FUEL FILTER REPLACEMENT, 2009 Elantra SE
Results 1 to 3 of 3
Thread: FUEL FILTER REPLACEMENT, 2009 Elantra SE
    Default FUEL FILTER REPLACEMENT, 2009 Elantra SE
    Does anyone know how to replace a fuel filter on a 2009 Elantra SE? Pep Boys couldnt get the part in, and I know the dealership will charge and arm and a leg. Is it an easy DIY?
    Default Re: FUEL FILTER REPLACEMENT, 2009 Elantra SE
    It depends on if there is an access panel under the rear seat. The XD has the panel, but not sure if the HD has it because I haven't looked. The manual states you need to drop the tank, but I don't know if that is the only option to do that work.
    Thanks man - its hard to access so i'll probably just take it to the dealer
