[XD] Oil light and engine knocking
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
Thread: Oil light and engine knocking
    Newbie Chorty has not yet proved knowledgeable
    Jun 2011
    Rehoboth beach
    5
    Default Oil light and engine knocking
    Ok so here is the problem. I have a 2004 elantra with 114000 miles on it. I purchased the vehicle about 2 months ago and it was running fine until yesterday. I was driving home and I thought I heard a knocking noise but I wasn't sure. The car drove fine and wasn't showing any signs of a problem. When I was about to drive to work and I started the car. The knocking noise was def. Noticeable and the oil light was on. I immediately turned the car off and checked the oil level. It's fine. So... If anyone has any idea what could be wrong please respond.
    Poster God Aintnonerd has picked up a wrench Aintnonerd's Avatar
    Apr 2010
    Sarasota, FL
    1,569
    Default Re: Oil light and engine knocking
    How did the oil look? Was it kinda gummy or really dark?
    Quote Originally Posted by songee623 View Post
    nothing is ever simple on the interwebz!
    Quote Originally Posted by xAlvarox View Post
    someones misery is my laughter xD
    Jun 2011
    Rehoboth beach
    5
    Not at all. The oil looks fine. I'm pretty sure it only has 3000 miles on it. The guy said he just chAnged the oil when I bought it. When I checked it, it looked brand new. Now it looks slightly used but not bad.
    Apr 2010
    Sarasota, FL
    1,569
    Rod bearings, oil pump, or as weird as it sounds, the oil filter could be causing the issue. It sounds like the oil pressure is not what it should be. Someone correct me if I am wrong.
    Junior Member lycan28 has not yet proved knowledgeable
    Feb 2009
    Bronx,NY
    71
    Your crankshaft bearings ride on a thin layer of oil. That knocking sound mean that your engine is being starved oil. The past owner may not have changed the oil filter in a while. I would change that first and if it persists it may be the oil pump or time for a rebuild as the bearings may be worn and cause the engine not to maintain proper oil pressure.
    My Daily Driver:
    2006 Elantra GLS- Custom 2.25 Catback (No resonator)- Magnaflow Street Series Muffler #14829- HID's 6000k Diamond White-Custom SRI Intake- Interior and Exterior LED lighting- Eibach ProKit Springs- KYB GR-2 Struts,-Pillar Mounted SunproAir/Fuel Gauge
    Soon to be Banned NovaResource knows about Elantras NovaResource's Avatar
    Oct 2006
    on your ignore list
    2,532
    Correct. The oil light goes on for a loss of oil PRESSURE. If the oil filter is not an OEM Hyundai filter, change it and see if the problem goes away.
    Jun 2011
    Rehoboth beach
    5
    Ok, I just bought new oil and filter so I guess I'll attempt to do that first. Thanks for the input. I suspected oil pressure myself but I didn't know if it might be common or have an easy fix. Thanks
    Oct 2004
    Redondo Beach, Ca
    4,862
    When I worked for a GM dealer in Nashville, I did a used car inspection on a Dodge Durango. Everything looked fine, so I changed the oil and was done with it. Two days later it got towed back in with the oil pressure light on and the engine knocking. I checked the oil level and it was fine. Took off the valve covers and it looked like the covers were still on. The engine was sludged up. Putting fresh oil knocked some of the sludge loose and it got caught in the oil sump, starving the engine of oil. I would check to see if your engine is sludged.
    Jun 2011
    Rehoboth beach
    5
    I just put the car on jack stands and the oil pan has been removed before and it doesn't look like a professional has done the job. Mismatched bolts etc. So, I'm gonna do the oil change first and see what's going on with it but I'm not optimistic.
    Well I couldn't be so lucky as to have it be the oil filter. I just changed the oil and filter. Same noise same light!!!! Damn I don't know what to do.
    After turning the car on, the dip stick is still showing that the oil level is very high. I don't know if that means the oil pump isn't pumping or maybe there is something sludged up. I'm gonna pull the new filter and see if any oil has been circulated threw the filter.
    Ok well the filter is bone dry so... No oil is being pumped. I guess i have to drop this pan and see what I can see. Thanks for all the help.
    Apr 2010
    Sarasota, FL
    1,569
    Good luck, hope it isn't too bad.
    Jun 2011
    Rehoboth beach
    5
    Does anyone know of any tricks on removal of this oil pan? I've removed all the bolts. Who ever took it apart last used sum kind of liquid gasket and I'm having a hell of a time getting it off.
    Im better at video games ki11er90 knows about Elantras ki11er90's Avatar
    Apr 2011
    Alexandria, Va, 22306
    1,440
    Good luck, I am not one of the mechanically inclined people around here so I cant help you sadly
    But someone will be here soon to chime in.
    Where's My Boomstick? Tommy knows a lot about Elantras Tommy's Avatar
    Aug 2005
    Rock Hill, SC
    5,486
    Quote Originally Posted by Chorty View Post
    Make sure you've got all the bolts out, then knock it with a rubber mallet.
    Sounds like your oil pump went out. As stated above, poor maintenance, non-oem filters, engine sludge all likely culprits. Hope you didnt buy it from a friend.
    Kick! Punch! It痴 all in the mind
    If you wanna test me, I知 sure you値l find
    The things I値l teach ya is sure to beat ya
    But nevertheless you値l get a lesson from teacher
    Oct 2004
    Redondo Beach, Ca
    4,862
    If I remember correctly there were 2 threaded holes on the pan. Screw bolts into those and it will push the pan off of the block.
    Aug 2005
    Rock Hill, SC
    5,486
    Quote Originally Posted by ricerrx7 View Post
    I think you're right. Been a few years since i pulled mine.
  18. #16
    Tannersville, PA
    12,884
    yes there are...but i have used a rubber and a pry bar in the right place.
    and yes like other have said...the oil light is for pressure, so i would take the valve cover off too and look. if all of that is fine...then i would be worried about the CVVT filter. There is a filter between the block and the cylinder head....it prevents little things from getting into the cvvt motor, that could be clogged too.
    one thing to try is to drain all of the oil and put int 4 qts of sp III from the dalership...run it (idle ONLY!) for about 15 mins, this will clean out any of the junk if its not too serious. IF your real lucky you wont have to replace any of the bearings.
    btw rehobeth beach is the bomb!
  19. #17
    Dec 2006
    Delaware
    7,322
    Sorry i am of no help!
    But hell yeah some one else on here from the small state of Delaware score....lol
  20. #18
    Oct 2004
    Redondo Beach, Ca
    4,862
    I'm all about being safe, but I don't think a condom is the right tool for the job.
  21. #19
    Dec 2006
    Delaware
    7,322
    ^lol
    back on topic.
  22. #20
    Tannersville, PA
    12,884
    yeah sorry forgot the mallet part. LOL
