[XD] P0422
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 37
Thread: P0422
    Junior Member yolmen has not yet proved knowledgeable
    Oct 2008
    Largo , Florida
    96
    Default P0422
    hello , today i got check light (2001 GT) , so i went to advence auto parts to get scaned. Whe got "Main Catalyst Efficiency Below Threshold (Bank 1)" , does that mine that i have to replace the catalyst muffer or the sensor ? thank you
    Oct 2004
    Redondo Beach, Ca
    4,862
    Default Re: P0422
    Replace the exhaust manifold with cat, and the second O2 sensor.
    Night time is coming T-Storm has not yet proved knowledgeable T-Storm's Avatar
    Jan 2005
    Carpentersville, IL
    119
    Default Re: P0422
    I just had this code, check your manifold to see if it is cracked, mine was and it is covered under a recall for 2001-2003 ELantras. The manifold and cat are one whole unit, so they will replace both for free. No matter how many miles, just as long as your manifold is cracked.
    Oct 2008
    Largo , Florida
    96
    Default Re: P0422
    thanks T-Storm , i tooked the cover off and i can see 2 cracks but not that big so ther is something coming out from them , is that enough for replacemend at hyundai ?
    Indiana
    11,228
    Default Re: P0422
    YES. A crack is a crack. If you're under the 10/100 and original owner it will be no problem.
    On a side note, had the same code on the Turd (2000 Accent 1.5) and changed the sensor with a spare I had and have had no problems since.
    Oct 2008
    Largo , Florida
    96
    Default Re: P0422
    i have 98500 miles but im the 3rd owner ,you think its gona be a big problem ?
    Avante2nr Elantra87 has picked up a wrench Elantra87's Avatar
    Jan 2007
    TX
    1,258
    Default Re: P0422
    more then likely
    Indiana
    11,228
    Default Re: P0422
    You don't know until you ask.
    Senior Member HYTECH has not yet proved knowledgeable
    Jul 2006
    florida
    569
    Default Re: P0422
    if you need a replacement you can get a new one here --> https://www.elantraxd.com/forums/showthread.php?t=32092
    Platinum Hyundai Tech, ASE Certified Master Tech, L1 Advanced Engine Performance Specialist, ASE Certified Master Engine Machinist. Over all Gold medalist of the 2011 Hyundai Motors World Skill Olympics #1 Hyundai tech in the world!
    Senior Member Stocker can identify a wrench Stocker's Avatar
    Jun 2008
    Austin
    667
    Default Re: P0422
    I'm the original owner but WAY over 100k and they replaced mine free. It's not a warranty item, it's a TSB.
    I am no longer active on this message board. Please find me at http://www.hyundaiaftermarket.org if you just have to get in touch with me.
    ______
    Check out my blog!
    Oct 2004
    Redondo Beach, Ca
    4,862
    Default Re: P0422
    TSB doesn't mean that it's free. The fact that it's a recall is the reason it was free.
    Indiana
    11,228
    Default Re: P0422
    TSB= TEchnical Service Bulletin. Information provided to the dealerships from HMA on common issues/problems and things to look for.
    REcalls= a REcall, a mandatory fix required by the NHTSB for all vehicles.
    A TSB IS NOT a recall.
    Relic of Soviet Empire farouk has not yet proved knowledgeable farouk's Avatar
    Jan 2007
    NJ
    43
    Default Re: P0422
    Quote Originally Posted by yolmen View Post
    Ownership shouldn't be a problem - I'm not an original owner of my car, and they still replaced my cat/manifold for free. No know about the mileage, but better not wait until 100K
    best of luck, mate
    Oct 2004
    Redondo Beach, Ca
    4,862
    Default Re: P0422
    Recalls don't expire with time or mileage.
    Veni, Vidi, Velcro Munky has information that can be trusted Munky has information that can be trusted Munky's Avatar
    May 2006
    Noblesville, IN
    10,969
    Default Re: P0422
    Just go ahead and take it in there and ask about getting it replaced. Mention the fact that you know it's a known issue, and ask if they will replace it for free.
    A lot of members on here have had it replaced even out of warranty.
  18. #16
    Jul 2006
    florida
    569
    Default Re: P0422
    If the recall was already done then it won't be free. but if it never had the recall done you are set.
  19. #17
    Oct 2004
    Redondo Beach, Ca
    4,862
    Default Re: P0422
    If the recall was closed, saying that it was inspected and not cracked, then the warranty on the manifold gets extended to 10 years unlimited mileage.
    I had the recall closed saying no crack found. Then later it developed the crack, and had it taken care of for free.
  20. #18
    Jun 2008
    Austin
    667
    Default Re: P0422
    If it was already replaced and it cracks again it will be done again. According to the service manager @ the local dealership anyhow.
    ______
    Check out my blog!
  21. #19
    Jul 2006
    florida
    569
    Default Re: P0422
    Ricerrx7 that makes more sense than what I was told. Have you found this in writing anywhere? My District Manager was trying to f### someone or didn't know what he was talking about. About two years ago a manifold cracked about 1 year after the inspection. I called him to ask about the warranty and he said if it passed inspection it is only covered to the end of the original warranty period.
  22. #20
    Oct 2004
    Redondo Beach, Ca
    4,862
    Default Re: P0422
    If I remember right, it's on the actual bulletin.
Similar Threads
  1. P0422
    By yahoo1z in forum Help!
    Last Post: 03-14-2007, 01:52 PM
