Can I install cruise control in my car?
Results 1 to 16 of 16
Thread: Can I install cruise control in my car?
    Newbie skipa has not yet proved knowledgeable
    Mar 2005
    San Diego
    1
    Default Can I install cruise control in my car?
    Hello, I'm new member of this community. My car is 2002 Elantra and it
    doesn't have cruise control. I want to install it as genuine cruise of elantra.
    Can I install cruise control with genuine hyundai cruise parts? If it is possible,
    I also want to know the parts that I must buy. Thank you.
    Oct 2004
    Redondo Beach, Ca
    4,862
    Default Re: Can I install cruise control in my car?
    It would be possible, but probably not worth it. You would need the steering wheel switch, cruise control module, cruise control cable, and any wiring harnesses to hook it up. I don't know if there's anything else you would need, but it probably wouldn't be worth it to do...
    Senior Member 2001GLS has not yet proved knowledgeable
    Mar 2005
    Windsor, Ontario, Canada
    785
    You can install cruise control. It's available as a dealer add-on I believe for vehicles that didn't come with it factory installed. Lot cheaper as a factory option. Not sure about the XD but most vehicles the cruise control kit is $150-200 & then about another $150 or so to get it installed. Only worth it if you don't want to get rid of your car & are going to be doing LOTS of highway driving. If your highway commute is under an hour each way per day I probably wouldn't consider it. If you're driving a few hours per day on the highway then I certainly would.
    hondahunter zhg411xd has not yet proved knowledgeable zhg411xd's Avatar
    Feb 2005
    layton, utah
    170
    from what i understand you can also get a aftermarket set up....im not sure how much they run but i know they have them.
    CAI, konig prophet wheels, Falken 451 tires, t.b. bypass, clutch mod, and magnaflow exhaust, new grille, aftermarket lights, debadged rear, tibby sway bar, NGK plugs, ported and polished intake, and hollow cat.
    Jun 2004
    Bellevue, PA
    3,538
    I'd suggest if you're consider adding cruise is to find out what parts you need from Hyundai, then find a totaled Elantra in a junkyard that has all the stuff and scavenge it.
    There's not too much to the cruise setup -- the harness might already be there but you'll definitely need the underhood controller unit and controller-throttle body cable as well as the steering wheel switch.
    Junior Member billydog has not yet proved knowledgeable
    albany,ny
    223
    they have aftermarket cruise control gizmos. I know audiovox makes one
    Former 01 GLS XD owner mrhoaf has not yet proved knowledgeable mrhoaf's Avatar
    Sep 2004
    Destin, FL
    1,873
    When I bought my base GLS I had the dealer install cruise as part of the sale. I thought the dealer would install OEM cruise in the car. Instead, they sent it to a local shop to have aftermarket cruise installed At first I was pretty dissapointed... I wanted it to look OEM. But I have to say that the cruise in this car (it's a 5-spd BTW) is absolutely the BEST cruise I have ever used. As long as you set it above 70, it will hold dead-on on all but the steepest hills....
    So... don't fear aftermarket cruise, but I certainly understand if you want the stock look.... I wish I had it....
    Traded in the XD on 6/24/06 for a 06 VW Rabbit 3-door
    Mar 2005
    785
    Does anyone have a photo of what the aftermarket cruise looks like installed?
    "Fully Sick".. Wel almost Yellow_Elantra has not yet proved knowledgeable Yellow_Elantra's Avatar
    Dec 2004
    australia
    75
    Hi i have a 2004 Elantra(aussie) and tried to get factory cruise installed
    but found out that if you do not have it installed in the factory
    then there is no wiring already in the steering wheel or anywhere else to
    just plug the parts into.
    i work at a car audio place and i ordered aftermarket cruise from one
    of our suppliers and installed it myself. the controlls are mounted on
    the wheel and it uses the horn wire to send the signals to the cruise
    controll module.
    this is the best cruise i have ever used and all up it cost me about
    [AUD]350[/AUD]
    My car member page is: http://www.elantraxd.com/forums/showthread.php?t=4516
    The following Photos are:
    Pic 1= Steering wheel with the controlls mounted to it
    Pic 2= Close up of Controlls
    Pic 3= Actuator mounted under the bonnet on right hand side
    Pic 4= Throttle linkage to the motor
    Jun 2004
    Bellevue, PA
    3,538
    Nice aftermarket unit... looks almost stock.
    Yeah, if the harness isn't there for the factory cruise I agree that an aftermarket unit would be your best bet. It'd be a major pain if you had to change the harness or contacts in the steering column to accomodate the factory cruise unit.
    Junior Member archywills has not yet proved knowledgeable archywills's Avatar
    Nov 2004
    Louisiana
    166
    Quote Originally Posted by mrhoaf
    I did that too. Mine was is a "stick" type of cruise thing-a-bob. You have to be a contortionist to see the stick. I have had to learn to operate by feel. OMG...and don't push the clutch in before you tap the brake to disengage...I was disappointed too. But I love cruise. Cost was $200 installed.
    Jun 2004
    Bellevue, PA
    3,538
    Quote Originally Posted by archywills
    I...and don't push the clutch in before you tap the brake to disengage...
    Huh... the aftermarket cruise units don't always disengage when you push in the clutch? The XD factory cruise cuts out when you use the clutch. There should be a microswitch added that triggers to kill the cruise when the clutch is installed -- it's probably an extra-cost option on the aftermarket cruise control systems specifically for manual transmission cars.
    That's a good thing to know.
    Nov 2004
    Louisiana
    166
    Mine doesn't disengage when clutching (have to brake first). Every now and then I forget and send the RPM revving way up.
    Mar 2005
    785
    Yellow Elantra, do you know the manufacturer of your cruise control kit? It looks pretty good for an aftermarket one.
    Dec 2004
    australia
    75
    I have installed a clutch swich with my cruise, so i dont have the over rev problem.
    My cruise came from auscruise http://www.auscruise.com.au/ or http://www.autron.com.au/
    Specific page: http://www.autron.com.au/newweb/index1280.htm
    this cruise is not just set for australian cars, is has an auto diaganostic mode that senses the speed pulses and sets the cruise module to your car
    i can see no reason why this would not work for any type of car in any country
  18. #16
    Newbie Cambo2124 has not yet proved knowledgeable
    May 2011
    Queensland Australia
    2
    Hi,
    New to the fun of DYI in the car (except for the near 20 mp3 players my family has asked me to install......irrelevant) looking to put an Aftermarket Cruise Control kit into my "04 Elantra (Auto Transmission) and just wondering how hard it is and an approximate idea of costs for a decent kit.
    FYI I'm an Aussie, so preferably something I can get here without having to pay heaps for shipping
    Thanks, Cam
