[XD2] A/C gets hot when car stopped
Results 1 to 9 of 9
Thread: A/C gets hot when car stopped
    Frickan Rican darkboricua has not yet proved knowledgeable darkboricua's Avatar
    Jul 2007
    Orlando, Florida
    186
    Default A/C gets hot when car stopped
    Hey guys, I have an XD2, with 83,555 miles on it. My A/C gets warm and starts blowing hot air when the car is not moving. Once it begins to move again it will begin to blow cold after awhile. Is my freeon low? Or what else can I check?
    Jul 2006
    3,782
    Default Re: A/C gets hot when car stopped
    Does both fans run when the A/C is on and is sitting still?
    smileymattj's Garage
    Oct 2004
    Redondo Beach, Ca
    4,862
    Yeah, sounds like a fan problem.
    Resident Leg Puller cuzimnotapimp has not yet proved knowledgeable cuzimnotapimp's Avatar
    Jan 2007
    idk
    411
    it could also be from low freon or the a/c compressor is getting weak and needs to be replaced, or as those 2 said, ya could only have 1 fan workin, but if you only have 1 fan running it would make the engine run warmer and you would see the gauge move, and not just feel the a/c get warm
    2003 Hyundai Elantra GLS 2.0L Auto Fully Loaded (Daily Driver Tuner)
    Quote Originally Posted by cbogg View Post
    Well, this didn't come out as ****ty as I anticipated. Not too bad hillbilly.
    EXD Pro Member exdtuner knows a lot about Elantras exdtuner's Avatar
    Apr 2006
    Jacksonville, Fl.
    4,751
    Likely a fan issue. My friend just had the same problem.
    Craig
    If i filled my gas tank with half Shell with V-Power, and the other half with Chevron with Techron gas...does that mean that my gas is V-TEC?
    Quote Originally Posted by moonlite5hadow View Post
    paul walker lives near all of us.
    Jul 2007
    Orlando, Florida
    186
    Yup, just checked tonight, both fans never stop spinning. ( Radiator Fans I'm assuming you are speaking of)
    ---------- Post added 08-03-2010 at 10:34 PM ----------
    I'm leaning towards that option now. Just have to wait until payday to buy some and find out. (the freon..that is)
    Near Chicago, IL
    15,223
    It has nothing to do with a fan. When you drop the engine RPMs, such as at a stop, the compressor spins at a lower speed. This compresses less A/C coolant, so there is less to decompress and cool. Want to test it? Put the car in neutral at a stop and give it some gas.
    I would think you need a recharge of the A/C.
    • Future: ????
    EVERYONE LOVES HYPNOTOAD! Gman knows about Elantras Gman's Avatar
    Columbus, Ohio
    1,361
    I have the same issue, but why would I be getting the same problem with HEAT in the winter. If I set at a light at idle the AC kicks off, and the same thing happens to the heat when it is cold out.
    Near Chicago, IL
    15,223
    First thought would be that the higher engine RPMs keep the water pump moving coolant through the engine and the heater core. Slow down the engine = less coolant to go through the heater core and provide heat. That's another set of issues. Things to check there would be thermostat, hoses, water pump, heater core. Do you still have the original T-stat? Those are wear-n-tear items that need to be replaced every so often.
    • Future: ????
