Speedometer is on crack???
Results 1 to 10 of 10
Thread: Speedometer is on crack???
    Night time is coming T-Storm has not yet proved knowledgeable T-Storm's Avatar
    Jan 2005
    Carpentersville, IL
    119
    Default Speedometer is on crack???
    I have a 2002 GLS elantra with 105,XXX miles. This hasn't started until a couple weeks ago and i need help. Here is my problem. I am driving down the highway between 70-80mph when i noticed my speedometer drop, nothing big, went down to 60 mph, then jumped right back up to where i was at before. No change in rpm's, no lights, nothing. The engine doesn't wind down or anything. Today while driving home from work on the highway, same speed, now the speedometer drops to 0mph, then back to 80, then to 20, back to 80, then to 0 again and hangs out for about 15-20 seconds, then right back to 80. Am i loosing a connection somewhere? I am having no problems with performance, acceleration or anything else, just my speedometer is going nuts. Anyone hear of anything like this or know what's up?
    Nov 2004
    Quebec, Canada
    17,346
    Default Re: Speedometer is on crack???
    Probably a problem with the VSS? The one on the wheel.
    Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
    '02 Elantra GT
    '04 Suzuki Katana 600
    Columbus, Ohio
    12,676
    clean the bay lately? when i used to de-grease, i found after the 2nd or 3rd time for a couple days after, my speedo went dead...always came back...probably ate away any dielectric grease, thus leading to the short out i had months later, which led to blowing ECU fuses left and right
    check the speed sensor on the tranny, directly below the TB...wheel speed sensor wouldnt do that...trust me...had the issue with my old xd 3-4x and now with my current xd. all that one will do is keep you from going above 5100 rpms
    Jan 2005
    Carpentersville, IL
    119
    Ok i will check this out, could you give me some insight on where i could find the speed sensor on the tranny or what am i looking for? A picture would be a great help if anyone has one or has a pic and knows where this is, thanks for the replies
    Near Chicago, IL
    15,223
    Also, if you've had your cluster out lately, make sure the connections are tight. One time after I had mine out, the speedo was working intermittently (similar to how you described). This was cured by undoing and redoing the harness connections on the back of the gauge cluster. All my other gauges/lights were fine, but the speedo got weird.
    • Future: ????
    Veni, Vidi, Velcro Munky has information that can be trusted Munky has information that can be trusted Munky's Avatar
    May 2006
    Noblesville, IN
    10,969
    Located directly above the differential:
    (Note: In this picture the transaxle is laying on it's side)
    evan got it right: i had the same exact problem on my '02 as well
    same year....hmmmm... is there a correlation???
    anyway, i cleaned the speed sensor on he tranny and repacked it with dielectric grease and it has been fine ever since
    although it was cool to go from 0-80 in 2 seconds haha
    Jan 2005
    Carpentersville, IL
    119
    So, replaced the white plug? I will also rip my dash apart, it is in pieces already. Anyone know the light bulbs go in for the gas/engine temp gauge? I took my dash off once and peeled the light covers off the bulbs to get a difference in color, now they don't want to light up
    Near Chicago, IL
    15,223
    ^^^I think if I were you I'd start at the dash connectors. From the sound of it, it could be very likely something was just loose up there.
    • Future: ????
    Jan 2005
    Carpentersville, IL
    119
    Alright, thank you all very much for the input. I plan on doing a ton of work on my XD this summer, if anyone lives in the chicago area and would like to help, let me know
Similar Threads
  1. Rabbit Damages speedometer
    By wfd59 in forum Help!
    Last Post: 03-15-2007, 01:51 PM
  2. speedometer color change
    By Elantra06 in forum Interior
    Last Post: 11-26-2006, 10:25 PM
  3. speedometer for 2004 (5spd)
    By Sistum Id in forum Marketplace
    Last Post: 07-17-2006, 02:56 PM
  4. ignition Coil crack
    By intelinside in forum Help!
    Last Post: 04-18-2006, 12:05 PM
  5. speedometer
    By zedd in forum Help!
    Last Post: 08-30-2004, 05:03 PM
