
    H.L. Mencken
    Jun 2005
    Eastern Shore, MD
    12,635
    Geez, 3rd gear at 70mph? Not only was he turning that motor hard he was wasting some serious gas, but I bet it moved when he went to pass someone!
    Yeah that may get it into time, but won't keep it from moving when you go to put the belt on.
    Nov 2005
    Duluth, MN
    514
    I have a DOHC lock tool so I will just line up the marks and use that tool to lock the cams in place. The kit comes with new belts and tensionor and thanks for the tips on the oil pump I was wondering about that.
    Tannersville, PA
    12,884
    but you can manually move it to line up...either way will work. thats just the way i was taught and am familiar with.
