High comp pistons, or shaved head??
Results 1 to 15 of 15
Thread: High comp pistons, or shaved head??
    Vtec what? BLK02XD has not yet proved knowledgeable BLK02XD's Avatar
    Ocala, FL
    350
    Default High comp pistons, or shaved head??
    which is the better way to go to raise compression, the pistons, or the head.
    im going to be getting a spare motor this week if things work out right. so i figure ill pull the head off that and send it to the machine shop. im gonna get it ported and polished definately, wether or not i want to shave it down though is the question. does anyone know if anyone has used the tigerlilly high comp pistons, or anyone who has shaved down the head on the beta motor, and if ones better than the other?
    Ultimate Post Whore FordFasteRR can identify a wrench FordFasteRR's Avatar
    Ocala, Florida
    3,950
    Default Re: High comp pistons, or shaved head??
    sorry, I have not heard of anyone doing this yet.
    However, from the books that i've read on engine tuning.. every point of compression that you increase gives you from 3-5% more power, but you need to increase the octane to keep things from blowing up.
    now, if you can raise the compression and still use pump gas, you are golden !
    you can get a nice power gain basically for free.
    Mad Scientinst oregun has not yet proved knowledgeable oregun's Avatar
    Oct 2004
    Chicago
    338
    I talked to Dave at RPW about going high compression. If you do go this route, you want to port and polish the head, because you will get carbon build up like crazy.
    I would also advise using pistions vs. shaving the head. This method maintains the proper squish area.
    Ocala, FL
    350
    ok i looked around a little bit and from what ive found they say 10.25.1 is the highest on pump gas. thats only a quarter of a point more correct?
    so not too big of a gain without going to race fuel which isnt the way i want to go.
    Ocala, Florida
    3,950
    you dont have to use race fuel..
    you can mix in a gallon of TOLUENE from sherwin williams and raise your octane safely .
    Here is an article on this:
    http://evo.jedinite.com/toluene.html
    Poster God faraco3 can identify a wrench
    Nor Cal
    1,150
    Dont the Betas have a compression of 10.3:1 ?
    According to webtech its 10.1:1
    Quote Originally Posted by oregun
    Are you referring to quench?
    Senior Member O_GT has not yet proved knowledgeable O_GT's Avatar
    Fairhope Al
    687
    Quote Originally Posted by FordFasteRR
    you don't have to use race fuel..
    you can mix in a gallon of TOLUENE from Sherwin Williams and raise your octane safely .
    Cool stuff ford.How do you find this stuff
    01 gt lots of mods
    05 Frontier lots of mods (sold)
    06 WRX stock (rip)
    11 Sonata turbo (sold)
    13 BRZ
    11 Outback
    Ocala, Florida
    3,950
    Quote Originally Posted by O_GT
    lol, I spent some time on the evo forums and gained some knowledge LOL !
    19 second madman tharptroy has not yet proved knowledgeable tharptroy's Avatar
    Dallas, TX
    2,506
    squish ~ quench
    pistons will always net better results. shaving the heads is the half-assed way of doing it.
    10.25:1 is a joke.
    the car from the factory runs close to that on 87 octane.
    I dont see any reason why you cant run 12:1 if you set it up right. (daily street use)
    11.5:1 would be a little safer. you're going to have to go with custom pistons, because I havent seen any pistons with a good streetable compression ratio. its either 9:1 or 13:1
    and you're going to need head work
    they'll have to take a little off of the head to get you a nice mating surface, and I can guarantee you that you are wasting your time if you dont get cams to optimize the setup.
    "Setting up your car for autoX is like tuneing your car for parking." -liveforphysics
    Super Hero XDGT03 has not yet proved knowledgeable XDGT03's Avatar
    Michigan
    579
    I'm really interested to see what he would get from just doing the porting. Particularly on the exhaust side. Carbon was supposed to get the head flow tested but he gave up I guess.
    Ocala, FL
    350
    well im getting my spare motor weds morning, so im gonna see what i can do with the head off that one, either port it a little bit myself, or save a little money and give it to the machine shop to let them do their magic.
    Ocala, Florida
    3,950
    BLK02XD, you could also get an OBX cam sprocket and further tune the ported head ...
    I suppose that if I gained 2 whp and 4 ft.lb torque on a stock head, you could easily gain double that with a ported head !!!!!!
    obviously, the stock cams are set too far back from the factory to make peek power / torque!
    Ultimate Post Whore slow 2K2GT knows about Elantras slow 2K2GT's Avatar
    Ontario
    4,605
    I dont think anyone has gone this route (ie high compression) I know that Rshack with cams, header, exhaust, and intake (not sure about pulley) is making 165whp. Ford you said that for every point of compression you increase you should see a gain between 3-5%, coupled with some good cams (268 or 272) and a head job. This may be another route for some power though I see it costing no less than FI. Oh well im sure someone will try it.
