Re-Programming the remote.
Results 1 to 15 of 15
Thread: Re-Programming the remote.
    Default Re-Programming the remote.
    The remote for my newly purchased 2004 Elantra does not work. The red light on the remote flashes when buttons are pressed but nothing happens. As expected, the Mom-n-Pop used car lot knew nothing about the history of the car. The car has a brand new battery so I suspect the loss of power may have lost the programming connection. Anybody know the secret recipe to re-programming?
    Junior Member Killride has not yet proved knowledgeable Killride's Avatar
    May 2007
    Phoenix, AZ
    126
    Default Re: Re-Programming the remote.
    yeah... the recipe is $80 at the dealership.....
    I lost one of my remotes and I wanted to replace it.... just to find out that I couldnt figure out how to do it.......
    Sparta, NJ
    6,437
    on 2004 and up models you need a hyundai scantool to reprogram.
    you have to go to the dealership
    MySpace/Facebook
    Keyan.
    You are my ****ing hero.
    Oct 2005
    Fort Worth, Texas, USA
    3,334
    Check to see if the hood switch is working. It is on the passenger side of the engine compartment next to the fender, about halfway back. 4 out of 5 dentists find that this switch not being closed is the reason for the remote not to work. The alarm won't arm the alarm if the hood, trunk or a door is open. Check all the switches on those.
    And like I said in the other thread, join the local board. If you do need it programmed, I bet if you get on real good terms with a guy named "Fixer" he'll do it for free or cheap (he's a tech and a Hyundai dealership in Arlington.)
    Oct 2004
    Redondo Beach, Ca
    4,862
    The hood pin won't cause the door locks to not function.
    Ultimate Post Whore 04 elantra cvvt has not yet proved knowledgeable 04 elantra cvvt's Avatar
    Georgetown, Texas
    3,501
    Quote Originally Posted by ricerrx7 View Post
    That is right. The locks will still function, it just won't arm the alarm.
    Tannersville, PA
    12,884
    Quote Originally Posted by Keyan View Post
    any car with the remote including 01 models and up...
    you need to have it reprogrammed at the dealership.
    Sparta, NJ
    6,437
    your f'ing kidding right?
    we all KNOW there is a DIY for reprogramming the 01-03 remotes
    MySpace/Facebook
    Keyan.
    Veni, Vidi, Velcro Munky has information that can be trusted Munky has information that can be trusted Munky's Avatar
    May 2006
    Noblesville, IN
    10,969
    And yet again, you're wrong. I've done it myself, along with many others.
    http://forum.crookedh.com/showthread.php?t=2133
    Oct 2004
    Redondo Beach, Ca
    4,862
    Wow dude...
    Near Chicago, IL
    15,223
    01-03 you can do yourself.
    04+ you need the dealer.
    • Future: ????
    Poster God mtlelantra knows a lot about Elantras mtlelantra's Avatar
    Oct 2004
    San Francisco Bay Area
    1,947
    Another 01-03 DIY: http://www.elantragtclub.com/elantra/id309.html
    So with your 04, if the remote is indeed programmed, it should at least do something (lock/unlock) if you press the corresponding button, regardless of the state of the doors/trunk/hood.
    If it does nothing at all (try all the buttons) and the light on the remote is blinking, then it's not programmed into the ETACS and for 04+, you need the dealer (or someone with a scantool who knows what he/she is doing) to program the ETACS to accept the remote. If you have more than one remote, you need to bring all of them in. I'm pretty sure like the 01-03 that you have to program the ETACS to accept all the remotes at the same time, and that old stored codes get erased at the same time.
    BTW- in all MY, you're programming the ETACS to recognize the code that the remote is sending... you're NOT programming the remote itself.
    I'm not sure about the 01-03, but the 04-06 have a "dual stage" arming system. Press the lock button once, it'll lock everything. Press the lock button again within ~4 seconds of the first press (like a slow double-click) and the ETACS will check that everything is secure (i.e. trunk closed, hood closed, all doors fully latched). If everything is, it'll chirp. If something is still ajar (e.g. trunk popped), it will NOT chirp which means you should have a look-see to see what's open. If you confirm that everything is closed properly and you still don't get a chirp, then do what Doohickie recommended and check the sensors... usually it's the hood sensor that's not being pressed down far enough with the rubber bumper and you'll have to MacGyver it.
    2004 Hyundai Elantra VE 2.slow
    One of the few 138 HP ULEV XD2s in California.
    EXD Pro Member jalmir knows a lot about Elantras jalmir's Avatar
    Oct 2004
    Back in Canada bit**es!!! :D
    4,501
    wow ... I don't even have an XD and I know it's not true!
    so fwjames, as other said you'll have to go to the dealer.
    Two weeks without the internet and Sean is still the biggest piece of crap around.
    Former Scoupe addict PanciLaan has not yet proved knowledgeable PanciLaan's Avatar
    Aug 2007
    Holland
    324
    Hey if you will go to a dealer.
    It should max cost em about 5 minutes.
    They just have to look up the other cable for the learning procedure.
    Then it's in the car with the Hi-scan or GDS and 20 secs later they're finished.
    If the dealer charges $80 for programming it, damn they're crazy
    I've done it a lot at work, so I know what I'm talking about
    (The DIY also works on older Santa Fe and Trajet, which got the same ETACS type with the switch)
    Also what is being said about door,hood and trunk switches is true.
    Check if they work, if the light on your dash go on if one is open, then it's working
    Tannersville, PA
    12,884
    ^ lets not forget that they have to pay a rediculous amount for the gds unit itself...
    and to be honest...i never saw a diy for doing the remotes....my bad.
