STS rules... How do they know?
Results 1 to 7 of 7
Thread: STS rules... How do they know?
    j rod jrod13 has not yet proved knowledgeable
    Oct 2004
    Minneapolis
    522
    Default STS rules... How do they know?
    So I plan on running STS next year. I have a Centerforce Dual Friction clutch, and a Fidanza flywheel. Obviously these aren't allowed in STS. How would they know though??? Not like they are going to pull bellhousing off to check. Is it just them trusting me?
    And what class would that put me in? I'm assuming one that would get me slaughtered. I don't have any cats right now, but I still have both of the stock cat's sitting in my garage, so I'm not too worried about that.
    Columbus, Ohio
    12,676
    Default Re: STS rules... How do they know?
    im not sure how they would check, but i think they would go on an honor system.
    I'm sure if we started winning and someone cried foul play they would check but hey thats just my opinion.
    Oct 2004
    detroit
    3,820
    dont be a fcking scammer and cheat to win. sts racing is supposed to be fun and honest. be a man, and dont cheat to try and win. so what if you dont win, its all about the fun of racing
    Countersteer forever SWortham has not yet proved knowledgeable
    Apr 2004
    Dallas, TX
    2,962
    I didn't realize this wouldn't be allowed in STS so you got me curious.
    Here's what I found in the 2006 rulebook...
    Stock category
    Alternate components which are normally expendable and
    considered replacement parts (e.g., engine and wheel bearings,
    seals, gaskets, filters, belts, bolts, bulbs, batteries, brake rotors,
    clutch discs, pressure plates, suspension bushings, drivetrain
    mounts, etc.) may be used provided they are essentially identical to
    the standard parts (e.g. have the same type, size, hardness, weight,
    material etc.), are used in the same location, and provide no
    performance benefit. The allowance for use of such replacements
    does not include camshafts, differential covers, or ring-and-pinion
    sets, nor does it authorize the use of piston rings having different
    configurations (e.g. “Total Seal”) from those of the original.
    And then Street Touring (STS) has the same stock allowances in this regard. I didn't find any allowances for clutch "upgrades" until the Street Prepared class...
    Street Prepared category
    Any metal clutch assembly, metal flywheel or metal torque
    converter that uses the standard attachment to the crankshaft
    may be used. Non-metallic friction surfaces (e.g. clutch disks)
    are permitted.
    Dowel pins may be added. Any hydraulic clutch
    line may be used. Minor repositioning of the clutch slave cylinder
    is allowed to accommodate the alternate clutch, but the unit
    may not be relocated and the repositioning may serve no other
    purpose. This allowance does not permit the substitution of
    slave cylinders or the use of non-original methods of clutch
    actuation (e.g. pull type versus push type).
    So if you wanted to be legit you'd have to be in FSP. Although nobody would care if you're just competing at local events, especially since you won't see a big benefit from it in your times anyway. The only place it might be contested is at nationals. Although honestly, I doubt anyone would care there either because the '89 Civics dominate STS every time.
    In the end you may actually have a more competitive chance in FSP assuming you buy R-compounds.
    Oct 2004
    Minneapolis
    522
    Yeah I don't have the money to go buy R compounds. I wasn't even thinking about auto x when i did the clutch and flywheel. Not that our stock clutches are good enough to support this driving in the first place. Slippage ftl!!
    And to the guy telling me to be a man, and not a scammer. Go fly a kite dude. I was asking a question, and that question didn't involve asking for your negative opinions or you calling me names. I am trying to be legit that is why I am asking these questions before I get involved this summer.
    Quote Originally Posted by 2loud2k2xd
    Hey mister my hormones are outta check shut the hell up he didnt say anything about trying to cheat he was curious as to the requirements a lightwheight flywheel and better clutch aint gonna make any worthy advantage it's merley for longevity .
