What do you run for alignment?
Results 1 to 11 of 11
Thread: What do you run for alignment?
    j rod jrod13 has not yet proved knowledgeable
    Oct 2004
    Minneapolis
    522
    Default What do you run for alignment?
    I am starting this thread because I am curious more then anything. State your setup what class you run, and what your alignment is spec'd to.
    setup
    03' Tiburon GT strut housings
    Koni adjustables for said year of Tiburon
    Tiburon lowering springs
    22mm rear adjustable sway bar (set to stiffest setting)
    17" Enkei wheels with 215/40/17 Falken Azenis RT-615 tires (been running around 40 psi in them)
    Eibach eccentric camber bolts both front and rear
    I am running STS class. Been doing fairly well. Car is going to be more competitive then I thought now that I got the all the adjustable stuff figured out.
    Basically I am more curious as to what people are running for camber.
    I am running -2.08 in the front, and -1.90 in the rear. With the sway bar it turns in beautifully, and doesn't push at all. Very neutral setup. If anything it oversteers.
    Oct 2004
    Redondo Beach, Ca
    4,862
    Default Re: What do you run for alignment?
    I don't run autocross, but I set mine up to -1.2 rear, and -0.5 front. Eibach springs, and 19mm tib rear sway. It's pretty neutral going into corners.
    I don't regularly autocross either but mine is set -.5 in the front and -1 in the rear. It responds well for a stock suspension.
    Oct 2004
    Minneapolis
    522
    You guys should maybe try running more negative in the front then in the rear. It will make for a bit better turn in. Although it could potentially cause for a bit more oversteer. Just a thought.
    Ultimate Post Whore BColeman knows a lot about Elantras
    May 2005
    Mahanoy City, PA
    6,582
    Actually, a bit more Toe In would make for better turn in, not the camber. The camber would only help settle the car through the turn, not into or out of it.
    EXD SupaMod Ugzz knows a lot about Elantras Ugzz's Avatar
    May 2006
    Pittsburgh
    9,897
    jrod13:
    size weight: 17" einki with 40psi
    class: sts
    alignment: -2.08/-1.90
    mods: sway bar, lowering springs
    Ugzz:
    size weight: 6ft 4in / 240lb
    class: fighter
    alignment: 25% evil
    mods: +1 mace / fire ring
    Internet Jesus is not pleased with the absense of the chatbox.
    And he stated, "let the people speak, and I shall grant thee speed". Microsoft Sam 11:17
    Veni, Vidi, Velcro Munky has information that can be trustedMunky has information that can be trusted Munky's Avatar
    May 2006
    Noblesville, IN
    10,969
    Quote Originally Posted by Ugzz
    Ugzz:
    class: fighter
    alignment: 25% evil
    ^ Geek.
    May 2006
    Pittsburgh
    9,897
    just had to do it.. and i honestly never even knew people ran different alignments for that kinda stuff. i knew they did for like professional rally n such.. learned that from a game also.. damn, maybe i am a dork?
    ok, ill stay out of this thread now casue i obviously have nothing to tribute but i shall read and learn
    Indiana
    11,228
    Waiting on the fundage for the frt camber bolts, so right now my 'kooks are getting a severe beating on the outside half of the tire.
    225/45/16 RS-2 Hankooks. Currently about -.8 in the front and about -.9 in the rear.
    May 2006
    Pittsburgh
    9,897
    if i get a standard alignment can i ask them for these numbers?
    Oct 2004
    Redondo Beach, Ca
    4,862
    Sure, if you go to a good alignment shop. You'll need to purchase camber bolts in order to have them change the numbers to what you want though.
