[XD2] P2626 Check Engine Code CEC.....need help and advice on parts
Results 1 to 18 of 18
Thread: P2626 Check Engine Code CEC.....need help and advice on parts
    2005 Elantra GT footprintsincon has not yet proved knowledgeable footprintsincon's Avatar
    Jan 2008
    Roseville (Sacramento), CA
    144
    Question P2626 Check Engine Code CEC.....need help and advice on parts
    i have a 2005 Elantra GT Hatchback with 99,300 miles. the color is blue
    well as i was leaving the autozone parking lot, my check engine light went on and i turned around and went back and this is the code they said:
    P2626 code: so this must be the oxygen sensor from what i have read from this site
    but which O2 sensor? the upstream or downstream?
    where is the upstream located? is it just off the manifold? or under the car?
    lastly what brand should i get? Bosch exact fit for $90 or Hyundia's OEM part?
    thanks for the help!
    _______________
    omar
    2005 Elantra GT Hatchback - completely stock EXCEPT for the 139dba Stebel Horns
    Jan 2008
    144
    Default Re: P2626 Check Engine Code CEC.....need help and advice on parts
    anyone??
    _______________
    omar
    Tannersville, PA
    12,884
    im getting there...hold on
    open/short to ground or a bad 02 sensor....i would replace the sensor. its the first one (wideband) its super easy to get at aslong as you have an 02 sensor socket.
  5. #4
    Dec 2006
    Delaware
    7,286
    there are two one right off the top of the manifold and the second under tne car near the flex pipe.
  6. #5
    Jan 2008
    144
    so should i be going with the OEM or the Bosch exact fit from autozone?
    _______________
    omar
  7. #6
    Dec 2006
    Delaware
    7,286
    my 2cents go with the cheaper of the two, if they are about the same then go oem.
  8. #7
    Tannersville, PA
    12,884
    OEM!!!! do not go with aftermarket...o2 sensors are just like spark plugs, for some reason oem's work the best, hands down! and there are too many half year productions and updates to the 02 sensor. just take your vin number to the dealership. your looking at about 130 bucks. if you want shoot me your vin and I will get a price for you with my discount.
  9. #8
    Dec 2006
    Delaware
    7,286
    ^ take his word he would know better than me.
  10. #9
    Jan 2008
    144
    thanks only1db!! here is my, i mean the car's vin # KMHDN56D45U139098
    btw, i just unplugged the battery and put it back on and now i have no check engine light........
    is it ok to go on a round trip of 1800 miles on it right now, i leave tomorrow, head to sac and then back. what happens if the light comes back on during my trip, will this in any way hurt my engine?
    _______________
    omar
  11. #10
    Tannersville, PA
    12,884
    nope you'll be fine. usually what happens is that the sensor dies intermittenly and when it does for that couple of minutes the ecu will throw the code. once it pops it will staty there till you reset the ecu or clear the code (it will go away on its own but it would take months and lots of key cycles.)
  12. #11
    Jan 2008
    144
    thanks. well, let me know what the price is and we can go from there. thanks once again.
    btw, how do you reset the code or ecu
    _______________
    omar
  13. #12
    Tannersville, PA
    12,884
    my price is 118....dealers list is 170! ouch! let me know.
    you reset the ecu by either pulling the ecu fuse or by taking the negative of the battery like you did both work.
  14. #13
    Jan 2008
    144
    my check engine light is not on right now, so i just want to talk to you quickly if you can call me.
    sweet! i am going to ask you to get it for me and mail it.......or can i pick it up here and i pay you through paypal right way or something.....
    i am headed out to CA in exactly 2hrs from now. can you call me, i am going to pm you my number.
    interesting, i dont see the pm that i sent you twice now, so here is my number ----------see your pm
    Last edited by footprintsincon; 06-25-2010 at 04:45 AM. Reason: because songee623 was going to call me late at night :)
    _______________
    omar
  15. #14
    Dec 2006
    Delaware
    7,286
    ill be calling you in the late night hours im thinking around 2ish just kidding. might want to take that off after you talk to only1db.
  16. #15
    Jan 2008
    144
    LOL, i deleted. now that i know you will be calling late at night, i'll just unplug my phone
    only1db, we started on our trip and the light came back on. while we were standing in traffic, the mpg per the dashboard display started dropping fast, like 0.1mpg every 1 sec...., so we just turned around and headed back home and took the other car.....i am going to need that sensor for sure. just give me a call on my cell.......i appreciate the help!!
    _______________
    omar
  17. #16
    Tannersville, PA
    12,884
    its going to dropp while you in traffic...becuse your not moving. so it starts to average zero into the equation. its not a malfunction.
    i'll give you a shout after class 1pm my time.
  18. #17
    Jan 2008
    144
    thanks man for helping out!! the sensor is in and hopefully i will be fine!!!
    _______________
    omar
  19. #18
    Tannersville, PA
    12,884
    sweet...glad everything worked out.
