Do you agree: Stock brakes=garbage?
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 21
Thread: Do you agree: Stock brakes=garbage?
    Default Do you agree: Stock brakes=garbage?
    Well for those of you that have been following my updates about my accident, its all done. The lights arrived and the car is running down the road as well as ever. But my brakes still are awful.
    Most people that drive my car say the brakes are weak, and i agree. I think they have always been so, but am not sure. For those of you that have OEM brakes, or remember what it was like when you had OEM brakes, what is your opinion on them?
    Also, if you think that the brakes are good and i am an anomoly, what do you think could be the problems.
    I am also considering upgrading the front disks to the tiburon brakes which are a bit bigger.
    FYI: I have stock wheels, new pads and good tires.
    Oct 2004
    Redondo Beach, Ca
    4,862
    Default Re: Do you agree: Stock brakes=garbage?
    I thought the OEM brakes worked quite well for what they were designed to do. What exactly is your problem? Mushy pedal? Long stopping distances?
    Might just need to bleed your brakes...
    19 second madman tharptroy has not yet proved knowledgeable tharptroy's Avatar
    Dallas, TX
    2,506
    my brakes work fine.
    "Setting up your car for autoX is like tuneing your car for parking." -liveforphysics
    Senior Member cobase has not yet proved knowledgeable
    Aug 2004
    Beltsville, MD
    708
    I remember the brakes on the GT (4-wheel disc) got good reviews. One review magazine got 127ft 60-0mph, which is very good. I wouldn't say I was ever unhappy with the brakes (maybe the stock tires weren't the best performers though). I'm happy with my current Hawk pads now.
    mostly mushy pedal/lag when braking.
    I know the amount of fluid is good, you think there might be air in the lines or something?
    Think bleeding them will fix them up?
    Oct 2005
    Fort Worth, Texas, USA
    3,334
    I'm still running OEM brakes coming up to 40k. They are getting low on the rear discs, but no squealers yet. They felt a little funny when the car was new, but they've been fine once I got used to them.
    Call me J xdforme22 can identify a wrench xdforme22's Avatar
    Apr 2006
    Pennsylvania/Michigan
    1,978
    I think I would try bleeding the brakes. You might have some air lurking in there yet.
    Quote Originally Posted by Bobzilla
    But if it ain't broke, don't fix it is my old motto. Unfortunately that got replaced with: Break it so you can fix it sooner.
    Sparta, NJ
    6,437
    bleed the brakes and adjust the rear drums. does your e-brake pull high?
    MySpace/Facebook
    Keyan.
    You are my ****ing hero.
    i agree... stock brakes suck balls.... mine feel very weak... i have to press alot harder to get it to stop.... its a pain in the ***.... i might b doing a upgrade to them tho for the summer time, steel lines, rotors, and ceramic pads. till then its w/e... :/
    mine work great
    My XD brakes worked fine. My HD brakes are better because they are nearly 11 inches.
    I've got 4 wheel disc and they're great! I almost totalled the loaner sedan with the drum brakes that the dealer gave me. I couldn't believe the difference!!!
    Columbus, Ohio
    12,676
    mine are fine. if you want an upgrade, just get slotted rotors (not drilled!). and better pads. you will notice a difference
    i had to stop extreamly short the other day with stock breaks went from 65-70 to 0 in about 5 seconds... was crazy scary but the brakes stopped like champs... ( good tires helped too ) without problem
    Indiana
    11,228
    Quote Originally Posted by reallyflycouple View Post
    Wow. . . IIRC, the drum cars actually had shorter dry stopping distances by a few feet. . .
    Mine are good. I can lock them when pushed hard enough.
  18. #16
    Answer: Buy Tib brake booster
  19. #17
    Apr 2006
    1,978
    I've noticed that my aunt's hatch seems to have s slightly stiffer pedal. Maybe that had something to do with it. I think the stock brakes are fine.
    However, as has been established before stock rotors=garbage.
  20. #18
    Oct 2005
    3,334
    Quote Originally Posted by Doohickie View Post
    I was thinking about this today and here's what I think feels "funny" about my brakes: We've discussed the RPM hang on the MT Elantra and its impact on shifting- the rpms lag a little when taking your foot off the gas suddenly. I think this happens on the AT Elantras as well, but the only time it is really noticeable is when you are on the gas and then quickly jump on the brake. The engine is still driving the wheels while you're trying to stop them with the brakes.
    There are a few ways to counteract this: One is to just be gentle on the brakes and try to anticipate when you're going to stop. Another is to downshift the AT- even though the rpms still are still hanging, that engine speed results in a slower wheel speed. The last possible way (and I've thought about trying this) is to do the restrictor plate mod on the IAC which would keep the rpms from hanging.
    Oh, forgot to mention this: If the rpms are hanging and you're the type of person that gets right on the brake, this could contribute to the premature brake pad wear some Elantra owners experience. You're not only fighting the car's momentum, you're also fighting an engine that continues to try to drive the wheels while you're braking.
  21. #19
    Noob (play gunbound?) jayupark can identify a wrench
    Apr 2005
    Arlington, MA, USA
    1,336
    SS brake lines and green stuff brake pads really, really helped with the brake feel and stopping power for my car.
    Memphis Blues
    2004 Elantra GT
  22. #20
    Even the simple upgrade of R1 concepts Rotors and the Axxis Deluxe brake pads have given my 03EGT a much needed improvement in brake feel. Mind you, I still demand more out of my brakes but I know what I need to do cept I lack the funding currently. Bigger rotors and better front 2 calipers with some tiburon brake booster is the idea so far. It requires one simple adjustment as far as I know for the calipers, simply remove the dust cover lol, beyond that I do believe it's a pretty straight forward caliper swap. ATM, with the simple very affordable brake upgrade from R1 Concepts I can lock up my wheels fairly quickly, still a bit of the mushy pedal but I will need the larger front rotors/calipers to fix that.
Similar Threads
  1. Audio system: Stock or Upgraded?
    By SuperGLS in forum ElantraXD.com Polls
    Last Post: 08-22-2006, 07:22 PM
  2. Whole bunch of stock parts for sale
    By 05xd in forum Marketplace
    Last Post: 05-08-2006, 01:24 PM
  3. Replies: 5
    Last Post: 03-10-2006, 10:44 PM
  4. Stock speaker...
    By SubZeDiZeD in forum Audio/Video/Security
    Last Post: 01-05-2006, 02:20 AM
  5. Replies: 8
    Last Post: 12-03-2005, 12:18 AM
