Tightening Accessory belts
Results 1 to 16 of 16
Thread: Tightening Accessory belts
    Newbie marckgt04 has not yet proved knowledgeable marckgt04's Avatar
    Feb 2009
    Raleigh, NC
    23
    Default Tightening Accessory belts
    I had the embarrasing power steering squeal this morning. After reading through some threads here I've decided my accessory belts need to be tightened. How do I tighten them down? Should there be any slack in the belts at all, or should they be super tight?
    I just had my timing/accessory belts done 6 weeks ago, so my belts should be good.
    Thanks in advance.
    Tannersville, PA
    12,884
    Default Re: Tightening Accessory belts
    the alt belt needs to be tightened....
    but to do all three....
    power steering...there is a 14mm bolt untop and another one on the bottom of the pump. loosen them until the pump can move...pull it toward you and tighten the top bolt while pulling on the pump...i believe its supposed to have 5mm of defelction. wich means if you press down on the belt it will go 5mm (IIRC)
    altenator/water pump belt (and more then likely the one squealing) loosen the 12mm bolt on the bracket just above the alt....there will be another long bolt that sits perpendicular to that bolt and will screw into the block (this block is the one that the 12mm bolt holds down.) you have to turn it (i forget which way) a couple of turns and check the deflection same as the power steereing.
    the ac is the same...but you have to remove the wheel and cover for easy access...you can do it from the top if you long arms....a 14mm bolt on the bracket is loose and then there is a12mm bolt again perpendicular to it facing the rear of the car....turn that one and tighten it up.
    Feb 2009
    Raleigh, NC
    23
    just checked all my belts, and they seem to be tight. Could they squeal if they're too tight, or could it be something else?
    Avante2nr Elantra87 has picked up a wrench Elantra87's Avatar
    Jan 2007
    TX
    1,258
    My power steering belt has been squeeling the past few days on cold starts then it goes away once i start to drive. Its been really cold and rainy iam guessing thats why
    Dec 2006
    Delaware
    7,295
    I have the same problem on my sonata rainy or really cold weather it will squeal like a stuffed pig.
    Feb 2009
    Raleigh, NC
    23
    By chance are you guys using stock belts? I have bando brand belts, and even when I had 88k on my stock ones, they didnt squeal like this. I dont know if I should go back to stock or if there's even a difference?
    Dec 2006
    Delaware
    7,295
    With out going out and looking under the hood I dont know off hand.
    Tannersville, PA
    12,884
    did you tighten the alt belt like instructed?
    Jun 2005
    Eastern Shore, MD
    12,635
    I have always ran Gates belts, and never had any problems. One of your belts is probably just a little loose. Check the alternator one like Only1db said.
    2002 Hyundai Elantra: Sold
    1992 Toyota MR2: Sold
    Feb 2009
    Raleigh, NC
    23
    altight, i did it, but i cant seem to get the long 12mm bolt to get back to it's original position (the bolt is a little rusted everywhere execept where its been covered the last 88k) The coolant reservior is in the way (prob why the mechanic didnt tighten it down completely in the first place). Does the top of the bolt need to be tightened down completely?
    I concur, gates ftw.
    Tannersville, PA
    12,884
    you can take the fan out (two ten mm bolts on the top and then pull it out) and then you can remove the resivoir if you want...two 10 mm bolts on the subframe all the way at the bottom....but if you have a 12mm wrench you can get in there with out taking any of that stuff off/out.
    just keep turning clockwise till its tighter. and push down on the belt...it should have the correct deflection.
    Feb 2009
    Raleigh, NC
    23
    fresh hands, tightened them down this morning, no more embarrassing squeaking like im driving a p.o.s. thanks for the help.
    Junior Member ken2400 has not yet proved knowledgeable
    Oct 2008
    NY
    92
    This is one of the things Hyundai could have done better. Most car makers use a nice wide all in one belt. More surface area make best work better and last longer Hyundai, in 2001, still used small narrow belts like most car makers used in the past.
    Good luck with yours.
    Tannersville, PA
    12,884
    all the beta motors still do....all the way up to the 2010 touring minus the power steering.
  18. #16
    Jun 2005
    Eastern Shore, MD
    12,635
    It's a 4 rib belt that only goes across two pulleys, really not that big a deal as far as wear goes. Belts get replaced primarily due to age aside from the occasional belt tensioners (which would be on serpentine belts, not the indivdual accessory belts like we have) so your argument is invalid. I also personally perfer to have indivdual belts since this way if you happen to lose your p/s belt you're still good to go because your alternator and water pump will still be driven vs if you had a "all in one belt" that decided to break or the tensioner let go and you're now on the side of the road because you have NOTHING.
