[XD] Alignment question
Results 1 to 12 of 12
Thread: Alignment question
    Avante2nr Elantra87 has picked up a wrench Elantra87's Avatar
    Jan 2007
    TX
    1,258
    Default Alignment question
    I will be installing my new struts and springs soon and my Moog tie rod ends.
    I know you need an alignment after installing both. But dont i have to wait til the springs settle to get an alignment? Is it a good idea to do struts/springs & tie rod ends at the same time? I was also wanting to replace my front sway bar links with Moog's. Do installing these require alignment?
    So bacially what all parts require an alignment after being installed?? I dont want to do multiple alignments!! So i need to know what and what doesnt require alignment. thanks for your info
    Tannersville, PA
    12,884
    Default Re: Alignment question
    if you want just install the springs/struts and then a week later do the tie rod ends and then go get aligned...
    tbh it really isnt going to matter
    Ultimate Post Whore BColeman knows a lot about Elantras
    May 2005
    Mahanoy City, PA
    6,582
    You don't want to pay for an alignment twice, so do the struts and springs, and the tie rods and endlinks BEFORE you get the alignment. If you need to wait a bit, go ahead. But don't wait too long, otherwise you'll be picking up a set of new tires too...
    me so sneaky ninja has picked up a wrench ninja's Avatar
    Feb 2006
    New Jersey
    281
    firestone has a lifetime alignment plan.
    here's a coupon for it too
    basically it costs as much as 2 alignments, but you get them for life.
    Jan 2007
    TX
    1,258
    Quote Originally Posted by ninja View Post
    nice thanks man
    Quote Originally Posted by BColeman View Post
    great thanks!
    Junior Member blmqzjc has not yet proved knowledgeable
    Sep 2009
    Ormond by the Sea, FL
    178
    I had a lifetime alignment plan once, on an 86 Acura Legend. It worked out pretty well considering, cause I owned the car for 17 years and had the plan for at least a dozen of those years. You do need to be aware of a couple of things though:
    1) As was pointed out, the upfront cost will generally be "at least" double that of a standard alignment.
    2) Some plans may limit the number of alignment "checks" you can have (like 2/yr or once every so many miles, etc., so read the fine print and be sure you are ok with it.
    3) The main purpose of such a plan is to get you back in the shop on some sort of regular basis (once or twice annually), so they can attempt to sell you other services (like brakes, tuneups, oil changes, all kinds of flushes, CV cracked boot replacements, etc.). The need for some of these is questionable of course. There is nothing wrong with that marketing logic, but you just need to be aware of it (as I'm sure many posters here are).
    If your vehicle is prone to getting out of alignment often, or if you hit a lot of potholes and curbs , it can be a good deal to have such a plan. I've never considered it on my Elantra, though, cause I'm at 38k miles and have yet to have an alignment done. Will probably have it checked when I buy new tires (around 45 to 50k miles), but so far the tires are wearing well.
    Jun 2005
    Eastern Shore, MD
    12,635
    you don't need an alignment after the sway bar links, and you don't need one after the outer tie rod ends (but that's only if you know what you're doing). You will however defintely need one after the springs/struts.
    2002 Hyundai Elantra: Sold
    1992 Toyota MR2: Sold
    Tannersville, PA
    12,884
    if you want to count the threads...but if your getting one done anyway...you might as well just slap the tie rods on just before the alignment
    Jun 2005
    Eastern Shore, MD
    12,635
    Theres a far easier way than counting threads.
    Jan 2007
    TX
    1,258
    whats the easier way? the only way i know is counting the threads
    Jun 2005
    Eastern Shore, MD
    12,635
    Just break the jam nut loose then use your fingers to put it against the outer. Just spin the outer off all the way then screw the new one until it hits the jam nut. Viola, it is exactly where it was before without needing to sit there and count threads. Use your brains kids
    Tannersville, PA
    12,884
    but without looking on the machine the alignment could be off and then your just putting on new tie rods on the funky alignment. same goes for counting the threads...
