Automatic transmission slips only at high speed
Results 1 to 4 of 4
Thread: Automatic transmission slips only at high speed
    Newbie mostafaelgamal has not yet proved knowledgeable
    Mar 2006
    farmington Hills, MI
    4
    Default Automatic transmission slips only at high speed
    Hi,
    My Elantra 2001 (265K) automatic Transmission (original) randomly slips to to lower gear specially when going on high speeds e.g. 50 mph. I have to stop, then it goes to normal there after, it used to happen every few hundred miles, but now it's happening more frequent. Otherwise, shifting is smooth on all gears. Is that a transmission overhaul job, or maybe a sensor (e.g. speed sensor) or accessory part replacement. I've checked the oil level which is ok. I also drain and refill the transmission oil every 15-20 K
    any ideas my self for the past 100 K (used to do a transmission flush at the shop).
    Thanks in advance
    Where's My Boomstick? Tommy knows a lot about Elantras Tommy's Avatar
    Aug 2005
    Rock Hill, SC
    5,486
    Default Re: Automatic transmission slips only at high speed
    265k is pretty impressive for any automatic transmission. Sounds like time for a rebuild.
    Kick! Punch! Itís all in the mind
    If you wanna test me, Iím sure youíll find
    The things Iíll teach ya is sure to beat ya
    But nevertheless youíll get a lesson from teacher
    Mar 2006
    4
    I got the input and output speed sensor from a local ebay seller. will install tomorrow and write back after few days
    Full Member Catfish has not yet proved knowledgeable Catfish's Avatar
    Nov 2005
    Wuppertal, Germany
    476
    Quote Originally Posted by mostafaelgamal View Post
    Might be more helpful to get the valve-block overhauled!
Tags for this Thread
