[XD] Front Wheel Bearing Removal
Results 1 to 19 of 19
Thread: Front Wheel Bearing Removal
    Senior Member QuickSilverGT has not yet proved knowledgeable QuickSilverGT's Avatar
    Pensacola
    879
    Default Front Wheel Bearing Removal
    This weekend I decided to take on changing out my front wheel bearing. I knew it was shot, so last week I ordered a new bearing and hub from RockAuto. I've searched and know that if you drive on a bad bearing for long enough, you can also screw up your hub.
    I started my project and everything was going pretty smoothly. I removed the wheel, brakes, axle nut, rotors, had the hub loose... and of course I run into the problem of not being able to get the tie rod loose from the hub, and some goes for the lower control arm. Come to find out there's a special tool for this, basically a fork, so I get it and I'm once again golden. I have everything out and now it's time to get the knuckle loose from the bearing/hub. Turns out, it can't be done without another specialty tool, or otherwise taken to a machine shop. So now here I am, on a sunday, without a car (with good tags anyways), waiting for monday to come. None of the area shops say they have this tool, and at this point I've all but given up on doing anything but taking it to the machine shop on monday.
    Does anyone know of a tool that would work that is rented out? (removing hub from spindle knuckle) Thanks.
    Default Re: Front Wheel Bearing Removal
    it needs to be pressed out, n then in. i believe harbor freight tools sells a hand held tool for this, but i dont know how effective that could be.
    i also need to replce atleast my passenger front bearing, SOON! waiting for my income tax to order everything.
    Pensacola
    879
    Well I guess I'll be waiting until tomorrow to get it to a machine shop. HMAservice.com diagram shows that there's a tool for it, and I found a VW DIY where they did it with a hand tool, but no such luck finding something like that for rent. If it helps any, getting the entire assembly out took about 1/2 and hour. You'll need the 32mm Socket w/breaker bar, a few other common sockets (14 for sure), a tie rod breaker, a ball joint breaker, and a hammer. Pretty simple minus the pressed parts.
  5. #4
    Apr 2004
    Southeast DC
    25,975
    You could buy that Hyundai tool if you wanted.
    http://www.elantraxd.com/forums/show...-Service-Tools
  6. #5
    Pensacola
    879
    Eh, by the time that tool gets here, I could have gone to the machine shop a few times over. Thanks anyways though.
  7. #6
    Pensacola
    879
    Wheel bearing success! After I got the machine shop to replace the bearing and hub ($35), got it all put back together in 30 minutes. If have a spare vehicle, I definitely recommend you doing this yourself.
  8. #7
    Tannersville, PA
    12,884
    and instead of using the fork and possibly damaging the boots you can just use a hammer and hit the metal where the tie rod sits and where the control sits...they just pop out and no damage.
    and yes the bearings WILL need to be pressed out by a professional....there is no handheld tool in the world that i would trust!!!
  9. #8
    Pensacola
    879
    I tried to hit the tie rod bolt to get it loose, but it wasn't happening. Then again, I had a small household hammer, so that probably had a lot to do with it. Regardless, it's all done and I can now talk to passengers in my vehicle without having to well at them. That humming noise was loud and irritating. It doesn't help that I ignored for close to two years, but sacrifices had to be made during that time period.
  10. #9
    Tannersville, PA
    12,884
    hahahah i hear ya...it took me awhile to do my bearings in my tib...i was just putting it off...till i found out that it was covered by the 10 year 100k warranty...then i took it in and they fixed it! haha
  11. #10
    Apr 2004
    Southeast DC
    25,975
    Good to hear you got it fixed. Two years? You are nearly as lazy as me it seems, haha.
  12. #11
    wheel bearings r covered by the 10/100? ill bring this **** in to get it done then!?
  13. #12
    Indiana
    11,228
    Yes, FRONT wheel bearings are 10/100 for the original owner.
  14. #13
    word. gonna go ask the stealership tomorrow and get it done if they do it for free.
  15. #14
    Pensacola
    879
    Free is definitely better than DIY, but I was way past my 100k mark. Even two years ago.
  16. #15
    im not so this is great news for me! lol
  17. #16
    Pensacola
    879
    I can't complain. To date (120,000 miles), i've changed from ac hose (expensive!), rotors, brake pads, fluids, plugs, wires, tires, cv axle, headlight bulbs, and bearing. Under warranty I had both o2 Sensors changed.
  18. #17
    Dec 2006
    Delaware
    7,286
    At that amount of miles thats not all that bad of a list.
  19. #18
    Newbie jaaams has not yet proved knowledgeable
    Jan 2010
    Maine
    4
    for removing the wheel bearing a steady hand and some oxy acetylene torches will do the job but you do need a press to get them back in.
  20. #19
    Newbie clarkandrew45 has not yet proved knowledgeable
    Jan 2011
    Illinois USA
    9
    Quote Originally Posted by QuickSilverGT View Post
    Wheel bearing module success! After I got the machine shop to replace the bearing and hub ($35), got it all put back together in 30 minutes. If have a spare vehicle, I definitely recommend you doing this yourself.
    I am planning to remove my wheel bearing. I guess i need to try what you have did. 30 minutes is more faster than i did before. I took me about an hour just to remov the wheel bearing.
