Gauges...
Results 1 to 10 of 10
Thread: Gauges...
    Car
    2002 Elantra GT
    Nov 2004
    Quebec, Canada
    17,346
    Default Gauges...
    Alright,
    I've got a voltmeter and an a/f ratio gauge here...
    Voltmeter: some people say to attach directly to car battery, some others do it on the dimmer switch. Which one?
    A/F Ratio: I know you guys say that the wires to be tapped in are under the footrest. I haven't looked, but which are the ones that have to be tapped in?
    Thanks! (I tried searching a bit but couldn't find this, I KNOW it's been spoken about somewhere I just couldn't find.)
    '02 Elantra GT
    '04 Suzuki Katana 600
    Elantra XD
    Car
    04, Elantra.
    Jul 2004
    new ringgold
    6,915
    Default Re: Gauges...
    for the Volts find the ignition wire that goes to the radio. I will search for the A/F
    Car
    2002 Elantra GT
    Nov 2004
    Quebec, Canada
    17,346
    Ignition wire... as in, the 12v power that goes to the radio? thanks.
    '02 Elantra GT
  5. #4
    Car
    04, Elantra.
    Jul 2004
    new ringgold
    6,915
  6. #5
    Car
    2002 Elantra GT
    Nov 2004
    Quebec, Canada
    17,346
    that a/f ratio looks like a PITA, I'm pretty sure I read something about the o2 wires being run under the footrest or something similar. Then again, would it be the same color wire used? (green?)
    alright.... I found out that it's ECU #43. Now, WHERE IS THAT?
    I'm just soo bad when it comes to electronics
    '02 Elantra GT
  7. #6
    Car
    2002 Hyundai Elantra GLS
    USA
    73
    I have not tryed to install an A/F myself, but I have read that all hyundai's use a narrow band sensor, and you need a wide band sensor to use an A/F gauge properly. I'm not sure what type of gauge yours is, just sharing what I read.
    Help me get my FREE IPOD
  8. #7
    This post I started a while back has some screenshots and a little bit of info on getting to the ecu (where the wires are located at to be tapped)
    http://www.elantraxd.com/forums/showthread.php?t=7060
    !!! Jattus Ground Wire Kit Groupbuy Going on !!!
    -New Jattus Turbo Kits Now Available (Dynoed At 242whp At 12psi)! www.jattus.com/Performance/home.html
    -2004 Silver Hyundai Elantra GT Sedan Turbocharged at 24psi
  9. #8
    Car
    2002 Elantra GT
    Nov 2004
    Quebec, Canada
    17,346
    Gauge is for narrowband sensors.
    Mahonroy, alright. question: would you suggest me to splice into the wire itself, or just slide the wire inbetween the connector and the ECU (make it warranty friendly)?
    '02 Elantra GT
  10. #9
    Well, thats a tough one... when I was making my device, for testing purposes I just slid a wire into the harness...its way more pain in the *** than it sounds trust me, first off you have to have a really small gauge wire, secondly you have to bend the wire in a really wierd shape to get it to slide into the harness and not get pulled out when you slide the clip back in. and third you risk reliability doing this, as those small wires tend to break really easily, IMO I would say do it the right way and just tap off one of the wires comming off the ECU. As long as you do a good job you have nothing to worry about, and you can always unattach it later (besides, unless your ecu cooks, there is no reason why you would need to worry about a warrenty there). I would locate the wire, strip out a section wide enough so that you can wrap the air/fuel guage wire around it, saulder the connection, and then shrink wrap it.
  11. #10
    Car
    2002 Elantra GT
    Nov 2004
    Quebec, Canada
    17,346
    alright, sounds like a plan, thanks!
    '02 Elantra GT
