Tire PSI
Results 1 to 8 of 8
Thread: Tire PSI
    Newbie BIGp has not yet proved knowledgeable BIGp's Avatar
    Dec 2004
    new jersey
    30
    Default Tire PSI
    hello all,
    what is the best tire psi for the 02 gls.the door panel says 30 for all tires.
    i guest it depends on the type of tire you using too...........
    or does it matter ?
    Countersteer forever SWortham has not yet proved knowledgeable
    Apr 2004
    Dallas, TX
    2,962
    Default Re: Tire PSI
    Usually with plus-sized wheels it's nice to run a little higher pressures because lower profile tires can typically support more pressure without bulging. And the extra pressure will help prevent sidewall rollover and potential wheel damage.
    But with OEM-sized tires 32 psi would be good. Or try 36 psi front / 32 psi rear as Bnystrom has said. The front tires hold 62% of the weight of the car, so it can help to inflate them more than the rear.
    Focus Hyundai Sales Rep. AvanteXD-CDN has not yet proved knowledgeable
    Winnipeg,MB,CDN
    137
    32 psi is a generally good all around...I like to run them at about 34 psi for fuel economy.
    you should also consider temperature. since you live in new jersey where its a little colder, you might want to inflate accordingly. lower in the winter, for good traction in snow. Higher in the summer.
    Senior Member dragonfighter60 has not yet proved knowledgeable dragonfighter60's Avatar
    Jun 2004
    Brighton, IL
    670
    The tire side wall says 38 cold on mine.... Is that normal?
    "If you don't stand for something, you will fall for anything." --Unknown
    Broke @$$ Fool BlackElantraGT has not yet proved knowledgeable BlackElantraGT's Avatar
    USA
    2,648
    If you go to the Yokohama tire website, they talk about tire pressure and one engineer had a basic general formula for figuring out what tire pressure to run. These are not the best settings, but they are ideal for most setups according to Yokohama.
    The formula was:
    (weight of car) / 100 = tire pressure
    add +2 psi for the heavier end
    if you're using stock suspension, add +2 psi all around.
    Senior Member jh0n has not yet proved knowledgeable jh0n's Avatar
    Dec 2004
    Queensland, Australia
    553
    Quote Originally Posted by dragonfighter60
    thats probably refering to the max load rating ie; you can carry so many pounds of weight at 38 psi cold.
    What red light where ??? Sledge has not yet proved knowledgeable Sledge's Avatar
    Feb 2005
    Ocala Fl
    125
    ok I used to do tre work for a living.
    go with the door pannel, unless you are loaded up and on a trip you can add 2-3 psi more in Other than that you could cause uneven wear to the tires or cause the car to ride rough.
