if you powershift (L23D) then you will overheat the tranny very quickly, and cause it to become too hot after doing that more than 2x. if you want to do that, get a tranny cooler asap. but that would be a good idea, since it gives you a bit more control over the shift points of the car to a certain extent. and if you do powershift, dont take your foot off the gas, just keep shifting so the car doesnt hiccup as much when launching.
You can load the brake for better grip so you can launch at a few higher rpms without slipping... Brake in N, and then rev the engine and your brake pedal should sink a little lower. Then you can shift into gear and rev it. But yeah, don't sit there at the tree and have it revving while you wait, or you'll mess up the torque converter quicker.
when i sprayed at the track, i left it in D. get the rpm's up to about 3000 while holding the brake pedal hard, then launch. but i also sprayed right out the whole. i didnt like the whole idea of shifting from L23D as i bounced it off the rev limiter a couple times.
Not all cars are faster messing with the shifter. Ive known atleast 3 diffrent cars that did better left in drive. I know just as many that are faster "manually" shifting.
Interesting...I didn't know that. Now by all cars, you mean it differs from each individual car even if the same make or between different manufacturers?
My best friends Grand Am (gone now) = Lost .2-.3 secs in the 1/4 screwing with the shifter
Another friends Eclipse v6 did .1-.2 better in D
Then I knew a saturn that ran a tenth or so faster in D
On the other side I know someone with a carolla thats slow as dirt in D. "shift it" and it gets alot faster.
My wifes Mazda5 is faster in "manual" mode, but thats also because itll turn another 500rpms in +- then it will in D
I think it depends on how well the tcm is programed and how the trans is built. Id go buy what other owners of the same make/model have done, but still do a lil testing on your own car to see what it likes.
Anyone in SoCal want to meet me at Irwindale Speedway then? =) They open their strip on Thursdays. My work schedule right now doesn't permit it, but hopefully soon that will change.
Like I have searched on NT, and they some of those guys have said that they ran slower times shifting, than just leaving it in D. But it just seems a little faster when shifting, but most of the power is at the lower RPMS (i think), so I dunno.
Im starting to think it may be something to do with my traction. Im at 63K miles, and Im still on my stock tires. I have maybe a 1/4" of tread on my fronts (one Kumho, and one Phaser,) and even less on the back. If you compare the two, my first one is actually beating me by ~.2 in the 60', then ~.1 in the 330'. By the 1/8, Ive pretty much caught up.
Im thinking about maybe setting the putting back to stock. And going down to Capital. This isnt making any sense.
The thing is, I know the power is there. (Comparing the two slips) By the 1/8, I was able to make up the .2 I lost in the 60'. At 1/8, we are pretty much even. By the end of the 1/4, Im up by .3 seconds. So in total, I went from being .2 under, to .3 ahead.
I think your problem is the fact you have an autotragic like me... with all those mods you should be beating 16 secs with a manual...
Natural Aspired on an XD ESPECIALLY an autotragic is not cost effective... (thanks for being another example of why) F/I is the only way to go Perhaps the only way youll get lower numbers is with nitrous, thus all your mods would be helpful then.
Doing worse in the "low end" means you must of lost some low end torque in exchange for high end Hp, the only way youd know is if you did a before and after dyno.
You gotta remember, small engines with N/A = not much gains unless you have some crazy tuning or timing system (Vtec)... this is why the EVO and the STi and the GolfR32 all come turbo with their comparable sized engines.
I'm not aware any car left in D capable of redlining. The whole purpose of the tranny in D throughout the gears is that it shifts at a safe and fairly economical point. If the car shifted at redline at every gear when left in D, there wouldn't be a need for much else...
I guess I don't grab throttle a lot when it's in D. I almost always do it shifting to get the maximum runout on every gear. Ya learn something new everyday I guess.
yeah thats what he said when i talked to him after he ran both times...i was like, ...jim...we have a guy running 10.90s in a formula firebird here in town that only pulls 1.7-1.8 60's
Doing worse in the "low end" means you must of lost some low end torque in exchange for high end Hp, the only way youd know is if you did a before and after dyno..
Honestly, I think its because of this cam gear, that I lost low end. Ill try to get it put back to stock, which will put me pretty much even (in mods, other than my udp) with Odessit auto's 16.5 hopefully.
yeah .003 off from ya. oh well. i know i could've had ya cause i bogged it off the line on the good run. i know i could've dropped another tenth off had i stayed but oh well. i really don't care.
I had a feeling the car had more power stored away somewhere.. so I decided to tune the cam sprocket.
I bought this sprocket on ebay for $70 new and i had fooled around with it and never really had good results... So it was time to do something about it...
I strapped the car down and gave it a baseline run... the diff from this dyno & the previous one was only 1 whp which is a perfectly acceptable variation.. green line : 131.9 whp & 126.2 ft.lb..
After the baseline, i advaned the cam sprocket by 2 notches on the gear which = 4 degrees of crank advance...
This yielded 2 whp gain & 2 ft.lb wtq gain ...
So i went back and advaned it 2 more notches, for a total of 8 degrees of crank advance...
The results were good, lost .2 hp but gained 2 more ft.lb of wheel torque so i stopped messing with it and locked it down..
the results ? A total of 2 hp gain and 4 ft.lb wtq !!! (133.2 hp & 130.6 ft.lb wtq BLUE LINE )
^ that quote is from fords dyno thread. 4 lbs tq increase with sprocket advanced.
