[XD] Radiator replacement- 2001 Hyundai Elantra
Results 1 to 5 of 5
Thread: Radiator replacement- 2001 Hyundai Elantra
    Newbie kev nemo has not yet proved knowledgeable
    May 2009
    Texas
    20
    Default Radiator replacement- 2001 Hyundai Elantra
    So the pepper trick worked for about a season and now it appears the crack has worked it's way down due to the 50+ 100 degree days here in Texas
    Found a replacement radiator at O'Reilly's up the road. These online instructions make it sound pretty easy:
    http://www.ehow.com/how_7403082_hyun...tallation.html
    Any tips, tricks, or dangers to look out for?
    Thanks!
    EXD Pro Member Leviathant can identify a wrench Leviathant's Avatar
    Philadelphia, PA
    1,275
    Default Re: Radiator replacement- 2001 Hyundai Elantra
    Study where the screw holes are on the new radiator. When I tried to replace mine, there were two screws I missed, and when I was wiggling stuff, I got a face-full of a/c refrigerant. It's my own fault for being impatient. I was able to leave my fans plugged in and just pulled them up and over.
    The screwhole in the bottom for draining your radiator? It's totally useless, might as well be made of wax. Set up a large container under your car, and drain the radiator via the bottom hose.
    Replace both hoses while you've got everything apart. Replace the radiator cap too, if you haven't done so recently.
    If I recall correctly, it boils down to 6 screws and two hoses. Just take your time.
    151,000 miles on my '01 Champagne GLS w/ Euro Antenna, OEM Wood Dash Kit, OEM Tiburon Gauges, KDM Card Holder, OEM Tiburon Clarion/Hyundai CD player, GT Tweeters, Mussa Strut Bar, 19mm Tiburon OEM Sway Bar. Pics & Details here, Maintentance log here
    7 psi tunned by poweraxel Matrixloader has picked up a wrench Matrixloader's Avatar
    Jul 2006
    san diego, California
    3,203
    replacing the radiator is very easy, is a simple job. should take a noob maybe 1 and half hr to do.
    this video might help
    http://www.youtube.com/watch?v=9uQpGse_g2w
    When I die, I want to die like my grandfather–who died peacefully in his sleep. Not screaming like all the passengers in his car.
    DIY : Paint Bezels and turn signals Black. http://www.elantraxd.com/forums/showthread.php?t=28188
    Junior Member lycan28 has not yet proved knowledgeable
    Feb 2009
    Bronx,NY
    71
    Wish I knew that it was that easy. I just had mine replaced last month. I had a hairline crack in the top by the inlet hose. I think it was the heatwave we had here in nyc that caused it. I was driving around a lot that weekend when the temps were above 100 F. I never used my A/C so much in the five years I had my elantra.
    My Daily Driver:
    2006 Elantra GLS- Custom 2.25 Catback (No resonator)- Magnaflow Street Series Muffler #14829- HID's 6000k Diamond White-Custom SRI Intake- Interior and Exterior LED lighting- Eibach ProKit Springs- KYB GR-2 Struts,-Pillar Mounted SunproAir/Fuel Gauge
    Quote Originally Posted by lycan28 View Post
    I just found a crack in the exact same place on my radiator Just shy of 150k miles. Engine temp still staying around 180-190F though. Gotta top off the coolant and get it checked out. I wish I had a garage to change it myself.
    Update - had it replaced, only $380 with parts, labor, and tax. They were done in about an hour.
    Jesse
    2006 Hyundai Elantra GT Hatchback 5-speed
    Clayton, NC
Tags for this Thread
