[XD] Blown head Gasket
Results 1 to 5 of 5
Thread: Blown head Gasket
    Newbie Eastern NC has not yet proved knowledgeable
    Feb 2011
    Eastern NC Havelock
    2
    Default Blown head Gasket
    OK my daughter has a 2005 Elantra and it overheated and blew the head gasket.
    The mech said $3k to remove engine, replace head gasket, mill head, water pump, new bolts, and gaskets.
    I think this is outrageous.
    I plan on buying a manual, going to Auto zone and buying a head gasket, water pump, timing belt and replacing all of the above.
    Is there anything that I am missing, input welcome.
    Near Chicago, IL
    15,223
    Default Re: Blown head Gasket
    That price does seem outrageous. You could swap a whole different engine in for less than $3K. I'm sure someone will be along shortly with an estimate of what it SHOULD cost.
    • Future: ????
    Forced Induction Junkie TSmooth8403 has not yet proved knowledgeable TSmooth8403's Avatar
    Dec 2005
    Greensboro, NC
    518
    Total at my shop $1085. Thats removed, new head gasket, rebuilding the head, water pump, bolts, gaskets, front and rear seals, water pump, timing belt, labor and reassembly.
    I Make More Horsepower than my post count!
    Cause when the season starts, WE'RE RACING! It's no fun when you have to watch!
    Quote Originally Posted by TSmooth8403 View Post
    My shop would charge about $1100 to remove the head, have it checked for warpage, cracks, mill the head, check the block deck, replace timing belt with tensioner/idler wheels, water pump, thermostat/water outlet gasket, plugs/wires, front seal, and dyno the car after reassembly.
    Engine does not need to be removed for this. Doing a Honda Accord head at the moment.
    Feb 2011
    Eastern NC Havelock
    2
    1.1K is much more inline with what I thought was fair.....Thanks
