Where are the top of the rear struts on a elantra?
Results 1 to 7 of 7
Thread: Where are the top of the rear struts on a elantra?
    Junior Member Wbaldwin80 has not yet proved knowledgeable Wbaldwin80's Avatar
    Apr 2010
    Clifton Park, New York
    134
    Default Where are the top of the rear struts on a elantra?
    Looking to replace all four sides, need to locate the top retaining bolts in the rear.
    Soon to be Banned NovaResource knows about Elantras NovaResource's Avatar
    Oct 2006
    on your ignore list
    2,532
    Default Re: Where are the top of the rear struts on a elantra?
    1. Loosen the bolts holding the rear seatback and remove the rear seatback assembly.
    2. Remove the rear strut upper mounting nuts(3).
    3. Remove the wheel and tire.
    4. Disconnect the brake hose and wheel speed sensor wiring from the rear strut.
    5. Remove the stabilizer bar link.
    6. Remove the strut and carrier mounting bolts(2).
    Be careful not to drop the rear strut.
    7. Remove the rear strut assembly.
    Apr 2010
    134
    I did find this for a Tibb, is it the same or for an elantra?
    ---------- Post added 09-26-2010 at 05:34 PM ----------
    http://www.elantraxd.com/DIY/sands.php
    ---------- Post added 09-26-2010 at 05:35 PM ----------
    Do I have to remove the whole rear seat?
    I wanted to also change the fuel filter, may be a good opportunity to do both jobs.
    Oct 2006
    on your ignore list
    2,532
    Quote Originally Posted by Wbaldwin80 View Post
    I did find this for a Tibb, is it the same or for an elantra?[COLOR="Silver"]
    That's not for a Tiburon. That is installing Tiburon struts on an Elantra. The instructions and pictures are of an Elantra.
    You don't have to but it's easier in my opinion to just remove the whole thing.
    How many miles on the car? There's really no need to do it before 100K miles. But yes, if the rear seat is out you might as well change the fuel filter.
    Apr 2010
    134
    What am I looking at in the top pic, the one showing the top of the strut?
    Right above,
    "3. Remove the wheel and tire. "?
    Where in the car is this pic depicting? Is that the rear seat? Folded down or what? Its a bit confusing.
    Oct 2006
    on your ignore list
    2,532
    Might I suggest going to a mechanic?
    Yes, if you remove the rear seat you will see the upper rear strut mount. It is located behind the upper portion of the rear seat.
    Feb 2006
    Thomaston, CT
    5,781
    You can get those nuts off by just removing the seat side bolsters and folding the seat backs down as well, just going to be some tighter wrenching.
