headlight adjustment!
Results 1 to 15 of 15
Thread: headlight adjustment!
    Senior Member tricked03gls has not yet proved knowledgeable tricked03gls's Avatar
    Scottsdale Arizona
    683
    Angry headlight adjustment!
    does anyone know how the hell to adjust the damn headlights on our cars, they are such a pain to put in and i dont have the slightest on how to adjust the stupid things! (as in they are to high and dont put enough light on the road)
    MODS: TRADED FOR LAND ROVER
    EXD Pro Member zx2uner has not yet proved knowledgeable zx2uner's Avatar
    Jun 2005
    Fargo, North Dakota
    2,058
    Talking Re: headlight adjustment!!!!!!!!
    If you have the owner's manual, it's in there.
    Otherwise, if you look behind each headlight up towards the frame rail there's little metal discs that have philips head screws in them, these actually do the adjusting, but use the philips on the head, cuz you'll loosen the discs. I just wanted to give you an idea where the discs are located on the headlight. To adjust these discs, you'll see on the front frame rail/radiator support, there is a hole next to where the prop rod mounts and two holes where the prop rod rests when the hood is down. All you have to do is stick a medium size philipd down there and turn it, as you turn it, if u look at the little metal discs, they should spin.
    Thanks for being a knowitall Alex.
    DON'T PANIC! Atomic has not yet proved knowledgeable Atomic's Avatar
    Nov 2004
    North Glendale, Arizona
    486
    Default Re: headlight adjustment!!!!!!!!
    There's little caps that look like you can unscrew them on the back of the headlight, but they just keep turning, that's what you'll use. Found it out the hard way, I f'd up the direction of my drivers side headlight thinking that was a screw I had to remove to open the headlights, lol.
    I just pulled up to my garage with the door shut, picked out a center line on the door and lined my headlight up with that, seems fine now.
    2006 Santa Fe
    Scottsdale Arizona
    683
    thanks guys...and atomic we still got to chill bro
    Newbie davidst has not yet proved knowledgeable
    Nov 2006
    Pearland Tx
    19
    A picture is worth a thousand words I will post some when i figure it out
    Car passed inspection only because the could not figure it out
    Jul 2006
    3,782
    http://www.elantraxd.com/forums/sear...archid=1529979
    your fixing to get the search committee
    smileymattj's Garage
    May 2005
    Mahanoy City, PA
    6,582
    WWWWOOOOOWWWW!!!!
    Holy 3 and a half year resurrection Batman!!!
    It would be obvious that the person above you actually did use the search function, to resurrect something this old. But why post pictures in a thread that's this dead, and with current pictures available in current threads?
    Jul 2006
    3,782
    lol didn't pay attention to the post dates.
    Newbie orion has not yet proved knowledgeable
    Apr 2006
    Glastonbury Connecticut
    11
    still looking for the thread that shows some pictures. I tried this last night, admittedly in a hasty fasion. there isn't a screw in the framerail hole near where the hood prop is bolted, there is just something that looks like the teeth of a gear, but it's a very thin flat gear, i'm having trouble getting the philips head to get any purchase on those teeth, am i looking at the right area? should i just keep trying different screwdrivers untill i can find one that works? and what about the screw that faces the engine of the car? does that need to be loosened? or does that just hold the "disc" rotating assembly to the side of the car.
    Soon to be Banned NovaResource knows about Elantras NovaResource's Avatar
    Oct 2006
    on your ignore list
    2,532
    What year Elantra?
    Poster God Aintnonerd has picked up a wrench Aintnonerd's Avatar
    Apr 2010
    Sarasota, FL
    1,569
    If I can recall, the're 2 screws(at least the look like screws) on the back of the headlight. You can fit a normal Philips head screwdriver in them and turn, those are you headlight adjustments. I raised my lights up just a hair, and now I don't have to use high beams that much anymore. And no other people don't high beam me while driving at night and the cops don't seem to care either. Figured I would try that first rather than buying super white bulbs or converting to HID bulbs.
    Quote Originally Posted by songee623 View Post
    nothing is ever simple on the interwebz!
    Quote Originally Posted by xAlvarox View Post
    someones misery is my laughter xD
    Newbie weaver has not yet proved knowledgeable
    Mar 2007
    eBurg & Tacoma
    29
    Quote Originally Posted by orion View Post
    I didn't have to touch the screws that faced the motor, they turn when you turn the little gears accessed from the top. Mine turned fine with just a #2 phillips.
    Feb 2006
    Thomaston, CT
    5,781
    You need a shorty phillips to get in behind the battery without taking the headlight out. Feel along the top of the back of the headlight housing for the unmistakable cross airs of a phillips screw. The one closer to the high beam side is for up/down, the one over the low beam is for left/right. This will adjust both high and low beam projection.
    Thanks bdiggy! I thought each screw adjusted dim and bright up and down. It didn't occur to me that one was left-to-right. No wonder I wasn't making any progress!
    Great post. Thanks for the help.
    Roger
    Newbie aoeu88 has not yet proved knowledgeable
    Sep 2011
    Arizona
    1
    bdiggy! another big thanks. created an account just to say this. With your picture and help, I was able to adjust the up/down pretty easy (most important). I'm having a tough time accessing the left/right but that's not as big a deal.
